No power, can't figure out, should be a beast!! - Dodge Cummins Diesel Forum
Old 05-05-2012, 10:54 PM   #1 (permalink)
Hey guys, I need help, I'm ready to give up! I put a motor in my truck, and I used the pump that was on the motor, but it ended up being bad, so I replaced it, I've done everything I know to do, and I can't get any power, it is sluggish as hell, and smokes like a , after it gets into 3rd, it starts to spool, it gets to maybe 25psi, it acts like the fuel is drowning the turbo, but I've done all the adjusting I know to do, what I've got is a '97 12v, 5 x .014's, afc is modded all the way, #0 plate, 4000 gsk, ive set the timing at 18* twice, once the normal way, and once by the spillport method, and a 66/74/14 turbo, and of course lots of tranny goodies, why is this thing so lazy????
Cumminstrokethis5.9 is offline   Reply With Quote
Old 05-05-2012, 11:02 PM   #2 (permalink)
What is your fuel pressure?
1997 3500 club cab Automatic 3.54 gears towing and camper package. Still stock with 116k on it so far. 4" dynomax stainless exhaust, 4kgsk, and pacbrake exhaust brake waiting for installation. Still need ideas for improvements for hauling 15k fifth wheel.
country_hick is offline   Reply With Quote
Old 05-05-2012, 11:06 PM   #3 (permalink)
pic_jon's Avatar
Specs on torque converter?
97 12v 2wd project: Dual-Fed 913 by Seth | 148* 7x.010" | 351cw/475/92/1.1 | Valair DD
pic_jon is offline   Reply With Quote
Old 05-05-2012, 11:17 PM   #4 (permalink)
Triple disk billet, rated at 1250ft. lbs.
Old 05-05-2012, 11:22 PM   #5 (permalink)
Best I remember it was around 15 or so, but I don't think that's the problem, cause like I said, the thing will stop traffic it makes so much thick, black smoke
Old 05-05-2012, 11:25 PM   #6 (permalink)
15 is to low. That could be your problem. It may be your OFV is bad causing the low pressure. If not your lift pump may be the issue.
Even if the low fuel pressure is not your big problem it is till a good idea to get it where it should be.
Old 05-05-2012, 11:26 PM   #7 (permalink)
And I did a boost leak check too, all good!
Old 05-05-2012, 11:36 PM   #8 (permalink)
Smourj21's Avatar
iTrader Score: 4 reviews
timing is low...have you tried to tune the low boost fueling, and afc?
02 QCSB 6 Speed|215 P-Pump 600cc 24*|SAC 7x12|131 DVs|.084 Lines/Tubes|64/71/14/S475|Tunnel Ram|CFM+| Water/Meth |6" Miter|Valair DD 3600|Colt 181|HD Push Rods/Springs| O-Ringed Head|ARP Studs|AD150|Dana60/80|3:55|True Trac|35" Toyo MT's|Quest for 700+ |
Smourj21 is offline   Reply With Quote
Old 05-05-2012, 11:58 PM   #9 (permalink)
pic_jon's Avatar
First and foremost.. Fill out your sig.
You need to spend a LOT of time tuning/dialing it in. I mean A LOT.
How is your afc set up? Give as many details as you can
Which afc spring are you using?
Afc location? front, back, middle..?
Pre-boost screw location?
Washer mods?
Ground afc barrel?
Ground afc foot?
Also, exhaust leaks anywhere?
What is your air intake set up?
Who's injectors are you using?
Which delivery valves?
Which pump?
Knowing your WOT fuel pressure wouldn't hurt.
Old 05-06-2012, 03:25 AM   #10 (permalink)
Not getting on top of your turbo, could be for many reasons.
98 12V auto 3.55 213K+miles, BHAF, Full 4" exhaust,AFC tuned just right.boost/pyro, 7 Blade HX35, 5x.012 Con. injectors,48RE trans with suncoast tripple disk TC koleene steels and trans-go shift kit, Tork Tec Adj. OFV
98-6BTA is offline   Reply With Quote
Old 05-06-2012, 10:54 AM   #11 (permalink)
When it idles, the fumes burn your eyes??? And I have the washer flip done, and ground off the foot, everything to the afc, and I've been playing with adjustments, but right now, I've got the star wheel kinda tight, and the pre boost I'd backed up probably half way, but the thing still just pours smoke on the bottom, and doesn't move the boost needle till late 2nd gear, even then it maxes at 25psi????
Old 05-06-2012, 11:57 AM   #12 (permalink)
You do realize that is a pretty darn big single for a street truck? Gonna be hard to make it street-able, tuning can only do so much, but I'm sure you can do a good bit more.
