aftermarket tach? - Dodge Cummins Diesel Forum
Old 04-24-2012, 10:10 PM   #1 (permalink)
dmaxlly06's Avatar
aftermarket tach?
Anyone running an aftermarket tach? If so post up some pics and let me kno of the brand. My chummins doesn't have a stock tach and i really need one
dmaxlly06 is offline   Reply With Quote
Old 04-24-2012, 11:46 PM   #2 (permalink)
cliff-1972's Avatar
I am running a Autometer 3781 8000rpm gas engine tach using a Dakota Digital DSL-1 w/a Flywheel Tachometer Interface Unit .Dakota Digital now sells a DSL-2 that comes with the probe(flywheel interface).This works very good.Just count the # of teeth on the flywheel,put that # in the DSL-1 and you set.I mounted the probe off the bottom of my trans bellhousing w/a bracket I made.There maybe some photos of it in my webshots below my sig.
1996 Ford F250 reg cab 4x4 98 12v,benched pump,Weston 5x.016,o-ringed,cammed,compounds,etc....E4OD,4.10's on 315/75/16 Dura-trac
http://community.webshots.com/user/cliff1972
cliff-1972 is offline   Reply With Quote
Old 04-25-2012, 12:11 AM   #3 (permalink)
dmaxlly06's Avatar
Do you have a website for the interface
Old 04-25-2012, 01:00 AM   #4 (permalink)
cliff-1972's Avatar
Dakota Digital sells it also.Summit or Jegs carry both items also.
Old 05-04-2012, 01:01 AM   #5 (permalink)
04.5ROHLING's Avatar
I have a friend we just put a tiny tach on it that's the name it is a fully digital it has a rpm high recall hour meter and other stuff the only hold back is the screen is only about 3in but to wire it all u do is clamp a transducer on a injection line and run a positive and ground I think he gave $100 buck for it the website is tinytach.com is where he got his great for the money
2004.5 auto meter,hushpower,Billet phat shaft trans,180hp injectors,T&C 150% daul cp3's wild rail with 30k cprv 66/480,Hamilton 188/220 and springs few other goodies UDC tuned by Gecovey/Coffman Customs
04.5ROHLING is offline   Reply With Quote
Old 05-04-2012, 01:20 AM   #6 (permalink)
One big problem with this on a 12V
98 12V auto 3.55 213K+miles, BHAF, Full 4" exhaust,AFC tuned just right.boost/pyro, 7 Blade HX35, 5x.012 Con. injectors,48RE trans with suncoast tripple disk TC koleene steels and trans-go shift kit, Tork Tec Adj. OFV
98-6BTA is offline   Reply With Quote
Old 05-04-2012, 03:41 PM   #7 (permalink)
What's the problem his is a 12v and it works great
Old 05-04-2012, 08:37 PM   #8 (permalink)
#2gunsmoke's Avatar
i have the 5" autometer 6k pro comp diesel tach.. i just modded my fluidamper as the instructions say. works great.. a little glitchy before fine tuning it.
94 F350 12v it started as a test unit for fuel system parts, baselining at 451/1083... now its a full blown 2.6 truck with some bada$$ names on the side of it.
#2gunsmoke is offline   Reply With Quote
Old 05-04-2012, 11:03 PM   #9 (permalink)
I Have a 2 5/8 Autometer Tach that uses a pick up which ties to the outside of the alternator. About $130. I havnt fitted it as my truck is still being built
1994 3500 dually SLT 6BT,KDP Killed,4in Exhaust,TST
4 plate,boost elbow,Airride suspension,22in American Forcewheels, 1955 GMC LCF cab
NZ Musclecars is offline   Reply With Quote
Old 05-06-2012, 10:02 PM   #10 (permalink)
73Fummins's Avatar
Running a Autometer 2 5/8 sport comp as well. A little on the small size (used to a 5" monster) and a bit off a pain to calibrate, but works well and will fit anything with an altenator.
73 F250 ccsb 4x4. 2" body lift. 95 ic'ed 12V. kdp tabbed. #100 plate. Adj wastegate. nv 4500. SB clutch. 4" exhaust. 3.54 d60's true tracks 35s. 2wd steering box. hydroboosted. Full autometer gauges in custom cluster. 02 dodge frt seats frt and rr.
73Fummins is offline   Reply With Quote
