Best intake manifold - Dodge Cummins Diesel Forum
Old 04-18-2012, 10:50 PM   #1 (permalink)
ram2500saba's Avatar
hey guys which is the best intake manifold on the market for these 12vs? any reviews/personal thoughts. ATS? CFM? BANKS? ETC. let me know
ram2500saba is offline   Reply With Quote
Old 04-18-2012, 10:56 PM   #2 (permalink)
Why do you want or need a different intake? If you fill out your profile with your truck information you might get a better answer for your goals. Several guys have just taken exhaust tubing and made their own intake.
1997 3500 club cab Automatic 3.54 gears towing and camper package. Still stock with 116k on it so far. 4" dynomax stainless exhaust, 4kgsk, and pacbrake exhaust brake waiting for installation. Still need ideas for improvements for hauling 15k fifth wheel.
country_hick is offline   Reply With Quote
Old 04-18-2012, 10:59 PM   #3 (permalink)
I have read about air restrictions caused by the stock intake manifold. Perhaps an after market one will lower EGTs, give a little if any more power.
Old 04-18-2012, 11:04 PM   #4 (permalink)
WA east side Vice President
cumminsrulez's Avatar
are you talking about the intake horn or the actual intake manifold that bolts too the head?
On Cummins forum instead of working or doing homework.
97,2wd,5 spd, 150k,4510 nano,5in to 6in miter,100 plate,afc mods,egt boost fp,valair single,16*,4k gsk-60pounders,traction bars,.10 over gasket, tork tek ofv,.025 dvs, he351vgt 406hp 9-29-12
cumminsrulez is online now   Reply With Quote
Old 04-18-2012, 11:31 PM   #5 (permalink)
I asked a similar question about a split intake manifold and this is what I was told by someone who is very knowledgeable about these engines.
"On a stock head the intake flows 135cfm &160 on the exhaust. If after doing this your boost went up and you drive pressure went down you could say it made a difference it wont. It takes better head flow to drop egts (more air through the head). Everybody talks about the uneven flow between cylinders but I have yet to see any results of egts of each cylinder and that is influenced by the way water is circulated through the head."
Apparently the air intake is not the real problem. Porting the head would be the right solution to drop egt's. As expensive as the head gasket is I would not worry about it until you get to serious power levels or develop a leak.
Old 04-19-2012, 03:36 PM   #6 (permalink)
Btp 2332's Avatar
The stock intake horn is good for alot of hp and would be one of the last things I would purchase. But to answer your original questions I have read of a few of the cfm's cracking and a few exploding with high boost, the only ones I have tried on my 98 12valve and my 2007 was the afe bladerunner. Its a real nice peice and I could feel alittle in low end response. Its also has ports on the back for water/meth injection etc.
2010 3500 H&S Xrt Pro, flo pro, egr deleted.
1998 12v,11.46@116.5 fuel,S475
Dads 1997 10.78@125 fuel,S480/1994 3500 tow rig
Btp 2332 is offline   Reply With Quote
Old 04-19-2012, 04:39 PM   #7 (permalink)
Feller's Avatar
Pusher intake horns. Great prices
Sent from my SGH-T989 using AutoGuide.com App
95 CCLB 4x4 auto, 4" exhaust, 3-pc manifold, S&B CAI, Fuel plate removed, heavily modded afc, 4k gsk, #60 valve springs, 2095 plug, boost elbow, Tork Tek adjustable OFV, 20* timing, KDP tabbed, boost fuel pressure & pyro, THUREN/CARLI SUSPENSION
Feller is offline   Reply With Quote
Old 04-19-2012, 04:53 PM   #8 (permalink)
12valvedriver's Avatar
Won't make any performance difference but would clean up the look under the hood. Another vote for either pusher or crazy carls. Both are reasonably priced and look good
'97-5" straight #100 ff, 19*, 4k gsk, valair dd clutch, 1-3/8" billet input, ARP studs, 60# springs, BD Super B over s475, 024's, Mayville WI best 5x14's,
'90-4" exhaust kdp killed
12valvedriver is offline   Reply With Quote
The Following 2 Users Say Thank You to 12valvedriver For This Useful Post:
ram2500saba (04-22-2012), TURBOLVR (04-20-2012)
Old 04-19-2012, 07:50 PM   #9 (permalink)
Btp 2332's Avatar
Agreed with above^ If I didnt have the bladerunner I would have got one of those.
