Best single turbo for towing? - Dodge Cummins Diesel Forum
post #1 of 21 (permalink) Old 09-13-2011, 10:51 PM Thread Starter
Mr. Bob's Avatar
I am toying with the idea of building a towing twin setup, or the GOS performance cummins conversion twins, but the $3999.99 price tag makes wonder if this is the correct route for me to go.. Because of where the Ford heater box is, there is very little room between my turbo ( running a flipped manifold already) and the heater box.
I am currently running a BD super B special turbo combined with the mods in my signature. I think this turbo is great for performance and milage empty, but I find it slow to spool while towing, making it smoky before spooling and having to watch EGTs closeley.
If I were to "cheap out" and steer away from twins, what would be a good single turbo for daily use and towing my 5th wheel? Want quick spooling, low smoke, reasonable EGTs..and for it to work well with my current mods..
Thanks
Bob
1995 Ford F350 XLT CC LB 4X4, P Pumped 12V, ZF5, D60, Sterling 10.5, SDX 5X14 Injectors, 63/68/12, 175 Pump, mack plug, .024DVs, AFC mods, 100 plate, 4GSK, Studs and O rings, 60LB springs, Colt Cams Camshaft, Southbend clutch, PSD Intercooler, Autometer Gauges
Mr. Bob is offline
post #2 of 21 (permalink) Old 09-13-2011, 11:21 PM
Ducky Fuel Injection
xzaq103's Avatar
iTrader Score: 5 reviews
If it were me I would keep the 64/71 and run a T3 spool flange.
DUCKY FUEL INJECTION
Home of DFI Injectors!!!
Visit us at
Shop - 479-365-2006
Cell - 479-799-3953
98 12 Valve 11.30/118mph
06 LBZ mostly stock....
xzaq103 is offline
post #3 of 21 (permalink) Old 09-13-2011, 11:46 PM
petie6464's Avatar
The S300 57-65-14 may be a good fit. Thatís my choice as soon as I can get some $$. I am DD, towing and looking for some decent fuel mileage.
Not sure about the 5x.014's with the DV's that's a good bit of juice. I'm sure someone will chime in with hands on knowledge. Maybe it will change my mind too?
97 CCLB 4x4 5-speed, 97 CCLB Dually 5-speed. 2011 4500 C&C
petie6464 is offline
post #4 of 21 (permalink) Old 09-13-2011, 11:50 PM
rdix7991's Avatar
I would do a 62/68/12.
Runs good!
That's all that matters at this point!
rdix7991 is offline
post #5 of 21 (permalink) Old 09-14-2011, 12:01 AM Thread Starter
Mr. Bob's Avatar
With my manifold flipped, I would not have enough space to run one without pushing my charger into my heater box
Mr. Bob is offline
post #6 of 21 (permalink) Old 09-14-2011, 12:10 AM Thread Starter
Mr. Bob's Avatar
The 68/12 would probably spool real fast, but how would much would that change EGTs?
Mr. Bob is offline
post #7 of 21 (permalink) Old 09-14-2011, 12:36 AM
TB1
I have a 62/68/13 and it's great for daily driving/hot rodding but is not the best towing turbo by a long shot but it's not terrible either. Flat highway towing is fine easy to control egt's get it into the mountains and its real easy to get under it and it's hot and smokey real fast. That being said it's manageable to drive and the water meth kit I made up really helps. The biggest problem is the low end fueling, I think if the turbo would light quicker it would help out a lot,
I'm adding some .024 delivery valves in the next week and see what that does for spool up also I need to fiddle a bit more with the pre boost fueling because I don't think I've found the sweet spot yet.
1996 extended cab manning motor sports 63/68/14 , PDD budget builder 5x.014 injectors,.024 delivery valves, 4gsk, AFC mods, Mack rack plug,timing @ 17*Head studs Isspro gauges and AFC Live. PDD turbo tuner
TB1 is offline
post #8 of 21 (permalink) Old 09-14-2011, 12:54 AM
Richard LeBar's Avatar
My 62/65/14 tows really nice with my mods but my injectors are smaller, I don't have the 2095 plug or the DVs. I could see things getting puuuuurty hot with those 3 mods. I could tow 9k without issue very easily with what's in my sig to the point that I can't even imagine needing or wanting any more mods for a tow rig. The thing was fast, didn't run hot, wasn't smokey, and towed like a dream. Maybe swap for an s362 and detune?
2003 F250 SD 4x4 3.73 SCSB VE Cummins, 60#, Hamilton pushrods, light home porting, A1 studs, 80lpm injectors, LPLP, home AFC work, stock ground pin, ATS mani (blanketed), s362/68/.7 sxe, 4R100, PCS TCU, gauges, 4" Lift, 35" tires
Richard LeBar is offline
post #9 of 21 (permalink) Old 09-14-2011, 02:14 AM Thread Starter
Mr. Bob's Avatar
It's a little different too with the Standard VS Automatic. I know with my 2002 powerstroke I went from the 1.0 exhaust housing on my Garrett 38R to a 1.15 and it was awesome, but that truck was automatic.
The standard trucks need the slightly smaller exhaust to get that turbo to light again after shifts.. The 71 exhaust wheel probably does not help fast spool up either.
I was looking around to see if I could go with a smaller exhaust housing on the Super B Special, but nothing so far...
Mr. Bob is offline
post #10 of 21 (permalink) Old 09-14-2011, 01:44 PM
that's true but even so my truck locks up at 65kmh when it shifts from 2 to 3. It locks and shifts into 3rd at the same time. If I have the pedal to the floor and am at max boost I lose so much rpm that the turbo barks
I mean, I can get like 25psi out of my turbo with the converter locked at 1700rpm without difficulty. and I can get 10psi easily at 14-1500rpm locked up without trying to hard. That's unloaded of course. Spool up of this turbo is pretty good when the converter is locked up. 1700rpm on a locked up trans is about where it lights HARD, at least on my setup. So even though you lose your boost between gears with the stick, you'd still be ok if you can get good boost down at 1700rpm. Shift when ya get to 2500+ towing and you'll be ok. Which you probably should do anyway since that's where max hp is (on a stock truck)
Basically what I';m getting at is if you went with a single for towing. A 62/65/12 or 14 would probably work wonders for ya if ya detuned a little bit (mainly talkin abou tthe DVs).
post #11 of 21 (permalink) Old 09-14-2011, 04:18 PM
BrainChild's Avatar
im running a 63/68/15 non gated.... i towed about 7000lbs from calgary over the rockies into BC a month or 2 ago... i had to dial up my afc quite a bit to keep the smoke down, but it towed fine... if it starts getting hot, drop a gear. rpm's up around 2000-2500 on big hills. I had it @ 3k in 3rd pullin thru the snowsheds near the summit but it worked out fine, anywhere between 800-1000 on flat ground and driving by the EGT gauge up hills... it's a sacrifice, but when your towing your working.... not racing.
96-CCLB-5spd-DD Valair-fresh 12v-155* bowls-180pump-stock sticks-7mm SDX-2095-A1's-P&P manifold/Gasketmatched Head-Custom Fuel/Dual Feed-7" lift-Lockout Hubs-5" stack-HE351/S475 twins
BrainChild is offline
The Following 2 Users Say Thank You to BrainChild For This Useful Post:
boostedpower (02-09-2012), whitlers (03-03-2012)
post #12 of 21 (permalink) Old 09-14-2011, 05:37 PM
PVAUTO's Avatar
i have a industrial 62/65/14 gated. spools super fast. maybe faster than stock. egts have never gone past 1300* but im curious on how this turbo and a 63/68 would compare myself? i wouldnt run anything ungated towing but thats my preference
97' 4x4 12v,transgo vb/3disc TC/built trans,custom plate,modded afc, 4"str8 pipe,ps62,4gsk,21*,omega fuel modded 370,2095,ported manifold,modded air filter set up,synthetic 75w90 all around,gauges,35 on H2's,KORE coils,carli 2.0,4.10,agr gearbox
PVAUTO is offline
