Banks power fuel plate and waste gate - Page 4 - Dodge Cummins Diesel Forum
post #37 of 42 (permalink) Old 07-29-2011, 12:10 PM
1stgen3rdgendodge's Avatar
Not sure exactly what kind of proof I can provide for that other than go watch one run on a bench. All I'm saying is I watched one run at school on a bench and at peak torque (cant remember exactly what RPM that was at id have to loook, its different per application) stock plate slid the whole way forward it was pushing 120cc's of fuel. With the plate out at the same RPM it only flowed 60cc's. Now im not saying that higher up in the RPM range your not gonna gain anymore fueling, cause you probably will, but not a lot, but if your looking for all out torque down low then leave the plate in cause thats where the pump was designed to deliver full fuel.
01 2500 QCSB 4x4 - NV4500 Swap, 3600# SD from Kenny's, Quadzilla ADR 4k, 150HP Jammer Nozzles, RSD 4" Down Pipe-5" Straight Pipe, AEM CAI, Raptor 150, Big Line Kit Tank to VP, Leveled, Recon Smoked Cab Lights (110# Springs, HD Rods, Head Studs, in the works)
1stgen3rdgendodge is offline
post #38 of 42 (permalink) Old 07-29-2011, 12:59 PM
12valvedriver's Avatar
interesting....this is the very first time i have ever heard someone say ANYTHING close to this.
personally i dont see how this could be possible. the plate onle effects top end fueling and torque doesnt occur at that point so i dont see how this is possible. BUT i have no facts that could back up my statement so im here to learn
'90-Getrag 360, mostly stock
'97-NV4500, Kinda fast
'17-G56, all stock
12valvedriver is offline
post #39 of 42 (permalink) Old 07-29-2011, 02:09 PM
I'm not trying to upset anybody or start any arguments. Just stating what I witnessed. I would have never believed it before. Now I'm not sure why it happend like that. Teacher didn't go into detail and explain why just wanted to show us. We never tried it at higher RPMs to see what kind of results we would get.
post #40 of 42 (permalink) Old 08-01-2011, 03:10 AM
Originally Posted by jrswoodworking View Post
My 12 valve is a 98 and have to smog it.
Don't I need the egr to pass smog?
yes you do. but you can easily unblock the manifold and swap intake horns for smog and clear your trouble code with a scanner
the plate limits max fueling (boost or no boost) at particular rpm, hence why they give you a profiled cut.
if it's restricting fueling at low rpm it will affect torque.
Obsessed with power is such an understatement!
The pursuit of power is more often than not an unobtainable goal that is remedied by DEATH
FIRESTARTER is offline
post #41 of 42 (permalink) Old 08-01-2011, 09:33 PM
I ripped my Fuel plate out just the other day and seems to be like a rocket ship haha.. why single disc? I was shootin for a dual disc street cluth?
Maxed 12mm pump, nv4500 w/ Valair DD, 35'' BFG on 3rd Gens, S300 Borg Warner, 12mm ARPs, BHAF, A-Pillar gauges and bad case of ITS
DC9612V is offline
post #42 of 42 (permalink) Old 08-02-2011, 07:19 AM
OrangeP's Avatar
didnt know what you were going to be using the truck for, you dont need a dual disc to hold 300 hp
98 12v hand shaker, Mumau diesel, Keystone diesel
Running Mayville WI's best injectors
OrangeP is offline
