12 valve cummins problems - Dodge Cummins Diesel Forum
Old 05-20-2011, 09:27 PM   #1 (permalink)
Hello, i have a 94 dodge diesel, 12 valve cummins, straight piped, new air filter, 35 inch tires, 5 speed standard, at 100 km/h the rpms are 1750. I just purchased it and i haven't been able to get over 15mpg and it is extremely gutless, won't go past 120km and won't pull past 2200rpm. what do you think is wrong?
94dodgediesel is offline   Reply With Quote
Old 05-20-2011, 10:24 PM   #2 (permalink)
petie6464's Avatar
Welcome to Dodge Ram ownership Check you fuel filter and do some reading here there is a ton of good info. on what could be your issue (s)
97 CCLB 4x4 5-speed, 97 CCLB Dually 5-speed Hauler, 85 Crew Cab CTD conversion.
petie6464 is offline   Reply With Quote
The Following User Says Thank You to petie6464 For This Useful Post:
94dodgediesel (05-25-2011)
Old 05-20-2011, 10:33 PM   #3 (permalink)
o6smoker's Avatar
You need a 3 or 4kgsk to get fueling past the 2200 rpm-ish range. As for mileage lighten your foot and as petie said check for leaks in the fuel line and fuel filter also.
96: 35" trail grapplers, no plate, 18* timing, bald asian 5x.014 SAC, S&B intake, 5" TBE, full billet tranny, 191 dv's, 4kgsk, triple gauge pillar, super b special.
06: cummins completely stock
o6smoker is offline   Reply With Quote
Old 05-24-2011, 01:19 AM   #4 (permalink)
ok thanks, yea i put a new fuel filter on it and it didn't change any, but i did notice the rod that goes from where the throttle cable is connected, to the back of my pump on a lever (assuming its something to do with the swash plate?) was taped on from the previous owner and fell off, so i called the dodge dealer and theres a re-call on that, hoping that will play a key part in my mileage. Now i was looking on the net, and are dynomite injectors and fuel plates decent products? what would you guys recommend for a good gain in power but nothing too ridiculous?
Old 05-24-2011, 01:34 AM   #5 (permalink)
JT422's Avatar
Before you consider injectors read up on the tech articles for these trucks. You can free up about a hundred horsepower with nearly free mods.
94-98 Tech Articles - Dodge Cummins Diesel Forum
The mods I would start with are, a fuel plate (you can grind yours down, pull it out completely, or buy one off ebay for 35 bucks), 3k or 4k governor spring kit (from TST Products), an AFC spring kit (also from TST products), an adjustable boost elbow (these are cheap), and tuning your afc. Also have you tabbed the killer dowel pin yet? If not get on that. You can make your own or buy a kit from TST with a new timing cover gasket. Now, start with those mods and see how you like how it drives. Keep in mind that you will need a new clutch with these mods because your stocker won't hold up. Valair or South Bend are two great clutch companies. As for injectors get a hold of SDX or a guy by the name of partyshortbusdriver here on the forum. Either of these guys will be able to get you way better injectors than DDP (no offense to ddp) at a much lower cost.
Start with reading up on those tech articles though and then come back with questions for us.
1997 Ram 3500 Extended Cab Dually 4x4 | 342hp/845 ft lbs | NV4500 | Valair 500hp SD | Isspro EV2 Gauges | DFI 5x.012 | 16.5* Timing | Vulcan Draw Straw | #10 Fuel Plate | 4k Gov Kit | 230K |
JT422 is offline   Reply With Quote
The Following User Says Thank You to JT422 For This Useful Post:
Old 05-24-2011, 02:24 AM   #6 (permalink)
cameronc's Avatar
Check your timing
94 reg cab 2wd/4k gsk/19.5*/cpp 7x.010's/sdx dv's/ and a big turbo in the works
cameronc is offline   Reply With Quote
The Following User Says Thank You to cameronc For This Useful Post:
Old 05-24-2011, 05:28 AM   #7 (permalink)
Freewheelin's Avatar
sounds like your truck is fine, operates like it was designed to. if ya read the beginners section, ya would know stock gov spring start defueling at 2200 rpm.
"straight piped" why does everyone think this is such a notable upgrade?
And like JT422 said, is easy and almost free to get around 100hp extra out of your rig, and you'll be well on your way to frying your stock clutch.
Preboost screw bottomed out, gutted afc. Custom plastic bag over airfilter, No gauges. Delivery valves removed, 9.5 X 23.25 injectors, Turbo removed. silencer ring port and polished to stage 1.5
she roals the coal... and a tire on fire in the bed.
B O T T S R . COM
Freewheelin is offline   Reply With Quote
The Following User Says Thank You to Freewheelin For This Useful Post:
Old 05-24-2011, 10:19 AM   #8 (permalink)
JT422's Avatar
Lol yup. I lost about 1.8 mpg with my 5 inch system.
Old 05-25-2011, 09:32 PM   #9 (permalink)
thanks guys for the help and information, with putting that new nation wide change up kit (throttle cable, fuel filter, return springs, and ball valve ends for the govenor shaft), the truck is running way better, the guy before me just had the shaft taped on and it wasn't connected properly. Yes i agree with you FreeWheelin, a 4" exhaust system doesn't change the trucks performance much unless you are cranking out big power, just makes them sound good thats all. I will check up on that tech articles to see how to tune this engine up properly and maybe gain a little more power.
Old 05-25-2011, 10:42 PM   #10 (permalink)
CorneliusRox's Avatar
Going from my stock 3.5" (that was rotted out) to a 5" w/ flow through muffler (3.5->4->5" downpipe), I picked up a couple mpg. Has a nice growl to it too.
Also, I love your sig. lol
08 Audi A4 6MT, 97 Dodge 12V, 5" Lift/37" STT's, Audio Junk, EGT/Boost, Cone/Dual Ram, HX35, AFC Modded/Tuned, 20* Timing, 275k+, about 750ftlb and 350rwhp
CorneliusRox is offline   Reply With Quote
Old 05-25-2011, 11:37 PM   #11 (permalink)
liteweight's Avatar
Not understanding why you would have lost fuel mileage with a larger system. Unlike gas engines that require the proper sized exhaust for proper cylinder scavenging, diesels don't rely as much on scavenging due to the forced air intake with no fuel charge. The larger the pipe the sooner the cylinders will clear of exhaust gases.
liteweight
96 4X4 2500,KDP,16.5*,40hp injectors,boost elbow,3K,ground plate to 0,AFC mods,5" exh.BD pressure loc kit,lock up switch,low stall,Rebuilt trans.all billet Boost,Pyro & Trans. gauges,rear air bags,3.54's, 315/70/16's
liteweight is offline   Reply With Quote
Old 05-26-2011, 01:15 AM   #12 (permalink)
God prefers Diesels's Avatar
How fast is 120km? That's like 27mph, right?
I'm glad we had this talk...
93 Chevy with '97 215 47rh 241DHD HE351cw/bht3b(26cm) Con7x12tagious
Timing in 40 minutes (P7100)
Originally Posted by billow99 View Post
i hate nv 4500s i keep breaking the cluster gear. even with cryo treating. its pointless to expect them to hold up to any abuse.
Originally Posted by randemelissa View Post
You want smoke? throw a rag in your air filter inlet. you want power? we'll help all we can.
God prefers Diesels is offline   Reply With Quote
