Mahle Pistons - Dodge Cummins Diesel Forum
Old 05-01-2011, 03:29 PM   #1 (permalink)
5.9cummins06's Avatar
Mahle Pistons
From what I have read on here the Mahle 286110 pistons are the way to go. Are they a forged piston or aluminum? Im going to be around 1000 hp and probably 4500-5000 RPM....how will they stand up? Should i go forged?
-06 2500 QCSB, EFI, 90HP DDPs, S&B, ArcFlow, 5" Aero Turbine, FTE Resonator, A3K, ATS Billet Trans, FASS 150
-'13 1500 Longhorn, 398HP Hemi, 8 speed, Air Suspension
5.9cummins06 is offline   Reply With Quote
Old 05-01-2011, 04:46 PM   #2 (permalink)
Tech Specialist
You realize forging is a process right? Not a material?
Dual K20s is offline   Reply With Quote
Old 05-01-2011, 05:09 PM   #3 (permalink)
cirvin33's Avatar
iTrader Score: 4 reviews
I beleive they are Forged. And it's cast aluminum or forged aluminum, not forged or aluminum.
96' CCLB-2wd-Transgo TFOD HD-Suncoast Extreme Duty-Revmax Triple-Lockup Switch-4k GSK-60 lb Springs-0 Plate-Modded AFC-Raptor 150 w/1/2" lines-7x.011s-038 DVs-Racked barrels-66/73/.91-Diamond Eye 4" (Mine) Bigblue Comp Cuts on the way!
10' CCSB-2wd-auto-bone stock (wife's)
cirvin33 is offline   Reply With Quote
Old 05-01-2011, 08:01 PM   #4 (permalink)
HBKCummins's Avatar
All forging is is smashing material back into itself. The reason this is usually better than cast parts is simple metallurgy. Cast has breaking and sheer points that the close metal molecules of forging will not. Think about it from the stories you have heard of the powerstrokes that came with forged rods instead of the cast rods in ever other year. My point being I would think and hope they are forged...otherwise they are sure as hell not an upgrade.
1996 Ram 2500 5sp.thuren track bar, WVO system MIA, gauges, 4kgsk, and a big heavy bumper....SOLD
1996 Ram 2500 ext. cab 6sp. showroom new in progress.
HBKCummins is offline   Reply With Quote
Old 05-01-2011, 09:06 PM   #5 (permalink)
yes im aware
Old 05-01-2011, 09:11 PM   #6 (permalink)
Well from what i've been reading on other sites i believe the 286110 Mahles are the Cummins Marine Pistons. Mahle is the OEM manufacturer for Cummins. So I believe these are still a cast piston
Old 05-02-2011, 01:48 AM   #7 (permalink)
HBKCummins's Avatar
Well if you are really wanting to put down 1000hp plus i would stay away from anything cast. Im new to diesels but not new to high powered engines. Why would you want marine pistons?
Old 05-02-2011, 02:09 AM   #8 (permalink)
Cummins35.9's Avatar
Large bowl lower comp
72' F100 Prostreet -- Quest for 15's
Cummins35.9 is offline   Reply With Quote
Old 05-02-2011, 10:09 AM   #9 (permalink)
Id just run coated marine pistons and save some money.
bluegrass1113 is offline   Reply With Quote
Old 05-02-2011, 04:40 PM   #10 (permalink)
Bullrack's Avatar
The Mahle 110's have been doing the deal in 1000hp builds for some time. I don't think you'll have any issues with that piston. I would at least have the tops coated for a little heat insurance. I'm running the Mahle 210's in my 12V which is a great option too, but I'm not shooting for that much hp either. I had my sights set on 800hp tops, but backed it down some to keep it alive while towing. Steven.
2003 F350 CC XLT 4X4 DRW Manual TC, ZF6, 12 Valve Cummins, 60mmGDS-HX35/HT3b Twins, JGS 40mm WG, 5X16 inj.,O-ringed/P&P head with 60# springs, Colt cam, Mahle 210 Pistons, 4K GSK, 20* timing, Valair Kevlar/Ceramic Clutch.
Bullrack is offline   Reply With Quote
Old 05-02-2011, 09:18 PM   #11 (permalink)
The larger bowl design is what you want.
