tuned afc......14mpg at the best.. - Dodge Cummins Diesel Forum
post #1 of 14 (permalink) Old 03-15-2011, 08:10 PM Thread Starter
Hardymanracing's Avatar
How can I pick up fuel mileage
96 3500,nv4500,23*, DFI 5x16, hx52 ,5"exhaust, no plate, afc tuned, rack plug,4k's, valve springs, titanium keepers retainers, studs, fire rings. DD and part time puller
Hardymanracing is offline
post #2 of 14 (permalink) Old 03-15-2011, 08:49 PM
PowerstrokeConvert08's Avatar
get your foot out of it :P
what gears?
Black '97 12 Valver 2WD GONE! Missed but not forgotten
White '05 2WD|NV5600|S-06|Valair Street Triple | the need is high, but the cash is dry...
PowerstrokeConvert08 is offline
post #3 of 14 (permalink) Old 03-15-2011, 09:12 PM
Algae Eater's Avatar
iTrader Score: 7 reviews
No offense, but a thread pretty much like this started a few hours earlier...
Ya may as well go join into that one, because the exact same thing is being discussed.
A twist on the standard MPG question.
Algae Eater is offline
post #4 of 14 (permalink) Old 03-15-2011, 09:34 PM Thread Starter
Here's a twist my fuel mileage has progressively gotten qorse over the last six months.... and I dont srive qny different.3.55 gears
post #5 of 14 (permalink) Old 03-16-2011, 12:51 AM
dieseltech8100's Avatar
Rotated barrels? Did you take your pump in or do this on your own? How many miles on the truck and injectors? Have you checked your timing lately?
2005 Black 3500 QCLB 4x4 Firepunk A/T - Aka: Gettin' Outta Hand 13.6@101.7 *Currently in Pieces*
dieseltech8100 is offline
post #6 of 14 (permalink) Old 03-17-2011, 01:56 PM
PoloCUMMINS97's Avatar
May be wrong, but i think "the all knowing Kronic" ripped the OP one time cuz he messed w/ the barrels/plungers...
97 CCLB 2500 4x4 5spd
PoloCUMMINS97 is offline
post #7 of 14 (permalink) Old 03-17-2011, 02:07 PM
Well as much as it pains me to agree with him, I do... It's not like turning the fuel screw on a ve44 pump. But if I were going to guess, I would say that and timing. I'd think about pulling the pump and having it looked over and re-balanced.
The Following User Says Thank You to dieseltech8100 For This Useful Post:
OrangeP (03-17-2011)
post #8 of 14 (permalink) Old 03-17-2011, 03:27 PM
PVAUTO's Avatar
im only chiming in because my gas mileage had been dropping gradually and last i checked it was 14mpgs. i went to regear my truck tuesday and during inspection i actyually found the shims on the pinion worn out and i had about a inch of play. i had NO noise and the normal slight clunk when appling in gear. i installed some 4.10s and took out my 3.55s and now im def getting better gas mileage.
anyways my point is make sure nothing is creating drag in the driveline.
97' 4x4 12v,transgo vb/3disc TC/built trans,custom plate,modded afc, 4"str8 pipe,ps62,4gsk,21*,omega fuel modded 370,2095,ported manifold,modded air filter set up,synthetic 75w90 all around,gauges,35 on H2's,KORE coils,carli 2.0,4.10,agr gearbox
PVAUTO is offline
post #9 of 14 (permalink) Old 03-17-2011, 03:32 PM
OrangeP's Avatar
anybody take into account winter blend fuel.......
98 12v hand shaker, Mumau diesel, Keystone diesel
Running Mayville WI's best injectors
OrangeP is offline
post #10 of 14 (permalink) Old 03-17-2011, 03:36 PM
^^^^^ Yeah that too...
BTW, PVAUTO- What you do with the 3.54's?
post #11 of 14 (permalink) Old 03-17-2011, 04:22 PM
PVAUTO's Avatar
there just sitting on the bench now. i dont recommend running them if you have bigger tires. trans dont like it and it makes it lug some. pm me if your intrested in buying them
PVAUTO is offline
post #12 of 14 (permalink) Old 03-18-2011, 08:19 AM
OrangeP's Avatar
you should start all your posts with "no offense"
OrangeP is offline
The Following User Says Thank You to OrangeP For This Useful Post:
God prefers Diesels (03-19-2011)
