F350 550 hp build parts for motor. List needs some input
put together this bill. lol list of things I Think i need to make 550hp reliable into my ford build. Please let me know what you think. Please Do not Make this a nasty thread I am looking for advice.
550hp Reliable, built auto, 4x4 f350 crewcab.
1 x 4000 RPM GSK w/ 12 HD valve springs, 94-98 Dodge 12V Cummins
1 x 94-98 Dodge 12 Valve 5.9L Cummins Fluidampr Harmonic Balancer
1 x AFC Spring Kit 94-98 Dodge 5.9L 12 Valve Cummins Diesel
1 x 89-98 Dodge 5.9L 12 Valve Cummins MaxxSpool Billet Chromoly HD Pushrods
1 x 12 Valve Cummins Billet Retainers & Valve Spring Keepers
2 x 94-98 12 Valve Dynomite Diesel 140hp Stage 4 Injectors DDP4
1 x A1 12MM 94-98 Dodge 5.9L 12V Cummins Cylinder Head Stud Kit
1 x 94-98 Dodge 5.9L 12 Valve Cummins w/P7100 Timing Tool Kit
1 x High Flow Laser Cut Delivery Valves, 94-98 Dodge 12V Cummins
1 x 20 Over Marine Head Gasket 1994-1998 12 Valve 5.9L Cummins
1 x 94-98 Dodge 5.9L 12 Valve Cummins Diesel Upper Engine Gasket Kit
1 x Haisley Machine Cast Performance Street Cam 89-98 5.9L 12 Valve Cummins
1 x Dodge 89-98 12V Cummins Quickspool Pulse Exhaust Manifold
1 x High Tech Turbo Sled Puller 66 Stainless 89-07 Dodge 5.9L Cummins
1 x 94-02 Dodge 5.9L Cummins ARP Flexplate Bolt Kit 147-2901
1 x 94-98 Dodge 5.9L Cummins Oil Pan
1 x 5.9L 24 Valve Cummins 6BT Diesel Oil Pump 89-02 Cummins
1 x 89-91 & 98.5-02 Dodge 24 Valve Cummins ATI Super Damper Harmonic Balancer
1995 f350 cummins ppump
1997 f350 powerfulljoke
1992 fsuperduty cummins 5speed dump ve pump
1989 f450 tow rig cummins in the making
1970 javelin 360 4 speed
1 x 94-98 Dodge 12 Valve 5.9L Cummins Fluidampr Harmonic Balancer Not needed
1 x 89-98 Dodge 5.9L 12 Valve Cummins MaxxSpool Billet Chromoly HD PushrodsNot needed
1 x 12 Valve Cummins Billet Retainers & Valve Spring KeepersNot needed but wont hurt
2 x 94-98 12 Valve Dynomite Diesel 140hp Stage 4 Injectors DDP4Its easy to find better injectors for cheaper
1 x High Flow Laser Cut Delivery Valves, 94-98 Dodge 12V CumminsFind a better DV
1 x 20 Over Marine Head Gasket 1994-1998 12 Valve 5.9L CumminsStock thinkness will work fine
1 x Haisley Machine Cast Performance Street Cam 89-98 5.9L 12 Valve CumminsNot needed
1 x Dodge 89-98 12V Cummins Quickspool Pulse Exhaust ManifoldNot needed
1 x High Tech Turbo Sled Puller 66 Stainless 89-07 Dodge 5.9L CumminsGet a 64/71/14
1 x 5.9L 24 Valve Cummins 6BT Diesel Oil Pump 89-02 CumminsWhy?
1 x 89-91 & 98.5-02 Dodge 24 Valve Cummins ATI Super Damper Harmonic BalancerNot needed
Fixed it for ya.
94 F350 12v it started as a test unit for fuel system parts, baselining at 451/1083... now its a full blown 2.6 truck with some bada$$ names on the side of it.
I agree with not needing the cam but i think that it wouldnt hurt any thing. i think that i would go with a helix 2 or helix 3. You wont heed fly cut pistons and your getting valve springs. I will help spool faster and lower egts.
94 Dodge 1500 2wd powered by a 2005 Cummins 3.9 4BTAA 27mpg 95 Dodge 2500 4x4 boost elbow (35psi) #10 fuel plate 99 2500 4x4 edge juice with attitude http://www.cumminsforum.com/forum/cu...ics-truck.html
The 24v oil pumps flow higher psi. and volume. Again, why?
What are the better then ddp injectors, and delivery valves.Pretty much anything.
