97 12v Boost Pressure - Dodge Cummins Diesel Forum
post #1 of 8 (permalink) Old 11-07-2007, 04:52 PM Thread Starter
smokeshow's Avatar
I have a friend who has a 97 cummins with a custom fuel plate, bigger injectors and an HX40. The wastegate limits the boost to about 25psi. How can he get the full boost potential of the HX40? Any tricks?
96 12v Dually
smokeshow is offline
post #2 of 8 (permalink) Old 11-07-2007, 04:57 PM
Whistler's Avatar
You need a boost elbow. This will "lie" to the wastegate and let you build more boost. Found one, click here eBay Motors: DODGE CUMMINS TURBO, TURBOCHARGER ADJUST BOOST ELBOW (item 120180879615 end time Nov-16-07 13:38:01 PST) :thumbsup
This will fix you right up.
97 3500 4x4 Ext. cab, Goerend Tranny & TC, 15* timing, #10 plate full forward, autometer gauges, lock up switch, prime loc, Amsoil Nano, straight piped, posi-lok, lots to come
Whistler is offline
post #3 of 8 (permalink) Old 11-07-2007, 05:21 PM
Banned
You can probably take the wastegate actuator and rod off. Rod should be threaded, shorten the rod, and that should do it. Threaded part could be pinned, drill the pins out and then you should be able to turn it.
zstroken is offline
post #4 of 8 (permalink) Old 11-07-2007, 06:51 PM
follow the boost line off of the turbo and when it crosses under the aluminum valve cover and turns to a rubber line for about 4 inches you can pinch the line off with a hose clamp and ive set mine to about 45 psi with stock everything on turbo.
dieseldaddy is offline
post #5 of 8 (permalink) Old 11-07-2007, 07:03 PM
get a quality adjustable wastegate, then you can tailor your boost pressure to the highest efficiency zone so you keep the temps cool and the power high.
DRFTR is offline
post #6 of 8 (permalink) Old 11-07-2007, 07:18 PM
b.lee's Avatar
x2 on the boost elbow.
i went from 24 to 36 psi for $40 shipped.
cheap and works great.
super easy to install,
just make sure the trucks cold.
it dropped my egts the most, and was the cheapest mod I did. :thumbsup
06 2500 Cummins - Mega, Auto, Smarty S06, Edge CTS
04 3500 Cummins - Built Auto, TCS TC, 5" Exh
b.lee is offline
post #7 of 8 (permalink) Old 11-07-2007, 07:44 PM
Monster Truck's Avatar
Theres a boost elbow on ebay express for 20 bucks to your door right now.
94 Single Cab Custom Flat bed, Loaded, Auto,3.55s, straight 3.5'' pipe, custom fuel plate AFC all the way forward, Intake, 250k, New build lots to be done.
Monster Truck is offline
post #8 of 8 (permalink) Old 11-14-2007, 02:50 PM Thread Starter
smokeshow's Avatar
Thanks guys that will get me started.
96 12v Dually
