waste gate? - Dodge Cummins Diesel Forum
post #1 of 14 (permalink) Old 10-01-2007, 02:35 AM Thread Starter
cummins96's Avatar
waste gate?
quick question i've bee reading about disabling ur waste gate to get more power etc,is there any consequences when doing this?
cummins96 is offline
post #2 of 14 (permalink) Old 10-01-2007, 09:28 PM
AlGores worst nightmare
Racer9's Avatar
You can get very high egt's, if not careful. If you have an egt gauge, and you keep it below 1350*, you'll be OK.
Gauges are important before any mods.
'96 2500, CTD, 4X4 flatbed, Isspro gauges, Skyjacker D-25's, ThurenFab track bar, DSS, HD steering.
Motor; BHAF, #100 fuel plate, 5X.012 90hp injectors, Pacbrake 4kGSK, Loose starwheel. 306hp/743tq before injectors.
Exhaust; Schwitzer S300G, 4" downpipe, single 5" turnout stack.
Trans; Dunrite VB/TC, Intelligent Engineering billet input shaft, Burt Brown rebuild/upgrade.
Racer9 is offline
post #3 of 14 (permalink) Old 10-01-2007, 10:02 PM
Plowboydually's Avatar
I would think that you could blow a head gasket.
2003 4door, auto, ho motor 83,000 and counting
1999 ext. cab dually Sold!! OHIO COAL ROLLERS
1992 reg. cab, auto, Bone stock w/ 325,000 miles
Plowboydually is offline
post #4 of 14 (permalink) Old 10-01-2007, 10:47 PM
Cumminsboy's Avatar
I dont know what u mean by disabling it but u can plug it. If u want to there a little rubber hose that goes from ur wastgate to the turbo. You take the hose off the turbo not the wastgate. There will be a little elbow u just take it off that. Leave the hose attached to the wastgate. Take a bolt (not sure wat size youll just have to play around with it) and stick it in the end of the hose make sure the bolt is real tight then take a hose clamp and clamp it around the bolt so it wont blow out and for a little more insurance. I havent done it to mine yet but i would take the elbow out and put a pipe plug or somthing like that in it and youll be set u dont have to do that but im going to whenever i get time. I almost make around 50Lbs of boost all i have is an ICEBOX, 100hp injectors, and an edge comp. you arnt gonna gain alot of boost but a little bit enough to be noticable. I learned this from a friend that went to diesel school so im sure its okay cause he knows what hes talkin about.
I would recommend gauges though u dont have to it helps to know what going on. I dont know how high ur egts will go but I know the other day i put my foot in it and didnt look at the egt gauge and it read 1500. But i left my foot in it for a long time.
DO IT YOULL LOVE THAT LITTLE EXTRA BOOST!!
2007 Chevy 2500 LT3 Edge juice, 4in exhaust, Rancho 4in lift, 20in Black KMC Armour with 305 nitto terra grapplers
Cumminsboy is offline
post #5 of 14 (permalink) Old 10-01-2007, 11:15 PM
Cummins5SPD's Avatar
DO NOT DO THIS I did it lowered my EGT's and gave me more power but in the end i ate 5 turbos in like 4 months. You will overspin the HX35 and the shaft will break, trust me i went through 4 of them. If you want to do anything splice a T fitting into the wastegate line so the wastegate wont open all the way. I have a 24Valve turbo and it has a different wastegate setup no line from the injection pump for it. I see 30lbs of boost and thats a safe place for stock head bolts.
1999 QuadCab ShortBed Sport, NV5600, Studded, BD High HP VP44, Fass 150, Edge Hot Comp, South Bend Dual Disk, 8" Turnouts
Cummins5SPD is offline
post #6 of 14 (permalink) Old 10-02-2007, 10:28 AM
My wastegate is blocked off and I hit 34PSI MAX. No problems with over 20K put on the truck by me.
1996 12valve, Auto, single cab, 2in pucks in front, rollin on 305's. BHAF, straight piped. EGT, Boost, and Tranny temp guages.
HELL NO IT AINT GOT A HEMI!
mavrik4x4 is offline
post #7 of 14 (permalink) Old 10-02-2007, 11:03 AM
dodge359's Avatar
At that psi you are fine. When I blocked mine I could get almost 50psi out of the poor little guy. Funny thing is it didnt pop until I put the 40 on then bye bye headgasket.
1997 3500 Studs, Fire rings, Twin Ram Intake, Stage 2 W/M, NX 2 stage, 4k kit, 40/3B, Custom fuel plate, 4" Stacks, 13" FE clutch, 191 DVs.
Nitrous, its the little blue pill for diesels.
dodge359 is offline
post #8 of 14 (permalink) Old 10-02-2007, 11:20 AM
I was pushin 42 out of the stock turbo, I have 4.10 gears and it seemed like if I was rippin a little bit and i let off the compressor side would try and stop and would spin the shaft right off at the journal bearing on the exhaust side. I talked to shied diesel and they said that was the only thing they could think of. My buddy who owns a shop has disabled alot of wastegates on his customers trucks and I was the only 1 that had serious turbo problems, some guys did pop headgaskets or stretch the stock head bolts. Finally i put an HX35w off of an 01 on it and left the wastegate hooked up and no more problems. I blew 3 HX35W's and 1 H1C with a 18 housing.
post #9 of 14 (permalink) Old 10-02-2007, 11:43 AM
Yeah, every situation seems different, however, the one thing that is UNDENIEABLE by anyone is the necessity for guages. If you stay under 35PSI with a stock turbo, all should be fine.
DISCLAIMER:::::::::::::::::::::::::::::::::::::::: ::::::::::::::::::::::::::::::::::::::::::::::::::
THIS OFFER NOT APPLICABLE TO ALL ASSOCIATED MEMBERS OF THIS BOARD. ANY MISREPRESNTATION, REPRODUCTION, OR BROADCAST OF THIS STATEMENT USED IN AN ATTEMPT TO DEFRAUD, IMPLICATE, OR OTHERWISE ALTER THE ORIGINAL STATEMENT, IS PROHIBITED AND PUNISHABLE BY THE APPLICABLE LAWS IN THE ORIGIN OF VIOLATOR'S STATEMENT. NOT RECCOMENDED FOR USE BY THOSE LACKING THE PROPER MECHANICAL SKILLS, MONITORING DEVICES, OR LIFE SKILLS, COMMONLY ASSOCIATED WITH COMMON FKN SENSE. THOSE WITH QUESTIONABLE INTELLIGANCE, NEED NOT APPLY.
post #10 of 14 (permalink) Old 10-02-2007, 09:01 PM
dodge359's Avatar
That disclaimer is great!!
dodge359 is offline
post #11 of 14 (permalink) Old 10-03-2007, 10:35 PM
Cumminsboy's Avatar
I have an 02 thats the difference. But the guy that owned it before me did it and he had it plugged for over 40000 miles and never had any problems. I love it.
post #12 of 14 (permalink) Old 10-09-2007, 01:21 AM
Roosten450's Avatar
I just took a set of vise grips and clamped the soft line right (by the head) and then drove it (hammered on it) and then take the grips off hammered on it again, and i did not notice anything... What is this mod spouse to do? and should i do it different
1984 crewcab K30 4x4 - 12V 5 speed
2003 Dodge 3500 Dually 6 speed 4wd
1999 Dodge 3500 Daully 5 speed 4wd
Roosten450 is offline
