12 valve exhaust brake 5 speed - Dodge Cummins Diesel Forum
post #1 of 5 (permalink) Old 09-06-2010, 11:54 AM Thread Starter
I have a 98 12 valve with a 5 speed and need an exhaust brake but would like to know what one is best for my particular truck. Help is appreciated.
ssmitch is offline
post #2 of 5 (permalink) Old 09-06-2010, 01:22 PM
I have a BD but the pac-breaks are the best IMO
To many mods to list just ask.
Cummins-Guy is offline
The Following User Says Thank You to Cummins-Guy For This Useful Post:
ssmitch (12-11-2010)
post #3 of 5 (permalink) Old 09-07-2010, 12:20 AM
Armchair Mechanic
colin91's Avatar
I have a vacuum operated Pacbrake right now and it works great. Looking to get the new PacBrake PRXB which is air operated. my buddy has one and its in, just a little expensive
1996 2500 ECLB, NV4500, 4X4 (24 valve P Pump swap in progess)
Engine: Crowler Springs, Adj. Timing Gear at 21*, Haisley H11s, ARP Rod Bolts, DIY O-Ringed Block, DAP 3 Piece Manifold, Fluidampr, Southbend DD3250, 5" Turbo Back Exhaust + FTE Resonator
Air: S363XE (63/68/.8) + The Ol' Trusty BHAF
Fuel: 215HP P7100, Infinite Performance 6x11 VCO, Scheid Conversion Lines, PDD 055 DVs, AirDog, Dual Feed, AFC Live Stage 1, 4K GSK
Suspension (So Far): Thuren 3" Coils, Thuren Torsion Sway Bar, Thuren Track Bar, DOR Shackle Flip, DOR Extreme Bent Long Arms, Fox 2.0 IFPs, 35s on H2s
colin91 is offline
The Following User Says Thank You to colin91 For This Useful Post:
post #4 of 5 (permalink) Old 09-07-2010, 12:33 AM
yes they are - but worth every penny if u tow heavy (n even if u dont)
*the i.d. is not what they advertise so i dont know how concerned u r with flow but if u hav spent anywheres near as much as i have on ur ex sys then u will want to order one size over and hav pac send the correct reducers to make it work
iow if you have a 4" ex sys make sure u order the 5" prxb
the 4" brake aint 3.5" on the i.d.
Mississippi is offline
The Following User Says Thank You to Mississippi For This Useful Post:
post #5 of 5 (permalink) Old 09-07-2010, 05:47 AM
Just dont buy the stock style one from Pac brake. All the ones listed for your application replace the back of your turbo. At some point you will want to upgrade turbos and your exhaust brake will no longer work unless you run a HX35/40 hybrid. Either upgrade to an HX40 flanged turbo now or do what was mentioned earlier and buy one that mounts in the exhaust pipe. Only drawback is this style will take a little longer to generate back presure but will allow you to go with any turbo you like later on.
08 5500 4x4 G56 4.44s, SB 3250 dual disc, XRT... Spicer 7041 Aux trans.
95 2500 4x4 G56 180 pump, injectors, 362/475 twins and more....
burnin oil is offline
The Following User Says Thank You to burnin oil For This Useful Post:
