DIY twins with a hx35 - Dodge Cummins Diesel Forum
post #1 of 20 (permalink) Old 06-26-2010, 10:27 PM Thread Starter
Casper's Avatar
I have thought about doing a set of diy twins. I want to know what turbo u guys suggest as a bottom turbo if i use my current hx35 with 12cm wastegated housing? also would should i get rid of the wastegated housing on the hx 35?
95 F250 12V 215 P-pump, 62/65/12, SDX5x12's, kdp done, afc spring kit+tuning, 100plate, 16*timing, 60lb int/exh springs, ats exh housing, 4k gsk, sbc zf5, dana 60 kp swap, 4"exh, 2 tank plantdrive wvo kit.
Casper is offline
The Following User Says Thank You to Casper For This Useful Post:
5.9 guy (11-27-2011)
post #2 of 20 (permalink) Old 06-26-2010, 10:33 PM
ykdave's Avatar
ditching the 12cm gated housing for something larger is definitely going to be beneficial when trying to light a larger turbo behind it.
Depending on your goals and how you want the thing to drive, its not uncommon to see a set of small twins like a 35 and a 50/55
ykdave is offline
post #3 of 20 (permalink) Old 06-26-2010, 10:42 PM Thread Starter
Casper's Avatar
what is 50/55?
Casper is offline
post #4 of 20 (permalink) Old 06-26-2010, 11:13 PM
ykdave's Avatar
hx50 or hx55
ykdave is offline
post #5 of 20 (permalink) Old 06-26-2010, 11:40 PM
TURBOLVR's Avatar
iTrader Score: 8 reviews
what are you using the truck for? the 35 as a small turbo in twins will limit you to 600hp but is good for a driver/tow rig.
being this is for a ford, do you have any experience with building twins in a ford? most twin kits are for Dodge's and wont usually fit. I ask because configuration may be a determining factor in turbo choices available as some are designed and rotate in opposite direction from others. Also some turbos (like S400's and HT3B's) are more common and easier to find parts for building twins.
'98.5 RAM 4x4 QC 12v, CRAZY CARL'S Whipple supercharger, Carl's SS SXE 64/GT55 twins, 13mm P7100,TUNNEL RAM intake plate, Hamilton head/valvetrain, , full 5" DUALS, BILLET AUTO
TURBOLVR is offline
post #6 of 20 (permalink) Old 06-27-2010, 08:12 AM
Yah, but if you look, he's got a 12valve in that ford.....
-Matt -- yah, I do this for a living....
1995 Chevy C1500 - Cummins in progress; 1988 Chevy 3500 Cummins Conversion; 1984 Mercedes-Benz 300SD; 1950 Chevy 2 ton - Future 6BT Toy
deerefanatic is offline
post #7 of 20 (permalink) Old 06-27-2010, 09:26 AM Thread Starter
Casper's Avatar
i want a good driver/tow rig. I dont have any experience with twins but i'm sure i can hammer my way thru like i did the 12V swap into my ford. I'm also trying to do this on the cheap so if i use my current turbo then i would save a bunch.
Casper is offline
post #8 of 20 (permalink) Old 06-27-2010, 10:29 AM
TURBOLVR's Avatar
On the cheap, you'll need to remove the HX35 and enlarge the WG passage and drill through the scroll divider to gate all 6 cylinders.
If you have an elbow on the back of the 35, you will need a different backing plate to make a hot pipe.
with a 12v, chances are, you have only one drain in the block. So you will need to put another in the pan for the big turbo.
The 3B is often cheaper to acquire and use then the S4. The BHT3B (garrett) model is the better of them. a 76 comp inducer and 26cm (you can go smaller like 23cm but bigger will add lag) ex. housing is what most use for the best street performance.
Be aware the 3B uses a T6i NOT a normal T6 flange, you can alter a T6 to work if you need to.
These turbos have a 5" exhaust outlet, you can step the pipe down to 4" right off the outlet if need be though.
I would search the conversion forum for other fummins w/twins to see pics and talk of what they did so you have a good grasp before diving in.
TURBOLVR is offline
The Following User Says Thank You to TURBOLVR For This Useful Post:
Casper (06-27-2010)
post #9 of 20 (permalink) Old 06-27-2010, 12:34 PM
Got Smoke?'s Avatar
Any pictures of this?
'97 2500 retired puller...currently getting 47RE FMVB swap
'07.5 Mega 6.7L 68RFE FirePunk tuned
'03 VW Jetta Wagon .205 nozzles, Colt Stage 2, studs, Malone Stage 3
Got Smoke? is offline
post #10 of 20 (permalink) Old 06-28-2010, 01:55 PM
Banned
i have some info for you if you want this is the truck i did
finished my twins and i love them - Competition Diesel.Com - Bringing The BEST Together
this is the truck i built for myself its a hx35 over an ht3b give me a call if you want more info the name is trevor im up in canada but am willing to help you or any one else out 1-204-572-5244
fordcummins1992 is offline
post #11 of 20 (permalink) Old 06-28-2010, 02:18 PM
TURBOLVR's Avatar
found one here too:
PA060171 pictures from trucks photos on webshots
TURBOLVR is offline
Casper (06-28-2010)
post #12 of 20 (permalink) Old 06-28-2010, 09:17 PM Thread Starter
Casper's Avatar
thanx man for the future help. where abouts in canada are u? also what have u done to the motor? i want to know how close performance wise our motors are.
Casper is offline
JDMath (07-31-2015)
