You wont be able to spool the 62, my brother had DDP 90's with no plate and 4k's , afc tuned, and full cuts and he couldnt lite it to save his a$$, not to shoot you down but i just dont want you to buy something you cant light, and if you do I would say do a s300 there cheaper than most and are a good turbo
94 2500,5 speed, southbend clutch,S&B intake,4" exhaust, No plate, SDX dv's,Bosch 370's, autometer boost,pyro, 4K GS, 60Lb VS, Air Dog 150, Tork Tek 060 OFV.
Your brother should have been able to spool a 62mm with those mods, but a 57mm would have been better.
Hicks12v What do you want to do with the truck? I can get you a s300g with a 12cm housing instead of a 14cm. It will spool 50rpm faster or so, but will get hotter up top. an hx35/40 may also work for you, but for not much more you can get a better turbo, the s300.
I thought he would of been able to but apparently i was wrong
sounds like there was something wrong with the truck or turbo, he should have been able to make about 450 if he was tuned right, was it a very low drive pressure turbine wheel like the 74 or even the 71mm?
