what psi should u get head studs? - Dodge Cummins Diesel Forum
Old 06-11-2010, 06:20 PM   #1 (permalink)
Casper's Avatar
what psi should u start thinking about getting head studs? I used the search function and didnt get answer.
95 F250 12V 215 P-pump, 62/65/12, SDX5x12's, kdp done, afc spring kit+tuning, 100plate, 16*timing, 60lb int/exh springs, ats exh housing, 4k gsk, sbc zf5, dana 60 kp swap, 4"exh, 2 tank plantdrive wvo kit.
Casper is offline   Reply With Quote
Old 06-11-2010, 07:04 PM   #2 (permalink)
No certain level. Boost doesn't kill headgaskets. Drive pressure does.
There are some VERY hot trucks running stock bolts.
97 4x4 extended cab
Valair Inc clutch
displacedtexan is offline   Reply With Quote
Old 06-11-2010, 07:39 PM   #3 (permalink)
usmcdbd's Avatar
Most say when you reach 40-45 psi but displacedtexan is right is tuned right you can run way more than that
6 Dodge 2500 2 wheel drive 6 speed 5'' fbd, BDTD CL, DR. Performance stage III, afe 2, Isspro Boost, Fuel, EGT. DD3600 from south bend, and air dog 150 505hp 1020tq since i ditched the Smarty.For Sale
usmcdbd is offline   Reply With Quote
Old 06-11-2010, 10:40 PM   #4 (permalink)
ThatStevensKid11's Avatar
My boss is pushing over 50psi at times with stock bolts but his head is fire ringed to keep the pressure in the cylinder better and not blowing the gasket.
1997 RCLB SLT Laramie, 4" Straight Pipe, KnN Air Filter,ARP Headstuds, NV4500 swap with Kenny's Pulling Clutch, now just need some gauges and let the power start accumulating. Some go fast parts laying on the bench just waiting to be put to use
ThatStevensKid11 is offline   Reply With Quote
Old 06-12-2010, 10:45 AM   #5 (permalink)
Banned
letting your truck warm up before beating on it is a key factor as well.... drive pressure is a huge one, but drive pressure and back pressure are a cause/effect relationship, so opening up your exhaust prior to the turbo can help (gasket matching)
most guys say 40psi ish on stock bolts....
some guys say retorque headbolts.....
the HG in my truck was toasted when i bought it.... and after doing the head/swap gasket after fighting with it for a year, i shoulda just threw a new gasket in right away... it really is NOT that hard.
some guys get 50/60/70 psi or more on stock bolts....
i'd say driving habits, timing, egt's and turbo setup will dictate how far you can go...
Kronic_187 is offline   Reply With Quote
Old 06-14-2010, 02:11 PM   #6 (permalink)
Toxic Diesel
murphy41's Avatar
I ran a 471 at 55+psi no problems on stock bolts, but drives were 64:55 so pretty low. Then gave her a healthy shot of a 200hp shot of spray... and boom she blew the hg.
murphy41 is offline   Reply With Quote
