Afc washer details, pics? - Dodge Cummins Diesel Forum
post #1 of 10 (permalink) Old 04-17-2010, 05:44 AM Thread Starter
flubyux2's Avatar
Ok, well I'm trying to get a set of 370s and the 0.020" sealing washers (or thinner if possible). I think I'm goin to yank my plate and let my afc be my full load rack stop. I'm wanting more details on the afc washers. I'm going to grind, not flip. But I'm just curious what the washers look like and What to expect before I pull it apart.
I'm also going to grind the barrel of the afc foot too. And then whatever else gets in the way. I thnk I might leave my stock rack plug in cuz swapping out to a Mack plug just might be too much fuel on a stock hx35... But if anyone has some good pics of the washers and some info, hook me up!
I want to move on past the Basic Performance Upgrades!
truck #5
2001.5 3500 Laramie, qclb, 4wd, drw auto, goose, AirRaid
flubyux2 is offline
post #2 of 10 (permalink) Old 04-17-2010, 06:06 AM
farmtwin's Avatar
Go here afc mods (lots of pics) - DieselRam.com it has a lot of useful information and pictures
2006 Mega 6sp mostly stock for now...
farmtwin is offline
The Following User Says Thank You to farmtwin For This Useful Post:
Spinner (04-18-2010)
post #3 of 10 (permalink) Old 04-17-2010, 09:26 AM
YOUNG GUNS15's Avatar
just take it apart..... its soooo simple once you do it.
94 12 valve- 12.55 @ 111mph
05 12 valve QCSB 3rd gen - 12 rail -
YOUNG GUNS15 is offline
post #4 of 10 (permalink) Old 04-17-2010, 11:14 AM
bulldog77's Avatar
iTrader Score: 5 reviews
Took 5 min once the afc was off. Put in a fender washers im place of fender washers. adjusted pre boost screw to where it justs touches the diaphram.
None of your damn buisness of whats done to my truck.
bulldog77 is offline
post #5 of 10 (permalink) Old 04-17-2010, 11:20 AM
bulldog77's Avatar
Heres a pic of the afc with flat washers inplace of the cup washer on the spring side of the afc. Hope this helps
post #6 of 10 (permalink) Old 04-17-2010, 04:39 PM Thread Starter
flubyux2's Avatar
Thais guys. I did read about fender washers too as an option. I looked this picture over real hard bu I couldn't figure out what part to grind on the washer. I couldn't see where the flanged cup part was. Makes more sense now that you mentioned it is alreay a flat washer.
I'm gonna tear into it as soon as I can bring the truck home. I haven't been driving it since it's for sale but I just sold one of my other cars so maybe I'll play with it more.
truck #5
flubyux2 is offline
post #7 of 10 (permalink) Old 04-17-2010, 04:55 PM
Big Deezul's Avatar
dont grind the foot on your afc...you can get more then enough pre-boost fuel for a stock turbo with your starwheel. Just grind the barrel end.
you can also just swap the washer positions...no need for a new one
97 club cab 4x4
Big Deezul is offline
post #8 of 10 (permalink) Old 04-17-2010, 04:59 PM Thread Starter
flubyux2's Avatar
No, I'm not gonna grind the foot. I can adjus the smoke screw and it'll do the same job. I'm def gonna grind the barrel on the foot. I'm not gonna swap/flip the washers cuz it'll prevent the afc foot from returning fully to it's rest position. So it won't be able to control preboost fuel like stock.
truck #5
flubyux2 is offline
post #9 of 10 (permalink) Old 04-17-2010, 11:57 PM
rollin coal 23's Avatar
iTrader Score: 6 reviews
just go to the hardware store and get two washers with 8mm hole in it and do it right. for only a few cents there is no reason to do it any other way.
this mod is super easy. and you will gain noticeable power from it so just dig in and get er done. let us know how it goes.
1997 eclb 2500 4x4. Built auto.dtt tripple disc.billet input.
hx35/s475 twins.A1 studs. 5x.012's. 191's .#10 fuel plate. Pump tuning Modified Ofv. Over all boost,primary boost,egt,trans temp.
rollin coal 23 is offline
post #10 of 10 (permalink) Old 04-18-2010, 12:18 AM Thread Starter
flubyux2's Avatar
Definitly! As soon as I can bring the truck back to the house, I'm gonna go thru it. I hope the deal on these new 370s goes thru as well. I was this [....] close to having 20x10" billet rims on my truck, with 34x12.50s too! But the center bore doesn't clear fullfloater axles I'm havin too much fun with this!
truck #5
flubyux2 is offline
