exhaust brake questions - Dodge Cummins Diesel Forum
Old 02-14-2010, 02:52 PM   #1 (permalink)
I installed a pacbrake and for some reason it is shutting my truck off when I shift. Any answers? Thank you
98 diesel long bed ext cab welding rig, 4wd (Posi lock cable), 5 speed containing 450 southbend clutch, pyro, boost and tranny gauges, BHAF, 5 in straight, #10 fuel plate,super b turbo, 90 hp injectors, tuned pump, exhaust brake
Geostan Duffin is offline   Reply With Quote
Old 02-14-2010, 03:43 PM   #2 (permalink)
Super Moderator
Maybe your idle is too low and the restriction is more than the engine can fight.
12 Valve Idle Adjustment
Bill
'95 2500 4wd auto
'95 3500 5 speed heavy hauler
Stock for one day
Old 02-16-2010, 02:55 AM   #3 (permalink)
colin91's Avatar
leaving it on between shifts can cause it to drop the rpms to low and kill the motor. will it kill the motor if you turn it on parked with the engine idling?
i was taught to turn it off between shifts while downshifting.
1996 2500 ECLB, NV4500, 4X4, HTT 62/71/14, SDX 5x14s, #0 plate, 20*, 4K GSK, ARP studs, Snow water/meth, SouthBend, 5" EXH, AFC tweaked, Icebox, ATS 3pc, PacBrake PRXB, Isspro gauges, Thuren track bar, KDP victim, more to come
colin91 is offline   Reply With Quote
Old 02-16-2010, 12:59 PM   #4 (permalink)
Super Moderator
I usually give a little throttle while downshifting to match rpms better, brake turns off automatically.
But when up shifting there is usually no reason to have the brake on.
Bill
'95 2500 4wd auto
Stock for one day
Old 02-16-2010, 09:40 PM   #5 (permalink)
.I turned up the idle today and all the problems are fixed and I love the brake, it really helps. I haul a lot of weight and all the time. I do have one question though. I have a 10 gal air tank on the truck and I want to tie the compressor that runs the exhaust brake into the 10 gal tank but I am afraid that it will cause the compressor to run too long and burn it up. If I tied it in will it be ok? The compressor is a 285 Viair.
Old 02-17-2010, 11:46 AM   #6 (permalink)
Super Moderator
The exhaust brake uses very little air, I wouldn't worry about it.
Bill
'95 2500 4wd auto
Stock for one day
