Possible to switch pumps? - Dodge Cummins Diesel Forum
Old 02-10-2010, 12:24 AM   #1 (permalink)
I have the 94 in my sig and the injection pump is startin to give out on me. My question is can I put a 180 or 215 pump in its place? i got the 160 pump now and figure they are all relatively the same price from what i've seen, so why not upgrade right? haha And whats all involved in doing this? Thanks guys- Andrew.
1994 CTD 4x4: 4" full exhaust Auto 370's 16 timing built injection pump #6 plate 3000gsk levelin kit 36's
mightywhitey5269 is offline   Reply With Quote
Old 02-10-2010, 12:26 AM   #2 (permalink)
superdutycummins's Avatar
It will bolt right up. There might be a different core charge if you are buying a 215 pump with a 160 core.
2001 FORD F-550 4x4 Crew Cab Cummins project truck.
2006 FORD F-350 6.0 auto Service Truck 4" exhaust, SCT tuned. 250 gallon fuel, Welder, air compressor, and all necessary tools to keep a 5k acre farm and construction company up and running -going back to a flatbed
2004 Ford F-550 6.0, zf-6, 11' Knapheide utility bed. NEW SERVICE TRUCK
superdutycummins is offline   Reply With Quote
Old 02-10-2010, 07:09 AM   #3 (permalink)
Ok thanks that was what I needed to know. Would anyone happen to know where I can get either a 180 or 215 pump for cheap?
Old 02-10-2010, 08:43 AM   #4 (permalink)
bh10's Avatar
Just send it in to a pump shop, it will be cheaper than buying a new (used) pump, in most cases.
04-not fast
95- fast
bh10 is offline   Reply With Quote
Old 02-10-2010, 02:45 PM   #5 (permalink)
OrangeP's Avatar
dont forget 215 injectors, the 215 has bigger dv's as well
98 12v hand shaker, Mumau diesel, Keystone diesel
Running Mayville WI's best injectors
OrangeP is offline   Reply With Quote
Old 02-10-2010, 02:51 PM   #6 (permalink)
CATSTACKS's Avatar
i would get a 180 pump... 215s start retarding timing over 2500rpm
which is fine unless you plan on a gsk... then you wont get your max performance from the 215... but if your goin for power your more than likely gonna get bigger dv's so who cares what a stock pump has an i right?
95 F-350 body swap on a 97 2500 12v, p-pump, 64/71/14, nv5600, 4x4,
01 2500 24v, auto, 4x4, intake, 5", airdog150, QUAD ADR V2, DAP 100s, 60/60 VGT, leveled 20s 33s
CATSTACKS is offline   Reply With Quote
Old 02-10-2010, 04:16 PM   #7 (permalink)
Tech Specialist
Wrong. I would love to hear how you think this works though, I'm listening....
The timing retarding from the upper helix on the plungers happens in relation to rack travel and rack travel only.
98 Dodge 2500 12 valve, 5-speed, 4x4
Dual K20s is offline   Reply With Quote
Old 02-10-2010, 08:05 PM   #8 (permalink)
CATSTACKS's Avatar
in relation to rack travel? about 2500rpm worth of rack travel? is when you start feeling it noticeably... im not talking about lugging it either im talking cruising throttle...
Old 02-10-2010, 08:34 PM   #9 (permalink)
cbtoyz's Avatar
On a 215 pump, they have a helix on the top of the plungers that retards the timing the more rack travel you get. Your problem must be a governor issue. Try a 4K kit.
Colin. '96 2wd 12valve= 10.99 @ 126mph.
Ponci's Diesel Center, Goerend Transmissions, Hamilton Cams, Dynomite Diesel Performance.
cbtoyz is offline   Reply With Quote
Old 02-10-2010, 09:27 PM   #10 (permalink)
OrangeP's Avatar
ive heard the 215 will retard at 2800 or 2900, sure feels like it retards sooner like catstacks says
Old 02-10-2010, 10:26 PM   #11 (permalink)
CATSTACKS's Avatar
if your talking about me, i dont have a 215... my truck never had one and its not from cali either...
Old 02-10-2010, 11:22 PM   #12 (permalink)
ykdave's Avatar
CATSTACKS, please do some reading up on the P7100 and RQVK gov before spitting out incorrect information!
rack travel is not directly related to rpms...
As stated above, the retard notched plungers (in the 215hp pumps) reduce timing in relation to the rack travel. Thus depending on your setup you could hit full rack travel just off idle and carry it all the way to defueling. Or.... because of the joys of a lean burn engine, you could spin the engine up to 3100rpm (appx full defuel for stock gov) with nothing more than a few mm of rack travel.
What you are 'feeling' around 2500rpm is the stock gov setup. The stock setup starts pulling fuel in the mid 2k's (slightly different depending on year/pump)
2007 Laramie 3500, 4.5" RevTek, 35x12.5 ProComp MTRs, buckstop front+rear, bullydog TD, BD RFI intake, Lightforce 140s in the bumper, 240HIDs up top
1997 SLT 2500, 5.5" fabtech, 36x13.5 IROKs, 5x12s, s300, 4kgsk, inj pump FUBAR
ykdave is offline   Reply With Quote
The Following User Says Thank You to ykdave For This Useful Post:
CATSTACKS (02-11-2010)
