Old 11-21-2009, 05:48 PM   #1 (permalink)
Cummins_12's Avatar
Question Injectors
I'm looking at getting some injectors for my truck. Here's what i want. i want something that will give me a good power increase but not put my EGT's threw the roof. I'm looking at the SDX injectors but i'm unsure what size to get.
1998 Dodge Ram 2500 12 Valve Cummins Turbo Diesel. Banks Git Kit, K&N intake, 0 Fuel plate, 6" Mitre cut stacks
Cummins_12 is offline   Reply With Quote
Old 11-21-2009, 06:00 PM   #2 (permalink)
estrada5.9's Avatar
Didn't notice a aftermarket turbo in your sig, Depending on what you want to do later with your pickup I would go with 5 x.012's which are approx. 90hp so you have some growing room. Egts will get hot but that is what your right foot is for.
O and welcome
1997, 2500, 4x4, ext. cab, long bed, 5spd, 240000, valair clutch,new NV4500 with updated fifth, 3.54's,4 GSK,DDP 3's,Timing 16.5*, II pump 480cc,35 over 3B, o-ringed and 12mm studs, ATS exhaust manifold,Lazarsmith drag bars,Snow mpg max water/meth.
estrada5.9 is offline   Reply With Quote
Old 11-21-2009, 07:06 PM   #3 (permalink)
Wisconsin Chapter President
partyshortbusdriver's Avatar
you will not get an injector that egts wont be an issue with a stock turbo, my 5x.012 got hot with the 62/65/12 that i had, so I dont suggest them at all with a stock turbo. I can even hit 1600* with this 62/71/14 im running right now
97 Fiat 3500 - Under Construction
Mark My Words. There will soon be change in our diesel world.
partyshortbusdriver is online now   Reply With Quote
Old 11-22-2009, 09:37 PM   #4 (permalink)
pm sent let me know what u think
u wont be disappointed
96 3500 12v S&B cold air -2095 plug- lazer cutz tuned pump negative 8 fuel plate cut like this / 4 gsk HD valve springs suncoast billet tranny more when funds available
sswing is offline   Reply With Quote
Old 11-23-2009, 01:16 AM   #5 (permalink)
CumminGetIt98's Avatar
I was wondering the same thing, i have a stock turbo, #0 plate, intake, and exhaust... my EGT's are right at the peak that i was told they should be at (about 1250, 1300) but I was thinking about doing a set of injectors before a turbo upgrade considering it's cheaper, and i would like to have that extra power when needed. And I dont wanna sound like I'm repeating the question, but any suggestions?.... and I was also thinking, if i can find them for the right price, is just picking up a set of used injectors just for now... until i can afford to build it for big ponies
CumminGetIt98 is offline   Reply With Quote
Old 11-23-2009, 01:27 AM   #6 (permalink)
if your egts are at the peak, why would you wanna add more fuel? thats how i look at it. Turbo before injectors, thats how I do my truck
Old 11-23-2009, 01:48 AM   #7 (permalink)
yea thats the thing, is that it hits peak when its in lockup and really hammering on it, which rarely happens around town but id really like to see more of that bottom end umph for now
1998, Reg. Cab, 4x4, 3500 Dually, 12valve, 105,000mi.... K&N Intake, Silencer Ring MIA, Wastegate Blocked, 4in Turbo to 5in Mitres, #0 Plate, Star Wheel Cranked, Pro Torque T/C, Shift Kit, Autometer Guages... 38lbs Boost, lots more to come!!
