Old 11-07-2009, 12:27 AM   #1 (permalink)
Is a I I 66 74 13 too big for me
I have a chance to buy a 66 74 14 industrial injection silver bullet and i was wondering if i used this with my current setup would the turbo be too big the only reason i would consider this turbo is because i can get it for cheap 1400 i do have plans for twins in the future but i dont want a laggy pos right now until i can afford the 2nd turbo and more fuel upgrades. By the way its for the 1st truck in my sig thanks for the help ahead of time
98 CTD 12v QC short bed 4X4 auto, k&n,#100,Industrial Injection PS62 gauges,4" exhaust 75hp ddp 3k'gsk Built 47re
98 CTD 12v CC Long Bed 4x4 Auto KDP 3gsk #0 plate, 5in dual exhaust 6 in tips bds lift on 37's
jungles82 is offline   Reply With Quote
Old 11-07-2009, 12:41 AM   #2 (permalink)
Hightech_Redneck's Avatar
get it and i wll trade you for my newer hybrid with 3k miles on it..... i need more air and that would be too big for you..... the hybrid would be great for you seeming it has a 14cm housing and the 60mm comp wheel (6 blade) it also has a Banks big head wastegate on it thats adjustable..... im needing a 66mm bad and i need to get rid of the hybrid.... i bought it new from II and it costs 1250 new.....
Dustin - 95' 12 Valve, RCLB, 4x4, 5" exhaust, manumatic billet tranny, nice gate shifter ....more fuel and a larger turbo coming soon....
CG DIESEL PERFORMANCE - - - - - - - - - - - - - - - OHIO COAL ROLLERS
Hightech_Redneck is offline   Reply With Quote
Old 11-07-2009, 12:47 AM   #3 (permalink)
I would but its gonna cost me 1400 Plus shipping to get the turbo to begin with but if you want it its on ebay and also whats a hybrid turbo an upgraded hx35? or what sorry i have no clue
Old 11-07-2009, 01:39 AM   #4 (permalink)
'strokeThis_'07's Avatar
Its a laggy SOB. Good turbo, but if your not running the fuel to light it, your gonna be unhappy with it
'07 3500 SRW QC/LB-Billet HTS piece-o-crap-7" mitres-AFE Stg. 2-Smarty TNT
'03 2500 QC/LB HO 305/555 6speed
'strokeThis_'07 is offline   Reply With Quote
Old 11-07-2009, 02:19 AM   #5 (permalink)
What else besides delivery valves do i need i dont really want to buy another set of injectors but i think i might have to so i dont know and is this turbo gonna be too small as a big turbo on twins?
Old 11-07-2009, 01:30 PM   #6 (permalink)
Im not very experienced with 12vs, but Id almost guess your gonna need atleast 100-120hp injectors. What size that is, Im not sure; maybe 5x.016 or something like that (that seems to be a fairly popular size injector)??
No that turbo isnt too small for twins. Thats actually a big turbo in twins. Lots of guys run a 62 or 64 secondary, so that 66 would be plenty big for nearly any power level your going to shoot for...
Old 11-07-2009, 01:41 PM   #7 (permalink)
Algae Eater's Avatar
I disagree that it would be good in twins. It's too big for the high-pressure turbo and you're not going to get much out of it as the low-pressure unit either.
In moderate (ie, 650-800HP not extremely high HP 1000+) twins, the ideal combo is a fast spooling primary (62mm is perfect) and a big secondary (74-80mm)... so a 66 is kind of only good as a really big single and it'll spool slow so it won't be great for the street.
If you plan on going with twins later, you're gonna have to get rid of that 66mm and buy 2 new turbos.
And at this point in time you don't even have enough fuel to light a 64mm turbo, let alone a 66mm.
Also, it seems to me that a 13mm turbine housing is too small for this turbo. That would be a good size on a 62mm turbo, but on a 66, I think it's less than what's ideal.
Someone will probably disagree with me.
98 12valve QC LB 4WD w/ 170K [new Goerend 47re, DDP fuel plate, AFE ProGuard7, MBRP 4" TB w/ 5" tip, Thuren trackbar, Bilstein 5100's, 2.5" Revtek level kit, BFG Mud KM2 33x11's, AWC 16x8 rims, Amsoil, silencer ring gone, KDP tabbed (THANKS Nitrous340!)
Algae Eater is offline   Reply With Quote
Old 11-07-2009, 02:00 PM   #8 (permalink)
Thats what i was thinking that 66 was gonna be to small for the big turbo and to big for the smaller turbo so i would have to go big single and i dont want to do that what should i run for a turbo now that will be a good fit for twins later and i am going to do delivery valves what should i do there 191? i Have no Clue any help would be great and thanks for all the great info guys
Old 11-07-2009, 02:48 PM   #9 (permalink)
Yes it is to big for a single for you right now. No its not to big for a secondary. BD twins use a 66/74/.91 as there secondary, the only difference from the II SB is it has a slightly larger exhaust housing. The turbo would be a very fast spooling set of twins if you put it under your stocker. A 13cm^2 exhaust housing is not to tight for this turbo. Also II doesn't offer a 13, 13s are from HTT in there stainless exhaust housings along with 16s.
95 12v 2wd, reg cab, long bed.
a3ftgiant is offline   Reply With Quote
Old 11-07-2009, 06:26 PM   #10 (permalink)
kjpcummins's Avatar
A .91 exhaust housing is like a 16cm. The reason a 73 wheel is so laggy is to put it in a smaller exhaust housing like a 13cm, 14cm, .83, .85 is you have to cut it to fit. The .88 and .91 t4 nongated housing were designed for that 73 wheel specifically to aid in spool up. I have a E.D. 66/73/.91 t4 non gated and it drives on the street like a hx35 becuase of the exhaust housing yet it flows a ton of air up top. Im gonna agree and say a small housing like a 13cm is to tight it would cause very high drive pressure.
2002 2500 4x4 6 speed
Please provide physical proof to back this up.....or refrain from posting it.
Engineered Diesel Turbos/Southern Diesel Extreme Injectors
kjpcummins is online now   Reply With Quote
Old 11-07-2009, 07:53 PM   #11 (permalink)
well i ended up going with a II phat shaft 62 65 14 i got an awesome deal. Also im gonna do 110lb valve springs studs and titanium retainers and locks. Should i keep the #100 plate or put in the #0 plate?
Old 11-08-2009, 12:01 AM   #12 (permalink)
Keep the 100 in it will help control low end smoke but will be the same rack travel as a 0 after the arm slides up the plate. Also your looking for 60lbs valve springs. 110s are vp and cr springs.
