| 94-98 Performance Parts Discussion Discussion of Performance Parts For the 94-98 Trucks No Advertising ...NO ADVERTISING |
#13 (permalink) |
Thanks, that makes sence to me. I have 131's in right now so I think I will take them out and cut them to a .25 or .22. Thanks for the good idea Sh111t!
1981 chevy 1 ton crewcab,shortbed, 95' CTD,HX35/ST50 twins,#100 plate, 15* timing, boost elbow,385 hp injectors, 4" exhaust, BHAF,3K gsk,SB clutch,8" lift,205tcase,4.11s,14r/60f both w/detroits,38"toyo MTs,18x10 chrome.SHES A BEAST! |
#14 (permalink) |
No problem. Us Chevy/Cummins guys gotta stick together
1981 Chevy Short bed - Cummins swap Hoping for ~450 RWHP 1995 12v, NV4500, s362/s475 compounds, PDI manifold, #5 fuel plate, 181 Delivery valves, 5" turbo back, Mack plug, 60# springs, 4000 GSK, Timing @ 16*, 5x12 injectors. |
#15 (permalink) |
I think what Derek is trying to say, is that the 131 has less shoulder than the 181, so that will flow more fuel than the 181, and the main difference is in the seats. So, if the same seats are used, the 131 will flow more than the 181. So by cutting the shoulder on the 181, and leaving the 131 the way it is, you will be accomplishing the results you were talking about. Having the higher flowing of the 2 dv's still stock, and modding the one that has more shoulder on it. Sean
2000 2500 Reg. Cab 4x4. Built trans, Twins, Edge drag box, Sticks, Studs, cam, Gauges, etc... 09 2500 6.7L QCLB 4x4, G56, all stock for now. |
#16 (permalink) |
Tech Specialist
Yeah that's what I was getting at. I'm mostly just stirring things up. When you have the two sets side by side cut the ones with the longer relief leading to the shoulder. If you don't want to mess them up yourself its an easy job for a machine shop.
98 Dodge 2500 Motor: 12 valve, original 913 pump with the basics, some DDP parts, FASS, and more stuff then they will let me put here Drivetrain: 5-speed 4x4 w/ SB OFE clutch (Love it!) |
#17 (permalink) |
Sooooo......I should cut the 181s? Correct? Since im NOT changing the seat?
#18 (permalink) |
You want to cut the 181's and run the 181 seats. 131 DV's with 181 seats are an upgrade from 181 DV's in 181 seats. 181 Dv's in 131 seats would be a down grade. Either way, I would cut the 181's as they have more shoulder on them. Running a 181 seat instead of the 131 seat will help a lot too. Sean
#19 (permalink) |
Well crap! I dont have any 181 holders, so im screwed then!
