| 94-98 Performance Parts Discussion Discussion of Performance Parts For the 94-98 Trucks No Advertising ...NO ADVERTISING |
I need some advice about my 12v
I just got a 1996 12v. mods: homemade intake w/ filter homemade 5" stacks running no plate Is there something I should be careful of or watch out for with these mods? And on another note the shut off soleniod is bad so thats jerry rigged too.... ![]() please help |
#2 (permalink) |
Wisconsin Chapter President
![]() Join Date: Jan 2008
get gauges and if the tranny/clutch is stock, it might not last too long if you beat on it fuel shut off soleniods are $140 off ebay
Wisconsin Chapter Prez 97 Fiat 3500 Dually - 62/71/14 - 5x.012's - Rack Plug - AFC Mods - Ished Timing - Helix II - 5" Str8 Pipe - BHAF- No Plate - 4k GSK - 60# Springs - Auto to Manual Swap- Valair 500hp Clutch - 342,500 miles Soon to be SRW
#3 (permalink) |
The solenoid rarely goes bad on these engines. Here is a very good write-up on how to check the solenoid and its circuit. Scroll down towards the bottom of link: Joe G's fuel system writeup
'96 Dodge 3500,KDP killed, boost-pyro-trans temp, not stock anymore '01 Dodge 2500 4X4, EC, LB, 6 speed, FP-pyro-boost, '97 Chevrolet Suburban, K1500, 4.10 gears |
#4 (permalink) |
thanks im gonna have to check that out, im gettin a new tranny in april and would appreciate any and all information on jasper (where im gettin my tranny) and some injector and turbo sugestions for the setup i have. I use my truck for daily driving, towing, and all around showing off. my goals are 13s in the 1/4 and still reliable if possible. |
#5 (permalink) |
For a transmission I strongly recommend Dave Goerand. I don't know if Jasper can build you a transmission to hold the HP your planning on putting to it. 13's in the quarter will take some pretty serious HP. Dave can build you one to take that and a LOT more.
#6 (permalink) |
i would definately get a good tranny. i have an ats tranny, but i have heard a lot of good things about Goerand transmissions. i heard their torque converters have a lifetime warrenty. thats who i would go with when i buy another tranny.
1997 12 valve full cut DVs, 60lb valve springs,14mm studs,fireringed, pump work, big injectors, straight pipe,ISSpro boost/pyro/oil temp/fuel pressure/tranny, ats stage 4 tranny w/lock up
#7 (permalink) |
definately dave goerend 100% go with him hes a super intelligent guy and the tranny has 3 year warranty or 100k and lifetime on the tq if you have any questions about his trannys dave will spend however much time it takes for you to understand it (been there) hes an extremely nice person to deal with as wel,l he'll put you in one bad a$$ transimission
96 12v 4wd goerend 47re built trannny billet input and output goerend 3disc converter 140hp ddp injectors 4gsk from ddp dv from ddp custom plate ff and 18* timing IN NEED OF CHARGER! |
#8 (permalink) |
Start by fixing the dowel pin, get some guages, and a trans. Mark
06 Mega 4x4 Her's, 99 qcsb 4x4, stock mine 96, dually, XC, 4x4, 5spd,Helix 2 cam, BD twins, 0 plate , 4GSK, SBC 3600 twin disk 97, XC, 4x4, 5spd, SBC OFE, |
#10 (permalink) |
Here's you a link for a repair kit. I recommend going to cummins and also getting a timing cover gasket also: Dowel Pin Repair Kit for 94-98 The dowel pin is used to hold the timing case in alignment. On these years trucks they are known to fall out and at minimum do no damage and at most completely destoy your engine. GET IT FIXED QUICKLY.
