Old 11-03-2009, 02:01 AM   #1 (permalink)
TTR 21's Avatar
Low boost problem....
I would like to know what other people are seeing for boost out of a 160 pump with no plate and everything slid forward and wastgate clamped off. i am seeing a max of 29 psi which seems very low to me. my buddy with his 98 12v with the same mods is seeing 45. i do realize he has a 215 pump but my boost numbers seem very low.
04.5, SB 3600 DD, 4 In. Straight Pipe W/ 6 In. Tip, AFE Stage 2 Intake, ATS Intake Manifold, Crazy Larry 2.4d, MP-8, Rail Cap, Airdog II, Snow Performance Stage 3 Water/Meth, Dipricol Gauges, 6 In. Lift, 37 In. Toyo MT's, 20 In. MKW's. 7/24/09 508 HP 1066 TQ!
TTR 21 is offline   Reply With Quote
Old 11-03-2009, 10:11 AM   #2 (permalink)
I can see 38 with my WHC1 holset with a 0 plate full forward. You could have a boost leak, a wategate flapper leak or an exhaust restriction........
1994 Reg cab 2 WD manual trans #0 fuel plate boost elbow BHAF 16.5* 3KGSK KDP fixed
tdshepard is offline   Reply With Quote
Old 11-03-2009, 11:19 AM   #3 (permalink)
that does seem a bit low ... like was said before, I'd check for boost leaks, but I'd also check your fuel pressure and/or fuel lines for any air leaks ... how's your egt's? If they aren't getting too hot with that setup, then I'd say you aren't getting enough fuel ...
1997 DRW NV5600 4WD - Banks Cat-Back - Banks "Big Head" WG - Banks Fuel Plate - Center Force Clutch - BD Exhaust Brake w/Press Gauge - 2" Leveling kit - Banks Boost and EGT gauges - Firestone Assist Bags... Need 4" Turbo/back exhaust badly... trade?
matterhorn is offline   Reply With Quote
Old 11-03-2009, 12:15 PM   #4 (permalink)
TTR 21's Avatar
my egts wont really get that hot even if i push it hard. maybe 1000 degrees. i will have to check for fuel and boost leaks i guess becauseit seems like i should have gained alot more power from these mods as well. thanks.
Old 11-03-2009, 12:16 PM   #5 (permalink)
12vanthony's Avatar
I see a max of about 40 with my 215 pump
'97 12v 5.spd...broke college student dreaming of more money and mods
12vanthony is offline   Reply With Quote
Old 11-03-2009, 09:40 PM   #6 (permalink)
TTR 21's Avatar
Where is a good place to start for checking boost and fuel leaks? Are there common problem areas or could it be anywhere?
Old 11-03-2009, 10:53 PM   #7 (permalink)
MX26's Avatar
For the boost leaks, the intercooler boots are usually the only places that leak. Inspect them closely, see if you can find any cuts or slices in them. As for the fuel leak, there are a few common leaks that can develop. One is the rubber hose behind the fuel filter.. It's a PITA to find though. Usually with a fuel leak, you'll find a drip. Let it idle on some concrete for an hour or so and see if anything turns up.
Trust me.... I'm a doctor.
94 12V NV4500 2wd - #100FF, BHAF, 3GSK, 4" FBD Straight
98 12V Quad Cab Shortbed SLT 4x4 - Auto with a "few" mods
MX26 is offline   Reply With Quote
Old 11-04-2009, 12:44 PM   #8 (permalink)
khunter_2007's Avatar
i hit 52 with a banks #10 plate not sprayng then about 58 with nos with the stock h1c
94 cummins ,stock turbo ,370 marine injectors ,3k gov springs, laser cut dvs ,cam, bored .20 over ,lockup controler, tci stage 5 tc, suncoast valve body, 150 shot of nos, banks #8 plate slid, afc slid, suncoast extreme duty clutch kit, 6 in . stacks
khunter_2007 is offline   Reply With Quote
Old 11-04-2009, 06:59 PM   #9 (permalink)
straight_six's Avatar
stock gsk?
06 Mega, SMARTY, DTT trans, MPI twins, FASS 150, DDP 90s, ARP, Opie bypass, MP-8, 643hp
94 2wd single cab...
straight_six is offline   Reply With Quote
Old 11-04-2009, 07:06 PM   #10 (permalink)
rdix7991's Avatar
Hey khunter, with all of those mods in your sig I would be jumpin all over a bigger turbo!
2000 Ext.C SB 4x4,AD 150, 150HP injectors, 62/14/71, Georend
rdix7991 is offline   Reply With Quote
Old 11-05-2009, 01:13 PM   #11 (permalink)
yeah im waitin to get a lil $$$$$ in going to either put hx40 / ht3b or s362/s480 twin setup
Old 11-06-2009, 02:29 PM   #12 (permalink)
TTR 21's Avatar
Well i did alot of playing around and testing yesterday to see if i could find any leaks. there was a small fuel leak to the pump after the filter but nothing that was terrible. fixed the leak and went to test everything out again. I was still only getting 29 psi of boost pressure. as i was out and about stilll testing and checking things i went to pass a guy on the highway and for the first time felt the TC lockup and away i went hitting 35 psi. with alot more messing around with i found out that you really have to push these older pickup go pedals alot harder than the newer ones. the whole time before i thought it was pinned it really wasn't and i just needed to add alittle more pressure to the pedal and she locks up everytime now as long as im going over 40 mph. i see a max of 39 psi at lockup and 34 psi with out. This sounds a bit better doesn't it!
