| 94-98 Performance Parts Discussion Discussion of Performance Parts For the 94-98 Trucks No Advertising ...NO ADVERTISING |
External Wastegate Options??
hey guys, egt's(1600++) and boost(50psi++) are through the roof on the super s3, so...... i was kickin around the idea of tryin an external wastegate. i'm probly gonna need one in the future (with the twins), so i figured i might as well get one comin since i'm not real sure on my twin setup yet. and it will give a little time to figure them out a bit... i see a few guys usin the 44mm tial units, but i am just not real sure what i'm lookin for yet. are they all adjustable for boost pressures?? do i have to buy different springs for different boost settings?? any info/input will be greatly appreciated..thanks.
my project: '94 2wd, standard cab, auto with goerend goodies, 5x14's, 0 plate, scheid dv's, airdog 150, super S300, 4k kit, afc modded, timing advanced, 60# springs, traction bars, custom intake, 5" stack...saving for S400(for twins) and billet shafts. |
#2 (permalink) |
Engineered Diesel
2002 2500 4x4 6 speed Please provide physical proof to back this up.....or refrain from posting it. Engineered Diesel Turbos/Southern Diesel Extreme Injectors |
#3 (permalink) |
You can buy different spring to regulate opening pressures. Or you can use you boost elbow on your turbo to fine tune it. Use it the same way you would regulate your internal gate, but route your hose to your external.
1996 2500 4x4, HX35+HT60,#10 Full Forward, 3000 GSK, 18*, DDP 191's,5x.012's, Modified AFC,5" Hood Stack, Home Made Traction Bars,Autometer Ultra Lite II Gauges,Auto to Manual,Valair 12 1/4" 3800# Ceramic, 3.54:1 Gears. |
#4 (permalink) |
ok...so with the diaphragm type, i can just use it as i would the internal gate. ahh...it all makes cents now. lol but arent the diaphragm types been known to wear out due to the heat and psi of the diesel application? are the spring type gates better or worse than the diaphragm types? and some of u guys runnin externals...how big is big enough? bigger the better? 38mm, 44mm..50mm???
#5 (permalink) |
I found a tial 40mm at a sweet deal of $100, so I couldnt pass it up. I think it should be alright as long as you tune it right. You might not be able to get the most out of a set up, but it sure will be better than no gate. Ive never heard of someone "needing" larger than a 44mm gate
#6 (permalink) |
You have to watch out... There's a lot of imitation crappy chinese "tial" wg's out there.
'97 4x4, 12 v, SC/LB work truck/DD probably a bad P7100 pump... Goerend VB and triple disc, Suncoast rebuild, Billet in/out, billet flex plate, 62/65/13ss +S475, Weston's 5x.014's |
#7 (permalink) |
Agreed to that. But when it came from a friends 240sx sr20, who bought it from tial, i wasnt worried. But that does bring up a good point. If you go on TiAL's web site, they show how to tell a fake from a genuine piece
#8 (permalink) |
alright...thanks fellas
