| 94-98 Performance Parts Discussion Discussion of Performance Parts For the 94-98 Trucks No Advertising ...NO ADVERTISING |
what turbo to twin with the stock turbo
on my conversion build, im thinking about putting twins on the truck, but want to do it on a budget, so whats a good turbo that can be used with the stock turbo that will supply enough air for about 500-600 hp? thanks
In planning stages, 2003 rc/lb gmc 2500 with 12v cummins conversion |
#2 (permalink) |
A standard S400 will work well, and can be had brand new for around 650 bucks if you know where to look.
Colin-'06 QC, SB, 4x4- 853hp/1467 & 11.30@122mph. Thanks, Brad and everybody at Ponci's Diesel Center, Dave Goerend and everyone who helped along the way! |
#4 (permalink) |
An S400 is a Schwitzer turbo, built by Borg Warner. They can vary a lot in size. For a primary charger you should look for something in the neighborhood of a 74/83/1.10 with a T-6 housing would be good. Here is a link to get you started. Bullseye Power Turbos
#6 (permalink) |
majestic turbo sells them with a 1.32A/R t6 housing for $585. Same spec on the Comp wheel, and turbine exducer. index Dallas Turbo Its under specials. The the charger is very restrictive in the exhaust department. You will definitely want to address that with an external wastegate. Sean
2000 2500 Reg. Cab 4x4. Built trans, Twins, Edge drag box, Sticks, Studs, cam, Gauges, etc... 09 2500 6.7L QCLB 4x4, G56, all stock for now. |
#8 (permalink) |
Check out Source Automotive they sell complete kits or just parts. Source Automotive Performance Diesel
98 Dodge 2500 Club cab 4X4 5-sp #5 plate ,16*timing, BHAF, dumped silencer ring, big rig junkyard 5"exhaust. KDP fixed the HARD way
#9 (permalink) |
HT3B would be a good/cheap bottom charger as well and many have done that exact setup for quite a bit less than a kit ... as for the s400 - check out Source Automotive's version of that setup - they have a lot of pics to help you out with the piping and such ... and the also supply individual parts to complete the build - VERY highly recommended .
1997 DRW NV5600 4WD - Banks Cat-Back - Banks "Big Head" WG - Banks Fuel Plate - Center Force Clutch - BD Exhaust Brake w/Press Gauge - 2" Leveling kit - Banks Boost and EGT gauges - Firestone Assist Bags... Need 4" Turbo/back exhaust badly... trade? |
#10 (permalink) | |
1981 Chevy Short bed - Cummins swap Hoping for ~450 RWHP 1995 12v, NV4500, s362/s475 compounds, PDI manifold, #5 fuel plate, 181 Delivery valves, 5" turbo back, Mack plug, 60# springs, 4000 GSK, Timing @ 16*, 5x12 injectors. |
