| 94-98 Performance Parts Discussion Discussion of Performance Parts For the 94-98 Trucks No Advertising ...NO ADVERTISING |
#14 (permalink) |
I got the best price from Air Flow systems 1-800-762-9876
98 12v,2wd twins,3:55,g56 6speed,elec fan clutch,100 hp sticks, 10 plate FF aFC fB,3gsk Valair ats,fluid damper,60#springs,o6 exhaust brake,High Idle,prime loc, 4"exh,piller mount |
#16 (permalink) | |
1997 12 valve full cut DVs, 60lb valve springs,14mm studs,fireringed, pump work, big injectors, straight pipe,ISSpro boost/pyro/oil temp/fuel pressure/tranny, ats stage 4 tranny w/lock up
#17 (permalink) |
an hx35/40 hybrid might be a good top charger as well ...
1997 DRW NV5600 4WD - Banks Cat-Back - Banks "Big Head" WG - Banks Fuel Plate - Center Force Clutch - BD Exhaust Brake w/Press Gauge - 2" Leveling kit - Banks Boost and EGT gauges - Firestone Assist Bags... Need 4" Turbo/back exhaust badly... trade? |
#18 (permalink) |
ok i have a few questions about this hybird turbo.... 1) what is the difference between it and a normal hx35? 2) will the pipes from source automotive work with this turbo? 3) if so, what hot pipe, charged pipe, and intercooler pipe would i need to get? 4) where is the best place to get one?
In planning stages, 2003 rc/lb gmc 2500 with 12v cummins conversion |
#20 (permalink) |
well i think i got it all figured out. by the looks of it, it is the same charge pipe and intercooler pipe regardless of the turbo. If not, im guessing that will be something I will have to call source automotive about. As for the hot pipe, it should be the hotpipe for the hx35. correct me if I am wrong about any of this, but im thinking a hx35/40 hybrid over an s400 will be the set up I go with.
#21 (permalink) |
The hx35 hybrid over an s400 will be a good spooling set of twins that should support up to 650 hp.
Colin-'06 QC, SB, 4x4- 853hp/1467 & 11.30@122mph. Thanks, Brad and everybody at Ponci's Diesel Center, Dave Goerend and everyone who helped along the way! |
#22 (permalink) | |
It would be too large for a single if that's what you were meaning. But not for a primary charger in a set of twins. ***1997 12 valve cut delievery valves,60lb valve springs,14mm studs,fireringed, pump work, big injectors, straight pipe,ISSpro boost/pyro/oil temp/fuel pressure/tranny, ats stage 4 tranny w/lock up**** Tough to say what you would be putting down for hp. What kind of DV? Full Cut, 0.22's, .024's ext? How much Pump work? Did you swing the barrels, has it been benched, how many cc's does it flow? How Big is Big Injectors? 5x14, 5x18? With a stock turbo, I'd be surprised if you put down 425 to 450 even if you had a lot of fuel.
#23 (permalink) |
the hx35/40 seem to have shaft problems.
| The Following User Says Thank You to renopker For This Useful Post: | cumminspower53 (11-09-2009) |
#24 (permalink) |
so what you're saying is that the hx35/40 might break or something? could you elaborate on this problem because upgrading to one of these is way cheaper than getting another complete turbo? Mabey you get what you pay for? Also I found Air Flow systems website and they dont show any turbos for sale, are those like a call only product? thanks
