| 94-98 Performance Parts Discussion Discussion of Performance Parts For the 94-98 Trucks No Advertising ...NO ADVERTISING |
5x.014 Injector opinions
Well I have finally had some time to install my new injector's from Southern Extreame Diesel but ran out of time. It's Halloween and time for trick or treating with the little Guy. I did have time to fire her up and check for leaks and I will say I am impressed so far! After I adjusted the idle there was little to no haze. Stay tuned for more testing
1995 CTD 4x4 100# Plate Full Forward Afc Foot mods set of 3k gov springs from Pdr,022 delivery valves, 5x0.14 injecters,Htb2 62/71/13ss, Goerand valve body, converter and various other trany goodies.Pyro,4 inch exhaust... |
#2 (permalink) |
Glad to hear it. I'm going to get a set for my 24v when I have some more funds. How do you like you complete set up? Are these upgrades from the 90hp's you have listed? Seems like a 5x0.014 should be more than that, closer to a 140hp. Your set up, is very similar to what I have in mind for my friend to do to his truck. Sean
2000 2500 Reg. Cab 4x4. Built trans, Twins, Edge drag box, Sticks, Studs, cam, Gauges, etc... 09 2500 6.7L QCLB 4x4, G56, all stock for now. |
#3 (permalink) |
u will love them
98 2500 4x4 7"38's, 8kh.i.d, pump tweaks, 4gsk, stacks, inline defuser,FASS,gauges,Suncoast billet trans bllt flex plate, tc lck up, timing, k&n, head oringed+ stg3 valve job,60lbs spring,coaltrain 140's soon to be a1's and super b special.
#5 (permalink) |
yep me two im all ears cant wait to see how you like the whole setup
96 12v 4wd goerend 47re built trannny billet input and output goerend 3disc converter 140hp ddp injectors 4gsk from ddp dv from ddp custom plate ff and 18* timing IN NEED OF CHARGER! |
#6 (permalink) |
Well guy's finished up last night and took her for a blast and I will say that I am pleased with several things the first being that the truck no longer has a thick haze on warm up and the throttle is much crisper when blipped! I went for a ride and the boost comes up a lot faster with these sticks virtually eliminating any perceived lag that the 71mm turbine might give. Now the last real tests are to see just how hot they are and what they can do when I put the foot into it all the way! I am waiting until I get the pyro hooked back up before I execute a full on blast! Overall so far I Love my combo! Now I need to find out whether or not the Mack rack plugg will benefit me or not? I have a 160 pump but I have played with the rack to maximize things and I was told by someone that it wound not help unless I was going to run NO plate?? Anyone have any opinions on this??
#7 (permalink) |
Wisconsin Chapter President
![]() Join Date: Jan 2008
a 0 or 100 plate FF will benifit with a rack plug glad to hear about improved spool, i cant wait till I get a set of 5x.014's for my turbo
Wisconsin Chapter Prez 97 Fiat 3500 Dually - 62/71/14 - 5x.012's - Rack Plug - AFC Mods - Ished Timing - Helix II - 5" Str8 Pipe - BHAF- No Plate - 4k GSK - 60# Springs - Auto to Manual Swap- Valair 500hp Clutch - 342,500 miles Soon to be SRW
#8 (permalink) |
Thanks Ralph! Oh and get that rack plug
1998 2500 12 valve QC Goerend trans, 4x4, gauges, Benched 500+cc 180 pump NO plate, 5" single stack, ICE BOX intake, 4K GSK, 60lb valve springs, 24* timing, AirDog 150, Southern Diesel eXtreme 5X18s, 3rd Gen wheels E.D. 64/68 turbo, ARP studs. 13.4/99mph |
#9 (permalink) |
Hmm I have a Guy that I talk to here and there on the Boards who told me that if I have a plate in there won't be any benifit to adding the rack plugg? He said that No plate would be the way to go if adding the plugg to a 160 pump that has had the afc modded out....IMHO if this will add power I will do it!
#10 (permalink) |
a 0 or 100 plate ff is the same as no plate, if you install it right. if you have a 0 plate then its not really worth having imo. a 100 plate will restrict rack travel down low to help with tuning
#11 (permalink) |
Yes I understand this I have had this thing apart a few times Lol! I am only quoting a pretty knowledgeable Guy and wanted to see if any one had any real number's with and without plates.......So your opinion is why bother with the plate if you are looking for Max rack??
#12 (permalink) | |
With your #0 or #100 plate FF you will not contact the plate, you will hit your stock rackplug (19mm travel). With the new plug installed and a modified AFC arm your plate will become the new rack stop at 21mm of travel.
94 regular cab 4x4, no plate, 90hp sticks, 191's, 2095 rack plug, 20* timing , Modded AFC, 5000gsk, Goerend Trans, Lockup switch, WH1C/HT60 Twins 34mm internal gate |
