Old 10-29-2009, 11:18 PM   #1 (permalink)
madmikeismad's Avatar
still no smoke?
I removed the plate the other day, and just !once! I floored it all out from a 20mph roll at an idle. No smoke, except for the small puff I get because I have no afc.
Any ideas? I'm getting a fuel pressure/pyro/boost setup soon from Lowry's, so I'll know then if I have low pressure, but assuming I don't have low fuel, what else could it be?
98 12v: BD brace, AFC gutted w/ no plate, Lukes Link, Timing to 15.5, BHAF, 2in HBS level, 35in Terragrapplers, brush guard w/ lights, window vents, H/U, bedlined rockers and bumper pieces. To Install: KDP, Mud Flaps, cab lights http://picasaweb.google.com/mch8223/Diesel#
madmikeismad is offline   Reply With Quote
Old 10-30-2009, 12:29 PM   #2 (permalink)
oh, also, when I put the afc back on, I stripped the bolt hole closest to the drivers seat. For now I have a shorter sheet metal screw in there, it's not leaking oil, and it seems to be sealed tight. Is that ok for now?
Old 11-01-2009, 11:11 AM   #3 (permalink)
no smoke is a good thing! Smoke does not give you power.
lifeline is offline   Reply With Quote
Old 11-01-2009, 11:25 AM   #4 (permalink)
no it doesn't, but it's nice to see. I blame the kid in me And if it's supposed to be smoking, and isn't, it could mean I have a fuel problem.
Old 11-01-2009, 11:32 AM   #5 (permalink)
maybe you just haven't put enuff of a load on it. I got an fl 50 frieghtliner that only smokes when it lugs or if I gross about 40 k and then it only does it till the turbo spools up. start out in a higher gear!
Old 11-01-2009, 12:01 PM   #6 (permalink)
automatic
Old 11-04-2009, 07:24 PM   #7 (permalink)
Update: It smokes when ever I give it throttle with the TC locked up A lot
So I should be ok using a sheet metal screw in place of the afc screw? It's been a week or so now, and still no oil leaking.
Old 11-04-2009, 08:49 PM   #8 (permalink)
no, put a helicoil in there with a real bolt.
a3ftgiant is offline   Reply With Quote
Old 11-04-2009, 09:11 PM   #9 (permalink)
pardon my french, but what the hell is a helicoil???
Old 11-05-2009, 12:15 AM   #10 (permalink)
Thread repair that will keep original size. Drill it out tap it and install a helicoil.
YouTube - How to Repair Threads With A Heli-Coil Insert
95 12v 2wd, reg cab, long bed.
Old 11-06-2009, 08:07 PM   #11 (permalink)
what exhaust u have on it???
96 3500 12v S&B cold air -2095 plug- lazer cutz tuned pump negative 8 fuel plate cut like this / 4 gsk HD valve springs suncoast billet tranny more when funds available
sswing is offline   Reply With Quote
Old 11-06-2009, 10:17 PM   #12 (permalink)
stock. Actually, I found a 4inch aluminized mbrp setup turbo back on autoanything.com that I was looking at for like 200. Does that sound like a good deal?
Either way, I'm going to 4 inch this week. And ordering the tranny parts as soon as I get a set price from goerend and suncoast.
