- - REGISTER - CALENDAR - INFO - SITE HELP - RULES - STAFF - MEMBERSHIP - ADVERTISE - CONTACT US - |
| 94-98 Performance Parts Discussion Discussion of Performance Parts For the 94-98 Trucks No Advertising ...NO ADVERTISING |
injector removal
even if you are sending your bodies in for cores why destroy them in the removal process?
worse yet if you are planing on having someone redo them and ship em back?????? ![]() remove the nuts pitch the dust covers and spray em with lps or aerokroil ![]() have the right tools. i like a ladys foot or a set of them in diff sizes and a pry bar if need be. (dont usually need pry bar (or brass hammer after lps) ![]() get a 14 x 1.5 nut and screw it down at least 75%. ladys foot off a head bolt should get it to move. increase size as inj raises up ![]() do not put the pointed end of the ladys foot in the return and try to pry there ![]() will turn the inj into scrap quick style ![]() and dont chince out on the nut and try to use vise grips. they will slip off the square part of the injector and bugger the threads eihter ruining the core or making for lots of filling work by the machinist come on guys...please use your head shouldnt matter if the injectors are getting new tips or the pressre set adn coming back to you or if you are just turning them in for cores thanks, don *ps - if you are going to disassemble and take a look inside please take note of how it came apart so you do not destroy the injector improperly assembling it and PLEASE do not lose any of the internal parts. thanks again Last edited by BBRam; 10-28-2009 at 06:58 AM. Reason: having ME or someone redo them (Advertising) |
| The Following User Says Thank You to DTanklage For This Useful Post: | 12v cody (10-28-2009) |
#2 (permalink) |
Daddy's Home
![]() ![]() Join Date: Jul 2008
a lug nut is the perfect size for the threads.... just some knowledge for ya
2001 3500 4x4 5.9 HO, 6 speed, AD150, triple gauge pod filled with ISSPRO EVII's.... Quad ADR and some FBD 100's en route.. ![]() 1994 3500 RCLB(New Money Pit).... Virginia Beater!!! |
#3 (permalink) |
Got P7100?
iTrader Score: 5 reviews
At least you 12v guys dont have to pull the valve cover off to swap injectors
Nice write up Don
2000 QCSB, 175hp p7100, 4gsk, 191dv's, .084 lines and tubes, 7x.014's, maxspool 2.5, 110# springs, head bolts @ 125ft lbs, tranny built by me with DTT parts, AD150, 62/71/14(for now) ohiocoalrollers.com
#4 (permalink) |
Super Moderator
![]() Join Date: Nov 2005
No need for all the tools, all you need is the lug nut and a piece of 1/2" or 3/4" pvc or steel pipe 1-3/8" long. Some fittings such as tees are close enough.
Just slip the pipe over the injector and tighten down the lug nut. If the pipe is too short stack up some washers, too long cut or grind it. Most times the injector pops right out just turning the the nut with your hand. If you have to use a wrench on the nut it will feel like no force at all to pop them out. I can't count how many injectors I've removed this way, never have had to use penetrating oil even once.
Bill '95 2500 4wd auto '95 3500 5 speed heavy hauler Stock for one day |
#5 (permalink) |
![]() Join Date: Nov 2006
I have done 2 sets with the lugnut and pipe method. No damage at all.
Around here with the humidity and such I doubt you could pry one out without hurting it. Matt-You are 1/2 way to a 12v as it is LOL KO
'96 4x4 EC Goerend-Triple Disc TC-Auto-4.10's-305/70 Terra Grapplers-909's-5" Grand Rock to da bumpa-Custom Injectors-HTBG 14cm-4K-GSK -19*-Fire Ringed-Titanium crap here and there-ATS 3pc- If I have something for sale it's always "First come, First serve", been burnt too many times...Sorry. |
#6 (permalink) |
no need for pipe... just double stack injector hold downs!
'06 Mega Cab 2500 4x4 auto. tranny by HotRodDiesels, Smarty, Fleece Performance stand-alone VNT setup, etc. "it makes cool noises" |
#7 (permalink) |
good right up. i just use a lugnut and pipe method or a wrench and a washer and pry up on it. good right up tho. I could def see someone using a pair of channel locks hahah
98 2500 4x4 7"38's, 8kh.i.d, pump tweaks, 4gsk, stacks, inline defuser,FASS,gauges,Suncoast billet trans bllt flex plate, tc lck up, timing, k&n, head oringed+ stg3 valve job,60lbs spring,coaltrain 140's soon to be a1's
#8 (permalink) |
i just used a nut i had in our bolt bin, did two trucks like that and no problem!!
94' cummins 12 valve. lots of fuel and a crazy ___ year old ![]() SPECIAL THANKS TO TOXIC DIESEL |
