Old 10-15-2009, 04:09 PM   #1 (permalink)
CumminsKid1460's Avatar
Fuel plate question
Hello guys, is anybody running a 10 plate? i have a 100 plate in my pump right now and i can peg my pyro pretty quickly, towing sucks as i can black out an intersection, ive heard some people like the torque curve of a 10 plate, so any input is appreciated.
1994 Dodge 3500 4wd, CTD, 5-spd, 4.10 gears, 4-inch straight pipe, 14cm turbine housing, hx40 compressor, Banks wastegate, Banks Twin-Ram intake, S&B filter, boost elbow, 3000gsk, 100 plate, full forward, 50hp injectors, timing at 14.5
CumminsKid1460 is offline   Reply With Quote
Old 10-15-2009, 04:21 PM   #2 (permalink)
cummin not strokin3's Avatar
i am running a zero plate and i can pull a trailer around just fine. play with your star wheel to get rid of smoke.
1997 dodge 2500 no plate 4" str8 pipe ,AFE BHAF,BD intercooler boots, boost and pyro gauges,what silencer ring? 2009 dodge 2500 6.7 stock as he!!
cummin not strokin3 is offline   Reply With Quote
Old 10-15-2009, 04:31 PM   #3 (permalink)
Like you I was running a #100 and had the same problems. I changed back to a #10 and all is good.
1997 2500 4x4, 5 speed, open intake, BHAF, #10 fuel plate, 16cm exhaust housing, 4" MBRP exhaust, Coolingmist stage 1 EGT, Timing 16 deg, and a 3K GSK.
turboAl is offline   Reply With Quote
Old 10-15-2009, 10:31 PM   #4 (permalink)
Ok, well i think im going to do a 10 plate and see how that rolls, thanks guys.
Old 10-17-2009, 06:04 PM   #5 (permalink)
redneckcummins97's Avatar
so i have a question. my buddy has a 96 and has a 100 plate and is gettin 20 mpgs + but his only smokes in od and i have a 97 and tow a 5th wheel camper and im looking to up my 10 mpgs and was goin to put a 100 in. is 10 better?
1997 3500 4X4 stock auto GREEN CONE AIR FILTER(changing to a BHAF),Boost and Pyro , 3" CUSTOM INTAKE HORN, Stock fuel plate forword, MBRP Dual 5" stacks
1996 2500 4x4 stock 205,000 BHAF, Stack soon to come.
redneckcummins97 is offline   Reply With Quote
