Old 10-14-2009, 12:39 AM   #1 (permalink)
cummin not strokin3's Avatar
need help tuning pump
so i installed my 0 plate and the truck has insanely horrible bottom end. it hits really hard at about 2300 rpm i have the plate about 3/4 of the way forward and my star wheel is about 2 turns from the spring being loose. the whole blowing black smoke thing was cool for a while but its getting old and now i just want power. another strange thing the truck does is when start out in a high gear and the truck almost stalls it will blow a huge thick cloud of grayish black smoke and it doesn't stop till about 2400 rpm or till i let off. its so thick that the whole street disappears
1997 dodge 2500 no plate 4" str8 pipe ,AFE BHAF,BD intercooler boots, boost and pyro gauges,what silencer ring? 2009 dodge 2500 6.7 stock as he!!
cummin not strokin3 is offline   Reply With Quote
Old 10-14-2009, 09:50 AM   #2 (permalink)
Tighten up the starwheel and back out the pre-boost screw. Mine did the same thing as you describe. Was pretty cool when I first got the truck then it started to get embarrassing. Most people think that a truck smoking means it is a piece. Read up on pump tuning here and compD. I have it set pretty good right now, very little smoke and pulls great down low. I am having trouble with the topend now. Think I need to adjust timing!
jknowles4 is offline   Reply With Quote
Old 10-14-2009, 10:32 AM   #3 (permalink)
YOUNG GUNS15's Avatar
i did a 2 houre tuning session on the highway and turned my starwheel way back and i actually gained alot of speed
94' cummins 12 valve. lots of fuel and a crazy ___ year old
SPECIAL THANKS TO TOXIC DIESEL
YOUNG GUNS15 is offline   Reply With Quote
Old 10-14-2009, 10:42 AM   #4 (permalink)
P-pumped 24v Guy
mathews8pt's Avatar
Where is the AFC housing set? Have you flipped the washers in the housing?
2000 QCSB with a p-pump, typically broke and always stealing $$ from me
ohiocoalrollers.com
mathews8pt is offline   Reply With Quote
Old 10-14-2009, 02:34 PM   #5 (permalink)
what does flipping the washers mean
Old 10-15-2009, 10:31 AM   #6 (permalink)
Tech Specialist
Cowboy_Customs's Avatar
x2 havent heard of this. But I dont have a working AFC either.......
'95 3500 SLT Laramie clubcab 4x4 bolt action flatbed Pacbrake 60# springs timed and tuned 4.10LS 19.5's and 309K on the clock!
http://community.webshots.com/user/Cowboy_Customs
Cowboy_Customs is offline   Reply With Quote
Old 10-15-2009, 10:52 AM   #7 (permalink)
hoodstack96's Avatar
Sounds like the arm is getting hung up under the plate. If she doesnt start to come alive till 2400? And is a real dog down low, I would pull the afc and see where the arm contacts the plate
1996 2500 4x4, Externally Gated HX35+HT60,#10, 3000 GSK, 18*, DDP 191's,5x.012's, Modified AFC,5" Hood Stack, Home Made Traction Bars,Autometer Ultra Lite II Gauges,Auto to Manual,Valair 12 1/4" 3800# Ceramic, 3.54:1 Gears.
hoodstack96 is offline   Reply With Quote
Old 10-15-2009, 11:04 AM   #8 (permalink)
You take the back cover off your afc and there is two washers sandwiching the afc diaphragm. One has a lip the ther doesnt. If you reverse these washers, you get full travel of the afc lever, some people also grind the angle of the afc foot off and make it flat, in order to achieve full travel.
Old 10-15-2009, 02:09 PM   #9 (permalink)
ive done both these and i dont smoke too much...
Old 10-15-2009, 02:20 PM   #10 (permalink)
DTanklage's Avatar
...some people also grind the angle of the afc foot off and make it flat, in order to achieve full travel.
that has got to be the worst way to get full rack
bout the only thing i could think of that is worse would be to gut the afc
take it apart...study it....figure out how it works....and modify accordingly
or take it to someone that knows whats up and pay them to mod it
the afc is the brain for your fuel curve
gutting the afc for a street driven truck is about as smart as removing your brain
(the one between your ears)_
DTanklage is offline   Reply With Quote
Old 10-15-2009, 02:27 PM   #11 (permalink)
Just info gathered from others on the site. Just thought I would make it easier for others, since most cant grasp the concept of the search feature this site has
Old 10-15-2009, 03:26 PM   #12 (permalink)
why do you make it sound as if it is going to be the end of the world? i just ground the curve off my foot and nothing bad has come of it.
and some of us cant spend 200 bucks to have someone do the same thing we can do for FREE.
waste of money
