Old 10-08-2009, 04:37 AM   #13 (permalink)
DTanklage's Avatar
Originally Posted by phatboy07 View Post
so wat you think my truck would throw done on a dyno at bout 1500ft elevation???
depends on at least four factors
who ported it
who dynos it
where the plate is
road ready or track ready?
don
ps - road ready the *'arrogant azzhole from california' only made 502/905 with 5x13.8 and 64/71 stock head head bolts and gasket. dyno'd in 4th gear no correction factor dude did not flash the brake
dyno yours and see if ya can break 550
*werent those your words just a few short weeks ago?
DTanklage is offline   Reply With Quote
Old 10-08-2009, 07:03 AM   #14 (permalink)
flubyux2's Avatar
Just so you know, an s300 is just the class of the turbo. It's like the term "truck". The 3 is the chassis size and the last 2 numbers are the inducer size of the compressor wheel. So you need to categorize them as an s358 or s366 or s371, all being 58mm, 66mm and 71mm inducers respectivley. Bullseye markets Borg turbos in the gasser crowd and can be had in many combinations with various turbine wheel sizes and turbine housing a/r. So, these guys can't just call up and say "I want an s300" because he answer they will get is "uh ok, and what kind/size are you looking for"
at least, that's how it works where I come from over in the supra community. Btw, alot of the guys there who were running borgs have switched out because the turbos failed and could not get customer service to save their lives. And these are high profile shops and builders and/or sponsored race teams. So if these guyscant get help, the average Joe won't have a good time either.
1997 reg cab, super clean, low miles, done right. F/S or F/T. http://www.cumminsforum.com/forum/2n...low-miles.html
flubyux2 is offline   Reply With Quote
Old 10-08-2009, 12:47 PM   #15 (permalink)
phatboy07's Avatar
im dynoing my truck again at bartling enterprises(and the owner of the shop runs the truck), the same place i had it dynod last time with old setup....
100 plate FF, 5x12s, 3gsk, stock timing
Hx35 w/t boost elbow, cai, 4in str8 pipe, and good clutch
it did 373hp/948ftlbs that time with that setup. i just wanna break 500 mark this time... still gotta get her tuned for road ready. ohh and ported by local machine shop
whered you have ur fuel comin in at.... 1800rpm??? im afraid if i dump too much fuel in to early itll kill the spool up and be to smokey for the street. cuz i dont drag race my truck only street drivin.... unless i find some local dumbazz ricer to race
NEW BUILD UP.... 97 215 Pump
FUEL- 100 Plate FF, 5x14s, 4gsk, 18*
AIR- Volant CAI, 64/71/14, Porting, 4in STR8
Goodies- Studs, O-Rings, Guages, 13" Valair K/C Clutch, Black 7" Mitre
phatboy07 is offline   Reply With Quote
Old 10-10-2009, 03:12 PM   #16 (permalink)
broke
chevyboy123's Avatar
what about the garrett dual ball bearing turbos
95 dodge 5spd 4x4 a work in progress AEM intake
215 pump flows 500cc
330 plate
370 inj
5" straight pipe
chevyboy123 is offline   Reply With Quote
Old 10-11-2009, 05:18 AM   #17 (permalink)
DTanklage's Avatar
shoot, most the of the guys here can barely swing a hybrid or a b/w charger
the garretts are big money
really nice turbo but i dont know how the guys running them on the street justify the cost
why dont you make a chart for them and post it here?
Old 10-11-2009, 09:20 PM   #18 (permalink)
broke
well im not sure on the sizes but you can get the compessor maps at turbobygarret.com
the best i can tell a
stage 1 is comparible to a super b
stage 2=?
stage 3 is a touch bigger than super b special but spools faster
330 plate
370 inj
5" straight pipe
Old 10-13-2009, 01:06 AM   #19 (permalink)
J REED '98 6BT's Avatar
I like the map of the holset vgt. Wish I could hook it up.
11/97 2500 Club Cab 4WD NV 4500 3.55's # 11 Plate, 16* timing , 285/75/16 BFG M/T's 197,XXX miles... driver MIA ... trying to make a living in the new economy
J REED '98 6BT is offline   Reply With Quote
Old 10-13-2009, 10:21 PM   #20 (permalink)
turbo
Thanks to Dtank This got me thinking about the newest chargers. This works for the Wright bros. and alot more. P1V1=P2V2 is the Idea. Bernoulli's principle can be derived from the principle of conservation of energy. This states that in a steady flow the sum of all forms of mechanical energy in a fluid along a streamline is the same at all points on that streamline. This requires that the sum of kinetic energy and potential energy remain constant. If the fluid is flowing out of a reservoir the sum of all forms of energy is the same on all streamlines because in a reservoir the energy per unit mass (the sum of pressure and gravitational potential ρ g h) is the same everywhere.[4]( from wikipedia)
Somewhere out there is a charger that I need. Keep up the good work. and thanks again.
Old 10-13-2009, 10:50 PM   #21 (permalink)
cummins34's Avatar
currently i have a phat shat 62 an would like to like to go compound an dont really know which way to go. feed that ps 62 or let it feed a bigger turbo? im goin for quick spool, low end for the snap in a hard pull
00 dodge 2500 shortbed 4x4 5.9 cummins, NV4500, sb clutch, 120hp sticks, edge w/add, phat shaft 62, sg3 snow, ats horn, 3p ex man, 5in/dual 6in stacks w/aussie's, afe st3, raptor 150, levelin kit, 35MT's, ps stablizer, bada$$ bumper, more to come
cummins34 is offline   Reply With Quote
Old 10-16-2009, 01:30 PM   #22 (permalink)
Randall
DieselRacer75's Avatar
Holy CRAP Don!!!!!! You are giving some REALLY useful info!!! I really appreciate this. Oh and thanks for sending the pics!! I haven't had a chance to to tell ya.
96 CUMMINS 4x4, dynamite 150 injectors,(HTT 64/71/13 SS) ATS exhaust manifold, AFE cold air intake Dragon Fly pump 4kgs, full cut DV's, +60 Springs, 100 fuel plate, star wheel cranked, plate and AFC fwd, Suncoast tranny, lock in override switch, triple lock converter, 4" exhaust into a black miter cut 6" BIG THANKS TO UNDERGROUND DIESEL
DieselRacer75 is offline   Reply With Quote
The Following User Says Thank You to DieselRacer75 For This Useful Post:
DTanklage (10-16-2009)
Old 10-24-2009, 05:23 PM   #23 (permalink)
Talking B1-b Dimensions
Some more data for the chart. Took a look inside my B1-b while it off the truck for a head gasket R&R.
Compressor wheel measured 60.6mm with 7 blades.
Turbine wheel measured 65mm with 11 blades.
I'm kind of supprised at the comp wheel size, always assumed it was a 62.
97 12 valve, 542HP 1200+ ft-lbs, Daily Driver-Rocky Mtn Tow Vehicle
97Rebel is offline   Reply With Quote
Old 10-25-2009, 01:08 PM   #24 (permalink)
DTanklage's Avatar
it is really hard to accurately measure any wheel that has an odd # of fins
62/65
