| 94-98 Performance Parts Discussion Discussion of Performance Parts For the 94-98 Trucks No Advertising ...NO ADVERTISING |
Injector Chart
stock 2nd gen inj - vary depending on model but all are 145° injectors 49 state 160 hp - 5x9 .000318 49 state 175 hp 5x9 .000318 180 hp 5x9.5 .000354 160 hp cpl 1863, (actually a 180) 5x9.5 .000354 all calif trucks '96-98 were 180 hp = 5x9.5 .000354 215 hp - 5x10.25 .01025 .000412 300's and 330's same size - 4x12 = .000452 370's - 5x12 = .000565 155° spray pattern 435's - 5x014 = .000769 avail in both 155 and 145° spray pattern ddp stg III (90 hp) = 50 LPM (liter per minute) 155° 5 hole extrude hone inj <5x12 270 bar ddp stg IV (140 hp) = 66 lpm - 5 holes smaller than .0135 270 bar ddp stg 4plus - no longer avail now considered comp waiver must be signed to obtain ddp comp = 73-90 lpm depending on application same for pop all four start out as 155° marine nozzles and are extrude honed the flow numbers (lpm) i posted is what was printed on boxes that i received from ddp there are posts on other forums that vary slightly with these numbers measured the holes myself (.0135 gage would not go in a stg 4 ect) have not used 50 or 75 hp ddp inj - have no idea what size the holes are custom injectors - 5x.012 = .000565 5x13 = .000663 5x14 = .000769 7x10 = .000549 (24v conv inj are usually 7 hole) 7x12 = .000794 6x13 = .000795 5x15 = .000882 6x14 = .000923 5x16 = .001005 6x15 = .001059 7x14 = .001077 5x17 = .001134 6x16 = .001206 5x18 = .001272 6x17 = .001360 5x19 = .001416 6x18 = .001526 5x20 = .001570 ind inj super dragon flows (10 hole) - 5x10.25 + 5x18 .001684 6x20 = .001884 5x22 = .001900 5x24 = .002261 6x22 = .002280 5x25 = .002459 (this is what some refer to as a true competition injector) *i figured out the csa (cross sectional area) for ea injector. those numbers are in bold if you want to figure 24v stuff or something that is not on the chart use rē x pi x # of holes take the hole size divided by 2 times pi (3.14259) times the number of holes Last edited by DTanklage : 10-07-2009 at 07:20 PM. |
| The Following 4 Users Say Thank You to DTanklage For This Useful Post: | 98cummins4x4 (09-28-2009), DieselRacer75 (10-16-2009), jpthorpe1041 (10-04-2009), PVXCummins (10-08-2009) |
#2 (permalink) |
My stock 160hp injectors were 5 holes....
Silver 94 Dodge 2500 4x4 3:55 limited slip. Goerend TC/VB. #0, 4k, 191DV's, 215 injectors, 60/58/9 turbo, 4 inch exhaust |
#3 (permalink) |
yes, found out that they all are there is talk of only two p/n for the trucks .0102" (215) .0092 (all others) dont know for sure - i am just gonna leave it as it is Last edited by DTanklage : 10-01-2009 at 02:16 AM. Reason: only 2 diff inj? |
#4 (permalink) |
I thought all stock 12v injectors were 5 hole? I was thinking marine 300's were 4 hole, but i cant remember.
#5 (permalink) |
![]() Join Date: Oct 2008
my stock 215s were 5 hole
NEW BUILD UP.... 97 215 Pump FUEL- 100 Plate FF, 5x14s, 4gsk, 18* AIR- Volant CAI, 64/71/14, Porting, 4in STR8 Goodies- Studs, O-Rings, Guages, 13" Valair K/C Clutch, Black 7" Mitre |
#8 (permalink) |
Sweet I have another thread about this I was hoping someone would throw up some good info like this!
Silver 98 2500 Quad Cab long bed, 12 valve, NV4500. No cat, no muffler little AFC work no plate, little timing, KDP victim now tabbed. Soon to have 2001 cab with all the options and a new color! |
#9 (permalink) |
Right from Weston Don. 160-175hp - 5x0.009" 260BAR 180hp - 5x0.0095" 260BAR 215hp - 5x0.010" 260BAR 300 Marine - 4x0.012" 262BAR 370 Marine - 5x0.012" 262BAR The automotive spray pattern is 145° and the marine spray pattern is 155°, non-intercooled engines with 9mm nozzles have the 155° bowl piston, all intercooled engines with the 7mm nozzles have the 145° bowl piston.
97 ECLB 4x4, , UNDER CONSTRUCTION |
#10 (permalink) |
there was another thread with the list too..... i have 8 hole injectors in mine and im stepping up to a 15 hole injector this winter
Dustin - 95' 12 Valve, RCLB, 4x4, 5" exhaust, manumatic billet tranny, nice gate shifter ....more fuel and a larger turbo coming soon....
CG DIESEL PERFORMANCE - - - - - - - - - - - - - - - OHIO COAL ROLLERS |
| The Following User Says Thank You to Hightech_Redneck For This Useful Post: | bengump (11-16-2009) |
#11 (permalink) | |
![]() 5 hole injectors with the right hole size will flow plenty. I havent even seen 8 hole injectors for a 12 valve, and definately not 15 holes. Eric
#12 (permalink) |
the shop i go through has them..... they smoke less than my marines and boy the power is awesome..... and i will tell you this.... they are cheaper than everyone elses..... and yes i counted the holes twice cause i thought it was crazy too and i will tell you they are.... my egts are at 1500 to the floor but thats before the delivery valves....
