| 94-98 Performance Parts Discussion Discussion of Performance Parts For the 94-98 Trucks No Advertising ...NO ADVERTISING |
#2 (permalink) | |
Had:24v. Little of this and that 09 6.7l S&B CAI EGR deleted 5" TBE Smarty Boost, Egt, Fuel ISSPROS now accepting donations to the po boy fund!
#3 (permalink) |
My truck sounds just like that, if my turbo is spooling good like he is and I let off the pedal it makes that exact noise, not sure if it's very good on the turbo but that is the noise it makes.
98' 2500, 12-Valve S.B. 170K, BHAF, 4" str-8 exh. Gauges, DTT Trans. TQ-Lock Up, #100 Plate, 90-HP Injectors, 16.5* Timing, HTT 62/12, 4K GSK, HID'S, Bilstein 5100's. |
#4 (permalink) |
that is the sound of turbo whistle and then turbo bark as he lets off..... i can make mine bark with ease, but i try to avoid it
96 2500 CC LB 4x4: BD 47RE/Flexplate/TC, 4" MBRP, S362/65/12, BHAF/K&N tube, #10, AFC tweakd, 4gsk, 60# springs,125ft/lbs. headbolts, 16°, Gauges, Lift'd 6"/Ladder bars, Dana 80 w/ disks
#5 (permalink) |
doesn't look like he has a hood stack so what came out of the area?
candy my diesel. she cost lots of money, i like it when she's dirty, and allway's get's the job done. just like a stripper. 95 cummin's 2500 3in body and 3in sep. 38in toyo and 16x10 rims. 100hp fuel plate. more to come. |
#6 (permalink) |
Are you talking about the wastegate blowing off the poof poof poof all you have to do is floor it for 2 seconds then let off the throttle
02 2500 4x4 Laramie pkg. mbrp 4 inch stainless turbo back exhaust. Edge juice with attitude. K&N cold air. Fuel Boss mechanical fuel pump.
#7 (permalink) |
if its the whisle sound you want pull the sinlencer ring on the turbo and get an intake
98 12 valve 5 speed, autometer pyro, fuel, boost, 100 plate ff, afc spring, 4k gov springs, 60 pound hd valve springs, 4" sliverline, airaid intake, arp studs, s300 62/14, 90 hp ddp sticks, 18*, snow water/meth, 75hp shot of nos, kdp vic
#8 (permalink) |
You dont want to make your truck sound like that its the turbo stalling to much of that especialy on a stock turbo and you will break the shaft
97 12 valve HX40/HT60 Twins, 0 plate FF, 2095 plug, AFC tweaked , 4k gov, 16*, Weston's 5X.014s, 5in from turbo to stack, Twin Ram, HTT manifold SB 3250 DD Gauges up the wazoo. |
#9 (permalink) |
lol no its not all he did was install a blow off valve in the cold pipe and vent it to atmosphere if ya ask me those things are gay unless you cant drive and are constantly lifting instantly when makin full boost build a nice set of twins for your truck...then it will sound like that (better actually) and rightfully so *i just watched it again...do you think it pushed a boot off or something? not sure what it was now... Last edited by DTanklage : 08-14-2009 at 09:22 PM. Reason: not sure |
#10 (permalink) | |
#11 (permalink) |
Banned
if your making your tubo do that when you let off with out a blow off valve it is bad. you will break the shaft then not look so cool and a bit spendy to fix |
#12 (permalink) |
Wow ! Just WOW ! .................................................. . Pretty neat BOV .....
97' 12v... II PhatShaft 71/74/16, II Dragon Flow 5x.018's, #100 plate, DDP .024 DV's, 4K GSK, 60# Springs,5" S&B Intake, 4" MBRP, Air Dog 150, & NOS.. Special Thanks to Kortney, And Toxic Diesel (546hp) 11/10/09 |
