4K gsk kit instructions - Dodge Cummins Diesel Forum
post #1 of 11 (permalink) Old 08-08-2009, 02:44 AM Thread Starter
Casper's Avatar
Does any have a guide to installing a 4k gsk? i got the kit from pdr diesel but the instructions are totally unreadable because its a really light crappy photocopy.
95 F250 12V 215 P-pump, 62/65/12, SDX5x12's, kdp done, afc spring kit+tuning, 100plate, 16*timing, 60lb int/exh springs, ats exh housing, 4k gsk, sbc zf5, dana 60 kp swap, 4"exh, 2 tank plantdrive wvo kit.
Casper is offline
post #2 of 11 (permalink) Old 08-08-2009, 10:16 AM
OSUdiesel's Avatar
http://www.pacbrake.com/PDF/L5658.PDF
I am installing mine today also!
2011 Ram 2500 Laramie 4x4 G56 - South Bend DD, Flo Pro 5" SS, Hushpower Muffler, 6" Flo Pro Tip, ARP 625+, H&S Mini Max w/NorCaler Tune, Edge CS, H&S Full Delete, S&B Intake System, Cooper AT3 315 Tires.
OSUdiesel is offline
The Following User Says Thank You to OSUdiesel For This Useful Post:
Casper (08-08-2009)
post #3 of 11 (permalink) Old 08-08-2009, 11:09 AM
kiohio's Avatar
A little trick that helped me......
After almost completely loosening the nut I used a long thin (less than 1/8") drift pin punch and held it against the stud.
Then I finished loosening the nut and pulled it onto the punch with my pencil magnet.
I continued on pulling everything else out the same way.
When putting it back together I did it the same way.
It gave me peace of mind to have something other than my magnet holding stuff from dropping into my pump.
KO
'96 4x4 EC Goerend-Triple Disc TC-Auto-4.10's-305/70 Terra Grapplers-909's-5" Grand Rock to da bumpa-Custom Injectors-HTBG 14cm-4K-GSK -19*-Fire Ringed-Titanium crap here and there-ATS 3pc-
If I have something for sale it's always "First come, First serve", been burnt too many times...Sorry.
kiohio is offline
post #4 of 11 (permalink) Old 08-08-2009, 01:06 PM
TheSh111t's Avatar
On the same topic kind of. I installed a 4000 GSK in my truck yesterday afternoon (Very simple install by the way. In the instruction it said to remove all of the stock inner springs, the factory lower seat and Any shims I could not see very well through the hole, and I tried to stick my magnet in there to pickup any shims that may be in there but I could not find any. How common is it that there will be shims in there? If there are shims in there what is the easiest way to get them out? I couldn't find any so I'm pretty sure there were none. I installed the new springs and everything went back together fine. But it is kinda in the back of my head that I may have left a shim in there that I could not see. Any suggestions?
1981 Chevy Short bed 2WD - Cummins swap:
1995 12v, NV4500, s362/s475 twins, PDI manifold, #5 fuel plate, 181 Delivery valves,
5" exhaust, 2095 plug, 60# springs, 4000 GSK, AFC springs, 17* Timing, 5x12 inj.
TheSh111t is offline
post #5 of 11 (permalink) Old 08-08-2009, 05:51 PM Thread Starter
Casper's Avatar
sweet apple man, those instructions are good. do they ones for 60 lbs valve springs or afc spring kits?
Casper is offline
post #6 of 11 (permalink) Old 08-08-2009, 07:07 PM
OSUdiesel's Avatar
Here is another posting on here dealing with the valve springs:
installing 4GSK and HD vale springs??
Here is one for the exhaust springs:
http://pacbrake.com/PDF/L5930.PDF
Or go to this which is the same thing:
Valve and Gov spring installation
Here is one for the AFC:
Installation Instructions
Here is a general information one:
Diesel Database :: Your Source For Diesel Technical Information
Fritz's Dodge Ram Tech
post #7 of 11 (permalink) Old 08-08-2009, 07:33 PM
kiohio's Avatar
Mine didn't have any shims in it. Neither of them.
KO
kiohio is offline
post #8 of 11 (permalink) Old 08-08-2009, 09:14 PM
OSUdiesel's Avatar
I did pull one small shim that was under the medium spring. I have the 96 215 pump if that makes any difference.
post #9 of 11 (permalink) Old 04-06-2013, 12:26 AM
wgr73's Avatar
Good 4GSK thread!
Holy Grail - Coming soon
4x4, Laramie, 4GSK, AFC Mods, Stock exhaust, KDP Tabbed, OFV, 4.10s, 285s on 3rd Gen wheels, Autometer Boost/Pyro, NEED TO INSTALL : Nothing for now
wgr73 is offline
post #10 of 11 (permalink) Old 04-06-2013, 03:43 AM
VP of the dry side
cumminsrulez's Avatar
Some trucks don't have shims. My one buddy and his dads truck didn't have any. But mine and another buddies I did had them. Just depends
97,2wd, auto swapped, Moss Green, 211k, s&b,4in with muffler stock tip
(stealth mode engaged
) ,afc mods, kdp,egt boost fp dp,22*,Haisley 5k gsk-60pounders,traction bars, A1 studs+Oring'd block, P&P, A1000 custom fuel setup,5x.018 SAC 145* 300 bar,.025 dvs, 64.5/68/.83 t4 sxe 50mm jgs gate/w screamer pipe
Originally Posted by dvst8r View Post
Dying is always a way bigger concern than egt's...
cumminsrulez is offline
post #11 of 11 (permalink) Old 04-08-2013, 08:02 PM
Threw in my new 4K springs in today also......
I had one shim (super thin circular spacer) on one side, and none on the other. The one was under the big spring. Definitely have to dig to make sure.
98 2500 QCab 2X4 12v 225K+ 47RE,Stock Air box,#10 Plate,AFC Mod/Tuned,Boost Blocked,4K GSK,Tork Tek OFV,Stock Timing,FHD,KDP Tabbed,4" Cat back,GlowShift Gauges,Billet Single TC,Built Trans w/Shift Kit,Euro HID/LED,Bilstein Next:Intake Horn,S&B,60# vs,16*
Bluedodge98 is offline
