| 94-98 Performance Parts Discussion Discussion of Performance Parts For the 94-98 Trucks No Advertising ...NO ADVERTISING |
new turbo is on but I need to bring down egts
Hi I just finished putting my new turbo. It is a borg warner s300g. I am running 204 dvs, bosch 370s, 3k gov springs, k&n intake, and a custom fuel plate. I like the power that I am getting, except the slow spooling, but my egts are getting hot when I get on it. They start climbing up to 16000 than I let off. I was wondering what I can do to keep down my temps a little bit. I was thinking about a intake manifold, ow much will this help? I plan on swapping out the 370s for some ddp 140s but that wont be for a while, will that help alot? thanks Patrick |
#3 (permalink) |
Diesel Auto Power
![]() Join Date: Feb 2006
your turbo is a bit on the small side to run WOT and stay cool. Water meth will help. going to bigger Injectors will get you hotter the 370HP are about 90HP over stock if I recall correctly. If you got marine 370 they are the wrong spray pattern and will run hotter and less efficient when compared to a 370 edm'd for dodge pistons. a 3pc exhaust manifold will bring temps down about 50 degrees. you may also have too aggressive fueling curve on the fuel plate. has your timing been adjusted? btw you have 1 too many zero's in your EGT #
www.DieselAutoPower.com Call Jacob at 951-377-4844 for best pricing SUPER DEALS on Injection pumps, Turbos, Injectors & Programmers SUMMER SPECIAL--8% off after REBATE(up to $200 off per transaction.) When you buy from me on Ebay and pay with paypal you will receive an 8% rebate from Ebay in 60 days. Call me for rebate coupon code or questions. Example: Buy VP44 for $1000- 8% Rebate of $80= $920 after rebate |
#4 (permalink) |
I would bump the timing to about 16* if you havent advanced it already. Eric
Silver 94 Dodge 2500 4x4 3:55 limited slip. Goerend TC/VB. #0, 4k, 191DV's, 215 injectors, 60/58/9 turbo, 4 inch exhaust |
#5 (permalink) |
whats the specs on that s300? Sounds like its time for something bigger.... Bump the timing up, that will help. Porting + a manifold will also help. air in and air out = happy EGTs. Any for of an air intake system will help over the stock airbox/filter (flows a measily 140cfm) Which pump are you running?
97 Ram 2500 / 5.9ctd / 5spd / nv4500 / 4x4 / np241 Home made intake and BHAF, AFC tweaked, custom plate, autometer pyro and boost gauges, Dual 4" stacks, 33x12.5 Mud terrains, posi-lok, tons more to come
#6 (permalink) |
Diesel Auto Power
s300g is usually 57/65/14.
#7 (permalink) |
Here is a bump for ya cause i actually have a very similar issue, but i adjusted my wastegate and it seemed better for a few days but not now so
98 RAM2500 AUTO 4X4 12 VALVE!!!!!BHAF, FUEL PLATE AND AFC FORWARD, HOME GROUND 100, s300/s400 TWINS, A-METER BOOST PYRO AND TRANS, 5" INTO 6" MITRE CUT STACK, SILENCE RING GONE ATS CONVERTER AND BUILT TRANS KDP tabbed-timing 16 deg-3GSK, stage 2 injectors |
#8 (permalink) |
Those 204 dvs seem a little large, you could go with a set of 181's or 191's. That may help some too. Ive seen some people make some big power with 181's even
1996 2500 4x4, HX35+HT60,#10 Full Forward, 3000 GSK, 18*, DDP 191's,5x.012's, Modified AFC,5" Hood Stack, Home Made Traction Bars,Autometer Ultra Lite II Gauges,Auto to Manual,Valair 12 1/4" 3800# Ceramic, 3.54:1 Gears. |
#9 (permalink) |
ok thanks everyone. I am going to try to adjust the timing. Anyone know of any good writeups to help guide me through this as I have never doe tis before. thanks. ansd I already have the air intake. I was talking about the intake manifold. will this help cool it a little? thanks
#10 (permalink) |
CumminsDatabase.com :: P7100 Injection Pump Timing you will need a special tool to do it
1979 Plymouth TrailDuster 94 cummins turbo/47rh/np205/ d60 front and rear http://www.cumminsforum.com/forum/cu...uster-ctd.html |
#11 (permalink) |
You can do it with basic hand tools but your timing isnt going to be very accurate... Your best off trying to get you hands on a dial indicator, if not the proper one, you can make a holder for any 'long' dial indicator using an oil pan plug. search around for info on that
#12 (permalink) |
I used an magnetinc base for the dial when I did mine.
97 12 valve HX40/HT60 Twins, 0 plate FF, 2095 plug, AFC tweaked , 4k gov, 16*, Weston's 5X.014s, 5in from turbo to stack, Twin Ram, HTT manifold SB 3250 DD Gauges up the wazoo. |
