Old 06-29-2009, 10:21 PM   #13 (permalink)
Stump Jumper's Avatar
Originally Posted by ykdave View Post
ill see if i can come across it again but i have stumbled across some cummins/holset literature a few months back showing the available 'options' for the different series of turbos (it was the HX series i was looking at)
That would be great
97 12 valve HX40/HT60 Twins, 0 plate FF, 2095 plug, AFC tweaked , 4k gov, 16*, Weston's 5X.014s, 5in from turbo to stack, Twin Ram, HTT manifold SB 3250 DD Gauges up the wazoo.
Stump Jumper is offline   Reply With Quote
Old 06-29-2009, 10:35 PM   #14 (permalink)
Originally Posted by Stump Jumper View Post
how much do you want for it?
PM coming buddy
1997 Dodge 2500 4x4 Ext cab LB 5 Speed, K&N BHAF, 5 inch turbo back , plate MIA, AFC tuned, bd 64/71-14, SDX 5x16s, boost elbow, 4K GSK, ARP head studs, oringed head, valair 13" full feramic clutch, autometer boost and pyro.
derek528 is offline   Reply With Quote
Old 07-04-2009, 02:42 AM   #15 (permalink)
While searching for turbo parts I found this can get good info here
http://melett.com/turbo-parts-catalo...HX40-HX40W.pdf
Old 07-04-2009, 03:51 AM   #16 (permalink)
ykdave's Avatar
that looks pretty close to what i had found before
97 Ram 2500 / 5.9ctd /NV4500/241DHD
Custom Intake Tube+ BHAF, Pump Tuning, Autometer Pyro and Boost gauges, Dual 4" stacks, 33x12.5 Mud terrains, posi-lok, One Hella sound system, tons more to come
ykdave is offline   Reply With Quote
Old 07-05-2009, 07:57 PM   #17 (permalink)
Originally Posted by derek528 View Post
You just have a hx40 with a 16cm housing. That is the best spooling hx40 available. A hx35 housing will not fit on a hx40 FWIW.
Your info is not corect. Although very rare and hard to find there is A 12cm housing to fit the HX-40 and I do have A place to purchase A 14cm wastegated housing for the HX-40. These are genuine Holset parts but by the time You buy the turbo and then another $500 for the turbine housing it would be easier and cheaper to order A Switzer from HTT in the configuration You needed to begin with and have A more durable unit also.
99 qc lb 4x4 auto almost stock.
macaw is offline   Reply With Quote
Old 07-06-2009, 03:28 PM   #18 (permalink)
Did holset ever make a hx40 with a 12 or 14cm housing or do you have to piece one together?
Old 07-06-2009, 03:36 PM   #19 (permalink)
They did make them but are very rare.
