hx35/hx55 for twins??? - Dodge Cummins Diesel Forum
post #1 of 21 (permalink) Old 06-27-2009, 09:14 PM Thread Starter
Just wondering if any ones used this set up befor and how it works??? hx35 12cm/hx55. Thanks
Corkys12valve is offline
post #2 of 21 (permalink) Old 06-29-2009, 11:11 PM Thread Starter
Anyboby have an idea??
01 ext/lnbx 4x4 6 speed, P-Pump 24valve, Being built.....
post #3 of 21 (permalink) Old 06-29-2009, 11:15 PM
ykdave's Avatar
The 12cm housing on the HX35 is not going to be the best thing you could use (its super restrictive, the main reason for not running the HX35 over 35psi because the turbine housing is reaching its choke point, the compressor is still good for a bit more boost)
A bit bigger turbine housing on the 35 and you should have a decent set of mild twns
What size turbine housing is on the 55?
ykdave is offline
post #4 of 21 (permalink) Old 06-29-2009, 11:23 PM
Stump Jumper's Avatar
I remember seeing some one on here running or ran this set up I think it was shelbuilt or something like that.
97 12 valve HX40/HT60 Twins, 0 plate FF, 2095 plug, AFC tweaked , 4k gov, 16*, Weston's 5X.014s, 5in from turbo to stack, Twin Ram, HTT manifold SB 3250 DD Gauges up the wazoo.
Stump Jumper is offline
post #5 of 21 (permalink) Old 07-01-2009, 07:15 PM Thread Starter
Its big i think its 33cm. but not sure because i cant fing a hx55 with that big of a housing. the biggest iv seen on the internet is 29. i was told its 33cm.
post #6 of 21 (permalink) Old 07-01-2009, 08:57 PM
Look on the inside of the runner on the housing the size should be stamped in there.
post #7 of 21 (permalink) Old 07-02-2009, 01:08 AM Thread Starter
Ya it says 33cm. that too big u think??
post #8 of 21 (permalink) Old 07-02-2009, 01:15 AM
ykdave's Avatar
You will definitely need alot of fuel and rpms to light it up with a housing like that
ykdave is offline
post #9 of 21 (permalink) Old 07-02-2009, 08:37 AM Thread Starter
think it will have lots of lag??
post #10 of 21 (permalink) Old 01-02-2011, 01:17 AM
osr1's Avatar
Can we fire this thread back up? Looks like it's the closest I can find in my searches to an anwer about exhaust housings and using my hx35/55 setup for compounds. I'll have to look at my 55 to see what the housing is. From what I've searched it looks like the stock hx35 housing is too small? Where can one larger be bought or what app did they come on? Thanks again to all.
2X 1996 F-350 crew duallies. One up, one down. Lifted truck --> 95 5.9 triples, 5k, Auto
osr1 is offline
post #11 of 21 (permalink) Old 01-02-2011, 01:22 AM
ykdave's Avatar
yes, the factory housing is a 12cm3. unless you run an external wastegate to dump drive pressure around it, you will want a larger housing. Lots of diesel shops sell 14 or 16cm3 turbine housings for them. as far as applications, look around for a high hp industrial as i have seen them with fairly large housings.
ykdave is offline
post #12 of 21 (permalink) Old 01-02-2011, 01:25 PM
osr1's Avatar
Yes external will just be more work. So, 14 or 16 which is best for my auto application? Limited street, weekend puller.
osr1 is offline
