Old 02-09-2007, 06:31 PM   #1 (permalink)
cummins freak's Avatar
re-torque on stock head bolts?
how much boost will my stock gasket handle with a re-torque and to what lbs/ft do i re-torque the factory bolts to thanks
right now i have the stock hx-35 but will soon have a killer b2 on
1997, 2500 CTD. 4x4 LWB, ext cab, MODS-#100 plate, JL Machine 5x0.016 Injectors, 3kgsk, timing at 16*, Dave G. trans, , HTT killer B II 64/14, Custom DV's from weston!!! Mods soon to be- traction bars,head studs, marine gasket.
cummins freak is offline   Reply With Quote
Old 02-09-2007, 07:18 PM   #2 (permalink)
DieselDood's Avatar
You can't retorque the stock head bolts. They are a torque to Yield design. You torque them 66, 89, then turn them 90*. If you are going to do anything replace them with studs.
DieselDood is offline   Reply With Quote
Old 02-09-2007, 07:32 PM   #3 (permalink)
well then is my only other option to get head studs to increase the clamping force
Old 02-09-2007, 08:07 PM   #4 (permalink)
DieselDood's Avatar
Studs are the only other option.
Sorry!
DD
Old 02-09-2007, 08:29 PM   #5 (permalink)
thats ok how well do you think studs and a0.020 marine gasket will hold or how about studs and my stock gasket thanks
Old 02-09-2007, 09:56 PM   #6 (permalink)
DieselDood's Avatar
I think...(ok I won't lie..I know) that Studs and a stock gasket won't hold what I do to my truck. I blew it out between 4 and 5 cylinders.
Will they get you bye for now...yes. Will they last forever? No. I'm hard on headgaskets for some reason...mine made it 3,200 miles before I popped it again. (I'm on #5 now, and I've finally gone to fire rings)
DD
Old 02-09-2007, 10:03 PM   #7 (permalink)
is this josh peters....also how much timing you running on your truck i really dont want to run more then 17-18*
Old 02-09-2007, 10:14 PM   #8 (permalink)
DieselDood's Avatar
Yes this is Josh Peters.
Timing, with that gasket I was at 17*
JP
Old 02-09-2007, 10:17 PM   #9 (permalink)
thanks this is kyle you helped i should say did my timing, plate and gauges in anoka we couldn't get my turbo bolt loose you were on the wall trying to push down
and dang only 17* well thanks thanks that helps
Old 02-09-2007, 10:30 PM   #10 (permalink)
DieselDood's Avatar
Ahh yes!
When I popped that gasket I wasn't running a ton of timing. Really, for a street truck you don't need a ton of timing either. 17-18 is MORE than enough for street use. You'll run into lag issues as well as starting issues in the cold if you go much higher.
Being I have the tools, in the summer I'd set mine to 17, 15 in the winter. Dyno day, pull or Drag race, 18.5 or so was the sweet spot for mine. But it was laggy on the bottom end on the street.
JP
Old 02-09-2007, 10:52 PM   #11 (permalink)
mine is still where we set it at 15.5* and it seems to be a good spot for the street and its more then likely going to be fast enough for me once i get my htt 64/14 killerb2 on and my tranny in
Old 02-10-2007, 12:29 AM   #12 (permalink)
zstroken's Avatar
You can retorque them. We are pushing 55psi through a24V and ran my12 for half of a pulling season at 55psi with 18 degrees timing. We torqued them to 120 ish cold if I remember right. Don't expect this to last forever, just to get you by.
B&B performance: Industrial Injection, HTT, EDGE, Bully Dog, BD, South Bend Clutches
zstroken is offline   Reply With Quote
