how to install 4k GSK and pump delivery valves and holders? - Dodge Cummins Diesel Forum
post #1 of 7 (permalink) Old 03-17-2009, 04:36 PM Thread Starter
dieselfury's Avatar
how to install 4k GSK and pump delivery valves and holders? Is there any videos or good write ups on how to do it because we need to know how for our drag truck??? btw we are running 5x16 injectors so what kind of timing would go good for it and whats the easiest way to time it? Thanks
2011 F350 6.7 2005 VW TDI with sunroof 51mpg 02 4x4 auto quad 4K Box,air dog 150, super b special, bd rad, full billet tranny, 200hp injectors, midwest vp pump<<<Sold.... 01 5sp pulse/adrenaline, airdog 150,valair, 150's FBD,leveled...Sold
dieselfury is offline
post #2 of 7 (permalink) Old 03-17-2009, 09:56 PM
12valveterror's Avatar
iTrader Score: 9 reviews
CumminsDatabase.com :: Governor Spring Kit
CumminsDatabase.com :: P7100 Injection Pump Timing
you could go really go anywhere from 16-20ish even more if you like...
DV Install(this came from another site i didnt write it..fyi)
List of required tools:
1. " open end wrench
2. 10mm socket
3. 7/16 deep socket
4. Delivery valve socket ( Special socket. Can be bought from PDR if needed. )
5. Torque wrench
6. Needle nose pliers
7. Dental pick ( for easier removal of gaskets-not required on most pumps )
Procedure:
1. Clean engine and pump area with cleaner and compressed air. Be sure to wear safety glasses. Cleanliness is very important.
2. Remove tin Valve cover and air intake horn and wires going to intake heater grid.
3. Remove injector lines. Keep lines together, unbolt clamps (two) where they connect to the cylinder head.
4. Do one barrel at a time. Use special socket to remove the barrel from the pump. Carefully lift out the barrel taking care not to drop spring and seat. See figure 2. Each seat is shimmed to that particular barrel. Do not mix up.
5. Use a pair of needle nose pliers and pull out the delivery valve.
6. Next pull out the delivery valve holder.
7. Some older 160hp pumps have copper gaskets under the delivery valve holder. See figure 5. Remove the gaskets. These are no longer used with your new delivery valves.
For most pumps which do not have gaskets,
8. Remove delivery valve from wax wrapping. Make sure its clean. Install the new valve into pump, as it was shipped. Install new o-ring from kit onto the barrel.
9. Now install your spring and seat assembly into the barrel, carefully install the barrel and spring and seat assembly back into the pump.
10. Tighten the barrel until it lightly seats in the pump.
11. With a torque wrench, in one smooth motion - torque to 85ft/lbs.
12. Repeat steps 4-11 on remaining barrels.
13. Reinstall injection lines, tighten lines on the pump, leaving the ones on the injectors finger tight
14. Replace wires to the grid heater.
15. Install air intake horn and tin valve cover
16. Attempt to start the engine. Do not crank engine for more than 20 seconds before allowing starter to cool for 2 minutes. Repeat this procedure once or twice more until you see some fuel at the injectors.
17. Tighten lines at the injectors. Go ahead and start the engine. Engine may run rough for a few seconds, then should smoothen out. Shut engine off, clean up any fuel leakage, restart engine and check for any leaks
Engine: Mahle "Marine" Pistons, Balanced Rotating Assembly, ECD Cam, O-Ringed Block, Ported/O-Ringed Head, 3 Angle Valve Job, ATI SuperDamper
Fuel/Air: 475cc P-Pump, 5x.014's, Airdog 150, BW 66/68/14
12valveterror is offline
post #3 of 7 (permalink) Old 01-12-2012, 02:32 AM
How do u install 4k gsk??
Cummins199512v is offline
post #4 of 7 (permalink) Old 01-12-2012, 03:02 AM
Did reading the previous link in the post not help?
Maxed 12mm pump, nv4500 w/ Valair DD, 35'' BFG on 3rd Gens, S300 Borg Warner, 12mm ARPs, BHAF, A-Pillar gauges and bad case of ITS
DC9612V is offline
post #5 of 7 (permalink) Old 01-12-2012, 03:50 AM
Link no good
Btw anyone with some marine injectors hit me up! Please
post #6 of 7 (permalink) Old 01-12-2012, 11:21 AM
jplasse's Avatar
Timing Specs http://dieseldatabase.com/p7100-plunger-lift-timing/
How to Timng: http://dieseldatabase.com/p7100-injection-pump-timing/
Governor Spring Kit Install:http://dieseldatabase.com/12v-cummin...or-spring-kit/
CUMMINSDATABASE.COM is now DIESELDATABASE.COM
08 2500 QCSB, 4x4 leveled, 20x12's and 33's, vinyl B pillars, amp research steps
96 2500 12V CCLB, 4x4 SOLD
jplasse is offline
post #7 of 7 (permalink) Old 01-12-2012, 11:22 AM
jplasse's Avatar
Sorry double post... puter F'd up
jplasse is offline
