Old 03-02-2009, 03:39 AM   #1 (permalink)
Banned
Running No Plate
It came to my attention that there are many myths concerning pump failures and the rack hanging while using no fuel plate. First off this is false, there are many reasons for a rack to stick or a pump failure, but not using a fuel plate is not one of them. The following pictures show an RQV-K governor being disassembled. As you can see there is no "pin" that can break due to not running a fuel plate.
Don Wagner is offline
The Following 2 Users Say Thank You to Don Wagner For This Useful Post:
diesleboy (11-05-2009), SUPERDUTY5.9 (10-18-2009)
Old 03-02-2009, 03:45 AM   #2 (permalink)
cursedtofirst45's Avatar
Thanks Don.
Ive always thought that if people could see how these pumps work and could see inside one, we'd have less of those threads.
1997 Dodge 2500 Cummins/Nv4500.
Project Yeti II 12v Sleeper
ACDC "No Box or Bottle, just Balls and Throttle"
cursedtofirst45 is offline
Old 03-02-2009, 03:46 AM   #3 (permalink)
Banned
When running without a fuel plate the governor lever will still contact the AFC lever. If the lever is modified for extended travel the limiting factor will be the rack plug no matter it being the stock 2000 plug or the 2095 plug which is 2mm deeper.
Front rack stop.
Rear rack linkage.
Old 03-02-2009, 03:48 AM   #4 (permalink)
Banned
As far as a runaway condition, the sliding bolt(pic#3 post#1) pulls the governor lever back limiting RPM. There is no way to "over extend" the rack also since either the AFC lever or the rack plug limit rack travel.
Old 03-02-2009, 04:27 AM   #5 (permalink)
Banned
1. fuel plate
2. rack
3. governor nut
4. governor spring
5. flyweight
6. governor rocker
7. control lever
8. plate cam
9. guide block
10. governor lever
11. sliding block
12. bell crank
13. sliding bolt
14. guide lever
Old 03-02-2009, 04:30 AM   #6 (permalink)
smkstk's Avatar
very nice post, about time we get one of these, but i'm partial to tune the truck with the plate still. good write up
Global climate change is natural phenomenon, exploited by the unscrupulous, for political and monetary gain.
smkstk is offline
Old 03-02-2009, 11:41 AM   #7 (permalink)
schaef_12's Avatar
Please make this a sticky, so the No fuel plate threads can finally come to and end!!
1998 2 Tone 12 valve Club Cab SWB, Helix II, PDP head ported polished, fire-ringed, 5 angle back cut valves,60lb springs, Custom plate forward, DDP4's, sps62, ATS 3-piece pulse manifold, ceramic clutch, 913 pump, 5" Skyjacker with 35X12.50 Toyo's
schaef_12 is offline
Old 03-02-2009, 12:25 PM   #8 (permalink)
This is slightly off topic, but what is the best way to verify that you are getting full rack travel when modifying the AFC lever?
mondtster is offline
The Following User Says Thank You to mondtster For This Useful Post:
popsat4t (09-02-2009)
Old 03-02-2009, 03:50 PM   #9 (permalink)
Banned
The best way to verify full travel is measuring rack travel through the front rack plug with the AFC installed, the pump needs to be removed to accomplish this.
Old 03-02-2009, 11:33 PM   #10 (permalink)
ykdave's Avatar
about time we had a good post like this!
97 Ram 2500 / 5.9ctd /NV4500/241DHD
Custom Intake Tube+ BHAF, Pump Tuning, Autometer Pyro and Boost gauges, Dual 4" stacks, 33x12.5 Mud terrains, posi-lok, One Hella sound system, tons more to come
ykdave is offline
Old 03-03-2009, 12:59 AM   #11 (permalink)
Sasquatch
crazyrunner33's Avatar
Already took out the plate this morning for my first mod since I don't have any access to a bench grinder yet.
'99 Cummins: too many mods to list
Some tips on using the search function for better results.
crazyrunner33 is offline
Old 03-03-2009, 01:09 AM   #12 (permalink)
Cummins35.9's Avatar
Finally no more explaining...
1988 gmc 3500 12v, GT3788 BB, 3pc mainfold, SB 3600# 12CB DD, Cmp p-pump(440ccs), 191s, 4gsk, no plate, 2095 plug, 18* timing, 60gph pump, #60 springs, 5x0.17 sticks, Afe pro dry, 7" Bullhaulers, Glowshift, 453hp 1007ft/lbs
Cummins35.9 is offline
