1993 W250 5 speed, full 3.5" exhaust, asa intake, boost pyro gauges, custom front bumer with 12,000 pounds warn winch. soon to be installed : bosch 190's, south bend 350hp clutch, Governor spring
My first thought was the heater core, too. I've had to do this a couple times on my wifes Bravada to check for the heater core clogging up...the theory still applies to ours. Open the hood and locate the hoses that go through the firewall to the heater core. There will be two of them. Once you know which hoses your looking at, start the truck to warm it up. As the truck is warming up, you are going to want to start feeling the hoses periodically for them to increase in temp. If both hoses are getting hot, then more than likely the heater core is not clogged, or at the very least has some flow going through it. If one hose is getting hot and the other is still cold, then you got a clog. It's easier to feel a difference if you do this test when the engine is completely cooled down, like over night. If it is clogged, then post back what you felt and there may be a couple options you can do without having to take it somewhere to have fixed. Like I mentioned above, I've had to deal with this several times on my wifes Bravada and have tried a few things that work.
'97 Dodge Ram 2500 4x4 12 Valve, 215 Pump, 16 deg Pump Timing, NV4500 5-speed, ISSPRO Gauges, #10 Plate, AFC Spring Kit, Amsoil #4510 BHAF, 4" Turbo Back Exhaust, KDP more to come...
You have several options. On my wifes Bravada, I've been able to grab the hose that exits the heater core and start sqeezing. Do this with the engine off btw. This forces fluid back through the core and sometimes breaks lose clogs. Sometimes it takes a couple tries. Start the engine and see if it worked. If it didn't, try it again. If that didn't help, and another thing I had to do to the wife's truck once, was disconnect both hoses and hook up a garden hose to side that exits the heater core...the hose that felt cold. Then you turn on the water and back-flush the core. This particular technique was the last time I had to do anything to the core for probably 3 years now. There is a kit to do this that can be found at places like advance auto. Or, you could do what I did and duct taped the garden hose to it...I was in a rush and it worked. If none of this helps, then you will either have to have the heater core professionally flushed or replaced. Both are rediculously expensive at the dealer. I would just try to back-flush the system several times myself.
yea if ur standin in from of the truck
if ur heater core is plugged up i would seriously consider a coolant flush your coolent should b changed ever 2years or 30k miles u most likly have sediment built up in the radiater and water pump also not to mention your block
andrew stein, 92 D350 a bunch of
94 2500 cummins 12v 5spd 4wd bosch 370's....hx 40 right now
