Old 09-21-2008, 02:14 AM   #1 (permalink)
KKRRSS's Avatar
Sport headlight conversion
I am going to convert my stock '96 Ram to the sport headlights.
I ordered the suvlights.com wiring harness.
I also ordered a new switch (yes, mine burned out).
I ordered the sport headlights. I ordered the '94-'01 style. Are the '01 and up headlights better or would they not fit my '96? I know I need to cut a larger hole and that's not a problem.
I want to make sure I'm getting the right headlights.
Thank you,
KKRRSS
1996 Dodge Ram 2500 HD, 4x4 Laramie Club Cab SLT, 5.9 Cummins Turbo, Fuel Slide, BD Performance Torqloc, Pacbrake Exhaust Brake, and 4" Exhaust system.
KKRRSS is offline   Reply With Quote
The Following User Says Thank You to KKRRSS For This Useful Post:
CharlieFoxtrot (11-04-2009)
Old 09-21-2008, 02:15 AM   #2 (permalink)
Kevron's Avatar
i was going to do this too, im interested. bump for curiosity
01 24Valve 2500 QC LB, Silver, 2in lift, and DPPI 275RV Injectors, Power Pro Programmer.
Kevron is offline   Reply With Quote
Old 09-21-2008, 06:23 PM   #3 (permalink)
AlGores worst nightmare
Racer9's Avatar
Wasn't '01 when the 1/2 ton body style changed? 3/4 ton changed in '02, right? So, I don't think the later ones will fit without major body work, but I was wrong once before
Another upgrade would be the switch bypass wiring kit from LMC. It sends the electric directly to the headlights, and the switch simply controls the relay.
Heres a link, if it works.
Diesel Ram Forums: We cannot proceed.
'96 2500, CTD, 4X4 flatbed, Isspro gauges, Skyjacker D-25's, ThurenFab track bar.
Motor; BHAF, #100 fuel plate, Shimmed gov springs, Loose starwheel. 306hp/743tq
Exhaust; Schwitzer S300G, 4" downpipe, 5" turnout stacks.
Trans; Dunrite VB/TC, Intelligent Engineering billet input shaft, Burt Brown rebuild/upgrade.
Racer9 is offline   Reply With Quote
Old 09-28-2008, 12:00 AM   #4 (permalink)
KKRRSS's Avatar
I'm halfway through the conversion now... it's been great !
Old 09-28-2008, 12:08 AM   #5 (permalink)
Kevron's Avatar
half way...what all have you been doing? whats all needed?
Old 09-28-2008, 12:53 PM   #6 (permalink)
KKRRSS's Avatar
I purchased 94-01 sport headlights from an ebay seller ($200 with shipping).
I purchased (from suvlights.com) a wiring harness with relays to give more power to the headlights and convert from single headlights on each side to dual (sport) headlights on each side ($165 plus shipping).
I purchased new headlight bulbs 2 ea 9004 and 2 ea 9007 of Sylvania's Ultra white, $49 each pair so $100 total.
I also purchased a new headlight switch ($74 plus shipping) and changed it out since my old one was erratic.
I've installed the new switch.
I've removed the old headlights.
I've cut out the headlight bezels to make room for the sport dual-bulb setup.
Now I'm waiting on the suvlights.com relay harness to instal and then instal the headlight housings and then reconnect the battery and enjoy upgraded light at night!
KKRRSS
Old 09-28-2008, 04:29 PM   #7 (permalink)
Kevron's Avatar
so u have to cut the body of the truck to fit in the new two bulb section huh?
Old 09-28-2008, 09:10 PM   #8 (permalink)
KKRRSS's Avatar
The black metal behind the headlights needs a little metal cut out... but NOT the body. It's harmless,
Keith
Old 09-28-2008, 09:34 PM   #9 (permalink)
Kevron's Avatar
oh ok, iv never had my headlights off, so i thought it was just part of the front fender that u were cutting another hole into in order to get the 2nd headlight into
Old 09-28-2008, 09:41 PM   #10 (permalink)
TECH SPECIALIST
lvin4jc's Avatar
Subscribed, I'd like to know how much of an improvement you guys see out of this.
2001 4X4 Auto SLT Laramie - DANA 60/DANA 70, 3.55's - Isspro Gauges, FP, Pyro, Boost, Trans. Temp. - HBS 2" Leveling Kit - Straight Pipe - Amsoil Nanofiber 4510 CAI - Quadzilla XZT+ - Debadged - 285/75/16 Firestone Destination M/T's
230,000 miles as of 08/09 - - All Cummins all the time!
lvin4jc is offline   Reply With Quote
Old 09-28-2008, 11:52 PM   #11 (permalink)
KKRRSS's Avatar
I'll take a pic and post it !!
Old 09-28-2008, 11:58 PM   #12 (permalink)
KKRRSS's Avatar
Here is a pic of the enlarged holes; the metal headlight housing rear has holes in it already so you can access the bulbs to replace them.
Because the std setup has 1 headlamp, the two headlamp sport headlight assembly needs two access holes at the rear. It's easier just to enlarge the ones that are already there into one giant hole.
