| 94-98 Non-Powertrain Discussion of 94-98 Topics Not related to the Powertrain...NO ADVERTISING |
#13 (permalink) |
I spray painted after cutting out the metal to prevent rust. I used a 4.5" grinder, and a sawzall with a metal blade; then touched it up with a die grinder with a grinding stone. KKRRSS
1996 Dodge Ram 2500 HD, 4x4 Laramie Club Cab SLT, 5.9 Cummins Turbo, Fuel Slide, BD Performance Torqloc, Pacbrake Exhaust Brake, and 4" Exhaust system. |
#14 (permalink) | |
01 24Valve 2500 QC LB, Silver, 2in lift, and DPPI 275RV Injectors, Power Pro Programmer. |
#15 (permalink) | |
so was this harness from suvlights.com, a OEM fitted harness? like can u just unplug ur singles headlight harness and plug this one in and away u go?
#16 (permalink) |
Nope, stock harness has one headlight plug on each side of the truck AND all the power goes through the switch (not relayed). The SUVlights part is relayed (power directly through battery which = brighter lights and cooler switch on the dash) AND has two headlight plugs on each side of the truck for the "sport" headlights. The sport headlights, new bulbs, and the harness are pivotal pieces needed for the conversion; the switch is because mine was acting up. KKRRSS
#17 (permalink) |
yeah well i was talking about the OEM sport 2 headlight harness. is the suvlight.com harness like the oem dodge stock sport 2 headlight harness? or is there cutting and soldering involved?
#18 (permalink) |
Don't know; but the suvlights harness is plug and play; it also has relays which is a bonus over either stock configuration.
#20 (permalink) |
I've done this in my '96. It is almost the single best improvement I've done to this truck. You can cut the headlight buckets with an air operated sawzall, doesn't have to be nearly as much as the pictures above. I'll include a picture or two. The SUVlights harness is expensive, and he took a long time to deliver - but it's worth it. It is very well made and runs everything from relays. It makes the wiring conversion a piece of cake. You will love the results.
Charlie Smith - Columbus, Ohio '97 2500 4x4 auto, Suncoast TC/VB, #5 16.5*, Arrowcraft DRW, Aerotanks D60, KDP '96 3500 2x4 auto, Goerend TC/VB, #5 16* DDP2 355hp/970tq, D60 tank, KDP Last edited by Charlie.Smith : 10-02-2008 at 11:57 PM. Reason: Added information. |
#21 (permalink) |
maybe if i take some time off from school and have some extra spending money ill do this. i added driving lights to my bumper just so i can see! these damn stock headlights kinda suck! juuuuuuuuuust a lil!
#23 (permalink) |
That would increase the load without decreasing the resistance = bad news for the stock harness. The stock harness was engineered to carry the minimum required load when it was brand new. You add age to the harness, and now it's not performing. You could add more load (2nd set of lights) but it would be (IMHO) too much for your dash switch and the stock harness. Not a good idea. Part of the beauty of the harness upgrade is larger wires, direct pull from the batteries, and less load in the switch. KRS
#24 (permalink) |
Kevron, you ever do it? I upgraded my wife's car with a similar harness (from the same guy) and it made a world of difference. KRS
