Miles Per Tank Of Fuel - Dodge Cummins Diesel Forum
post #1 of 12 (permalink) Old 06-14-2013, 01:04 PM Thread Starter
TXCummins83's Avatar
What is the most miles you've driven on a tank of fuel?
My 97 had a recent oil change, a fuel filter change, and a new P7100 return overflow valve installed. I drive like a old man 50-60mph in order to get the most miles out of my fuel tank.
My 12v burns clean because it has slow acceleration. My average miles per tank is 650+ with 3-4 gallons left.
My new record is 719 when I pumped in fuel all the way to the fuel cap. I could have gone further till it was bone dry. My truck is a long bed with 245 tires.
97 Ram 2500 Cali Stock 180hp NV4500 S&B Intake MBRP 4'' Exhaust
96 Ram 2500 Turned Up, NV4500
TXCummins83 is offline
post #2 of 12 (permalink) Old 06-14-2013, 02:56 PM
Cranky's Avatar
I go about 500 or so and fill it up. Never did like running my tanks low. My wife now is a different story and I'm surprised the pump in her Durango hasn't gone bad yet. Also, have you checked your speedometer for accuracy? Mine is a bit slow because my tires are about 9% taller than stock....
97 Laramie SLT, ECLB, H2 chrome wheels, 3.54's, auto, 3" straight pipe otherwise all stock.
Cranky is offline
post #3 of 12 (permalink) Old 06-14-2013, 08:01 PM
876 miles from Cheyenne, Wyoming to Minneapolis on one tank and still had 3 gallons left.
Strong tailwind plus it's all basically downhill.
About 27 mpg, never have got over 24 mpg before or since, mostly around 22 mpg.
Bill
'95 2500 4wd auto
'95 3500 5 speed heavy hauler
Stock for one day
illflem is offline
post #4 of 12 (permalink) Old 06-14-2013, 08:27 PM
12vCountryBoy's Avatar
Wow you guys thats some numbers. I guess my 4x4 4:10's dont help much and the fact im always running around the farm start n stop, usually fill it up at 400-450 if im lucky
97 12v, 1 ton, 4x4, 5 speed, 235k, 4'' exhaust
12vCountryBoy is offline
post #5 of 12 (permalink) Old 06-14-2013, 08:47 PM
zthatzmanz28's Avatar
One time best of 25 mpg driving back from Atlanta to Raleigh. Just about half a tank.
Lately the 98 has been hitting 22-23 mpg highway...
1998 2500 4X4 CTD QCLB 3 inch lift-- Stablizer Bar-Tork Tek OFV-MAXX links-KDP TABBED-Luke's Link & Bushing POTS LMC dash #10 fuel plate AFC ISSPRO fuel- boost-2K* PYRO BHAF Posi-Loc Larry B Solenoid & relay rebuilt 47re low stall TC
zthatzmanz28 is offline
post #6 of 12 (permalink) Old 06-14-2013, 09:07 PM
The ol 97 auto did me well on the last tank. I did almost all interstate or rural highway driving on the tank. Its got the 35 gallon oversize tank on it, and i did just over 800 miles with a couple gallons to spare. So about 24 mpg
1997 Ram 2500 ext cab long bed
#10 fuel plate FF, afc FF, boost elbow, 4" straight pipe, BHAF, Full gauges. Valve body, TC. lots moar!
12 valves bro is offline
post #7 of 12 (permalink) Old 10-02-2013, 11:11 AM
24vCumminsDiesel's Avatar
I am at 542miles on a 1996 club cab dually with 4:10 gears & NV4500.
after the last 8th but not on empty yet. hope to hit 600 miles before I fill up.
Wonder how MPG will be afected after i do 22.5 wheels & tires(Yokohama 255/70R22.5 RY023's) 4 allum wheels & 2 steel wheels.
I have a K&N Intake/4" downpipe to dual 6" stacks/Custom Ground flate fuel plate/AFC housing all the way forward/ Anaroid screw with light tension/Boost Elbow/Earls Over flow valve. Dont know what I want to do next.....
24vCumminsDiesel is offline
post #8 of 12 (permalink) Old 10-04-2013, 10:08 AM
What size tank do you have?
How in the world are you guys getting so much out of these?
Does the EGR on the Ca version affect MPG?
98 12v qclb 4x4 automatic, Isspro EGT/trans temp/boost, KDP fixed, straight pipe, AFE Stage 2, 315/70r17 & 3rd gen wheels. 4th gen center console
Senorlechero is offline
post #9 of 12 (permalink) Old 10-04-2013, 10:11 AM
renopker's Avatar
got some of my best mpg that way and some of my worst going the other way.
I love pigs, they turn vegetables in to Bacon
renopker is offline
post #10 of 12 (permalink) Old 10-04-2013, 10:24 AM
CTK30's Avatar
I think the 275/65/20's I have make my odometer way off, I think as high as 20%. They were as tall as my friends 35 toyos on 20x10's
If I use 20% I get around 21-22 mpg
at 10% I get around 20
Putting new injectors and an OFV for good measure on next weekend since they are probably worn out, excited to see what happens. I drive like an old man though
k1ob.com, 94 5spd, 356k miles, bhaf, 5" exhaust, 30" FTE resonator, efi live #100 fuel plate full forward stacked with smarty, Stock AFC, 3k gsk, stock timing, Super B single, 3" tubular intake horn, tow mirrors down, MG diesel VCO 5x10, torkteq ofv020
CTK30 is offline
post #11 of 12 (permalink) Old 10-04-2013, 02:53 PM
Staying under 60 MPH. Generally around 55. And of course that is no load.
Right now I am driving 100 miles a day and get almost 300 miles on 13 gallons on the interstate.
post #12 of 12 (permalink) Old 11-13-2013, 02:10 AM
98.5Cumminspower's Avatar
i get 600 at a 1/8th of a tank. I usually never let it go that low but i took a trip to Nashville and didnt feel like fuelling up on the way home.
97 4x4 5 speed, southbend DD, 4k springs, injectors, 0 fuel plate, fuel turned up, 4th gen bumper. coming soon 2in leveling kit, Top Gun Customz control arms.
98.5Cumminspower is offline
