Can a 4" exhaust actually increase MPG ??? - Dodge Cummins Diesel Forum
post #1 of 41 (permalink) Old 02-01-2013, 01:18 AM Thread Starter
memphis04's Avatar
Ive searched all kinds of threads and websites and all I can find are people saying yes or no. Does any body have any hard evidence that it helped or was there just no gain? Is it a waste of money to put in on the truck?
1992 Single Cab LB 4x4 5spd pump turned up a bit, custom intake, 4' DE Exhaust, DennyT Fuel Pin, 3.54 gears, leveled in front, JI Flatbed
(NEW) 1998 Ex. Cab LB 2500 4x4 5spd stock 12V w/132K Grail Truck
memphis04 is offline
post #2 of 41 (permalink) Old 02-01-2013, 03:02 AM
admorrow's Avatar
Are you saying going from a 5" or stock exhaust?
97 4x4 built auto,Fire rings,a1000,5x.014s, 215 from seth, 62/68 sxe s480.
admorrow is offline
post #3 of 41 (permalink) Old 02-01-2013, 10:07 AM
GAmes's Avatar
iTrader Score: 7 reviews
I have 800,000 miles of logs that show absolutely no gain in mileage when I installed a 4" MBRP exhaust. I only replaced the stock exhaust because the original rotted out. A person I know who tested products for TST did extensive work on the dyno and found that a 4 inch exhaust did not make any difference in power or egts until the engine was making over 400HP at the wheels.
97 3500, 2 WD, G56, slightly bombed, 1.2 million miles. Started the second million on 8/24/13
GAmes is offline
post #4 of 41 (permalink) Old 02-01-2013, 08:10 PM Thread Starter
memphis04's Avatar
That might have made up my mind, im going from stock and I always hear and read of others getting .5 to 2 mpg increase, but im not sure I believe them.
post #5 of 41 (permalink) Old 02-01-2013, 08:16 PM
GAmes's Avatar
For some reason there are those that feel the need to exaggerate the results of an aftermarket piece of equipment or to justify the cost of a fuel additive. If it really worked, considering the push for higher mileage vehicles and their salability, the factory would install them and the fuel companies would add them.
GAmes is offline
The Following User Says Thank You to GAmes For This Useful Post:
mattswaggs (02-04-2013)
post #6 of 41 (permalink) Old 02-01-2013, 08:30 PM
It's because most folks don't want to admit they've been taken. I think some even truly believe they've had positive results.
Common benefit described is "the engine is quieter"
What the hell does that mean and what difference does it make?
Bill
'95 2500 4wd auto
'95 3500 5 speed heavy hauler
Stock for one day
illflem is offline
post #7 of 41 (permalink) Old 02-01-2013, 09:31 PM Thread Starter
memphis04's Avatar
Yea I agree, I think the aftermarket cold air intakes, intake manifolds, and exhaust systems are quite a waste of money if your just cruising around in a daily driver. Please correct me if Im wrong.
post #8 of 41 (permalink) Old 02-02-2013, 02:31 AM
country_hick's Avatar
Correct me if I am wrong here. Don't the newer diesel trucks come from factory with a 4" exhaust?
1997 3500 club cab 3.54 gears towing & camper pkg. Still stock with a built transmission at 120k. 4" exhaust, 4kgsk, and exhaust brake waiting for installation. 37337 upgrade. Still need ideas for improvements for hauling 15k fifth wheel.
country_hick is offline
post #9 of 41 (permalink) Old 02-02-2013, 03:58 AM Thread Starter
memphis04's Avatar
I had on 04 and it had factory 4 inch, but what would the advantage be?
post #10 of 41 (permalink) Old 02-02-2013, 09:35 AM
GAmes's Avatar
The 3rd gens had 24 valve engines which move more air than a 12 valve, plus emissions stuff. The '04 HO was rated at 305 HP.
GAmes is offline
post #11 of 41 (permalink) Old 02-02-2013, 01:11 PM Thread Starter
memphis04's Avatar
I just went out and measured mine and it was factory 4 inch? does yalls have that?
post #12 of 41 (permalink) Old 02-02-2013, 02:14 PM
GAmes's Avatar
Did you just measure the tip? The stock exhaust expands to 4" at the end.
GAmes is offline
