Air bag light came on after changing starter NEED HELP
Have a couple problems
First off my air bag light stays on when driving
This started after i changed my starter
Second problem is more serious
I can only start the truck with a wrench
Basically when i turn my key to start
Nothing happens but a click
I know the wire that goes from the ignition to the starter
Is fried because how i start it is i put a wrench
From the nut on the starter with the main power
And tap it onto the smaller nut on the starter solinoid
Where that little wire comes off of
I know i have to replace the wire from the ignition
To the starter solinoid, i need help on how to do that.
Thanks alot to whoever helps!
98 1500extcab 4x4 auto, converted Has a 97 12v, tranny and dash swapped, 9 1/2" suspension lift, dana 60 and 70, 4.88 gearing, kN air intake, 4" to 8" mbrp exhaust straight piped from turbo, boost gauge, 2 1/2" body lift, 210xxx km,
