99 tow mirrors on a 96 - Dodge Cummins Diesel Forum
post #1 of 12 (permalink) Old 07-19-2012, 06:09 PM Thread Starter
i have a 99 dodge 3500 with the tow mirrors and picked up a 96 dodge and want to pull the mirrors off the 99 and put them on the 96 well they be a bolt up or do i need to just order a new set
thanks
collateral damage is offline
post #2 of 12 (permalink) Old 07-19-2012, 06:21 PM
I don't believe they will fit. I found tow mirrors on ebay, they type that swing-up for towing and just checked to see if the 94-97 ones I've been eyeing will fit your '99 and it says no. They have non-powered set for $135 and power set for $205, both shipped.
1997 Ram 3500 Non-EGR 5.9L Cummins 12V, 5-spd 2WD Extended-Cab Long-Bed Dually, Alcoa Wheels, Banks PowerPack System &TwinRam Intake, Boost & EGT Guages, AFE XP Intake System
97 5spd Dually is offline
post #3 of 12 (permalink) Old 07-19-2012, 06:24 PM
country_hick's Avatar
The mirrors mount the same way on the same door. The only difference is the tow mirrors need a stabilizing plate. Hopefully those are included with the mirrors.
The only other issue is power. If you have power mirrors on both trucks the aftermarket mirrors on the 1999 have a different plug than the 1996. The solution is to cut the ends off and do a swap. Then you would have the correct ends to get power from your harness.
The only question is if you would use the heated mirror function and hook up some custom switch and timer or if you would just leave it unused.
Read the thread below for more information.
Tow mirror part numbers and descriptions for your search with your 1994-2002 truck.
1997 3500 club cab 3.54 gears towing & camper pkg. Still stock with a built transmission at 120k. 4" exhaust, 4kgsk, and exhaust brake waiting for installation. 37337 upgrade. Still need ideas for improvements for hauling 15k fifth wheel.
country_hick is offline
post #4 of 12 (permalink) Old 07-19-2012, 07:47 PM
iTrader Score: 7 reviews
both doors are the same the mirros will swap out no problem but if they are power the electrical connection is different but can be wired up to worki had to buy a replacement for my 94 and it was sent with the newer plug style but i got it wired in and working with no issues
twisted_diesel is offline
post #5 of 12 (permalink) Old 07-19-2012, 09:49 PM Thread Starter
there powered mirrors on the 99 and not on the 96 but i found a 95 at the junk yard with power mirrors i was going to pull the wiring out and put it in mine dont care about the heat part i live in florida
if its a bolt on set up ill do the swap and just splice wires i just dont want to be drilling holes and fabing up brackets
and country hick what does the stablilzing plate look like
thanks
post #6 of 12 (permalink) Old 07-19-2012, 10:08 PM
thanks
It looks like this. One per side.
Dodge Ram Pickup Truck Tow Side Mirror Support Bracket Passenger Side Right RH | eBay
post #7 of 12 (permalink) Old 07-20-2012, 12:49 PM Thread Starter
what would happen if you didnt use them would in just bend the door or make the mirror shack alot
post #8 of 12 (permalink) Old 07-20-2012, 12:51 PM
On call 24/7
98whitelightnin's Avatar
iTrader Score: 12 reviews
They will shake like crazy.
2012 Laramie Longhorn, EFI by Ryan, 5" FloPro, 35x12.5x20 Toyo AT II
1995 Dually, Weston's 5x.016, 4k GSK, 5" FloPro, 255/85r16 Toyo M/T, Goerend, ARP, 60# Springs, BW 62/65/14, BW 75/96/1.10, Isspro, Fass 125, BDP Sump, 7mm DV's, Old Numbers 421/946
1998 P-Pumped 24v, 4x4, NV4500 swap, Valair Dual Disk, BHAF, 4k GSK, .024 Dv's, Fass 150HPFP, Isspro, 5" exhaust, 2" Thuren Coils, Overland Shocks, 305/70r17 Nitto TG, 4th Gen Wheels, Fat Bald Asian 7x.010 Thanks Lee! VP Numbers 359/744
2005 Dually, 285/75r17 Nitto TG, Redhead, Thuren, Edge CTS, Smarty S06
98whitelightnin is offline
post #9 of 12 (permalink) Old 07-20-2012, 10:25 PM
Due to excessive mirror weight and vibration the doorshell could eventually crack where the mirrors mount. The stabilizing plates take the stress from 3 little holes to a large plate covering several inches that prevents the thin sheet metal from cracking.
post #10 of 12 (permalink) Old 07-20-2012, 10:58 PM
If your taking these off one truck and putting them on another you should have the brackets already
Sent from my DROID X2 using AutoGuide.Com Free App
post #11 of 12 (permalink) Old 12-18-2012, 01:25 PM
ROBBIESWORLD's Avatar
Hey is the wiring simple? I remember trying this on my old 95 nad blew something in the truck. I am doing it again with tow mirrors on my newer 95 and dont want to do the same thing.
1995 CTD DRW 4X4 XC
2004 CTD DRW 4X4 QC
MY NEW PHRASE "Forum Testosterone"
ROBBIESWORLD is offline
post #12 of 12 (permalink) Old 12-18-2012, 01:58 PM
You can always just buy the 1994 to 1997 mirrors on ebay and not worry about wiring anything wrong. The key is watching the wires on the back of the mirror itself. Some people have reported they needed to make a better hole so they would not pinch the wires during installation.
Look here Tow mirror part numbers and descriptions for your search with your 1994-2002 truck.
To put Kool-Vue mirrors (1998-2002) on a '94 - '97 truck that has these connectors,
you need to wire it like this:
up/down wire to Kool-Vue white wire #1
common (center) wire to Kool-Vue blue wire #3
right/left wire to Kool-Vue yellow wire #2
Even if for some reason you wire it wrong you can always use a multimeter to verify that power goes to the right connector before you plug into the truck.
