ABS and Brake Warning - Dodge Cummins Diesel Forum
post #1 of 38 (permalink) Old 03-03-2008, 01:46 AM Thread Starter
Seanzinator's Avatar
My ABS and Brake warning lights come on at start and do not shut off.
1996 Mineral Gray & Atomic Orange 2500 | ATS 3k-5k Compounds | ATS Trans w/ PCS Standalone | 5x0.014 Injectors | Thuren 3" Coils | Carli Track Bar | Thuren HD Steering | Pure Performance Long Arms | Nitto 35X13.50R20 Trail Grapplers | Diamo DI16 20x10
Seanzinator is offline
post #2 of 38 (permalink) Old 03-03-2008, 02:02 AM
chevyboy123's Avatar
so do mine i was told it was a short in the wire from the speed sensor or the sensor itself
95 dodge 5spd 4x4 215 pump flows 500cc head studs and o-ringed Garrett stage 3 turbo 215 inj 4k gov
5" straight pipe
chevyboy123 is offline
post #3 of 38 (permalink) Old 03-03-2008, 01:19 PM
CTDFan5.9's Avatar
Have you tried disconnecting the battery for 10 min or so (some say 30) and reconnecting (resetting codes) and see if it repeats.
CTDFan5.9 is offline
post #4 of 38 (permalink) Old 03-04-2008, 12:38 PM
stevezcummin's Avatar
mine are also on.. but i think its beacause i ripped the ABS sensor out of the back diff. LOL. i'll try the battery thing also though.
94 2500, reg cab long box. 11" of lift. 43" millitary tires #100 Fuel plate, full forward, BHAF, Banks powerpack system, BHAF, autometer boost and egt gauges. Flex-a-lite electric fans and a jacobs exhaust brake.
stevezcummin is offline
post #5 of 38 (permalink) Old 03-04-2008, 05:35 PM
Mine is doing it again, for the second time. First time the speed sensor was broken in half....this time....same thing, broken again.
My vote is the speed sensor.
-R.J.
1998 2500 QC SB 4x4 White DDP 4s, O-ringed ported and polished head, Silver 62, Full Garmonized SunCoast, billet front to back, hood stack, pump plug, no plate, AFC disabled, 5K GSK, far more to come.....
RJPotts is offline
post #6 of 38 (permalink) Old 03-09-2008, 01:00 PM
Mine did the same thing, but I has accidently shorted the circuit when installing a brake controller. When I drove the truck is was really obvious because when you stomped on the brakes the rear ABS didn't work. Found out the fuse was blown (located in the cab next to the driver's door). Replaced the fuse and all problems are now gone.
Hope this helps.
dodgenewbee is offline
The Following User Says Thank You to dodgenewbee For This Useful Post:
Chilcotin guy (05-14-2012)
post #7 of 38 (permalink) Old 03-09-2008, 01:16 PM
Banned
mine are on to im just to cheep to fix it id rather buy more go fast goodies
moparfan1234 is offline
post #8 of 38 (permalink) Old 03-22-2008, 04:48 PM Thread Starter
I have recently hooked up a Pioneer AVIC-D3 with navigation. One of the wires was supposed to be hooked up to the speed sensor. Could that be it?
The Following User Says Thank You to Seanzinator For This Useful Post:
69goat (07-15-2011)
post #9 of 38 (permalink) Old 04-01-2008, 06:01 PM
Mine was doing that with the speedo not registering untill 20 MPH changed the speed sensor and have had no more problems.
98 2wd SLT quad cab stock with auto
92 4x4 250 CC 5 speed
RBTX is offline
The Following User Says Thank You to RBTX For This Useful Post:
post #10 of 38 (permalink) Old 04-01-2008, 09:49 PM
Esjayco's Avatar
my speed didn't work until 30 mph, after a while it was 45 mph ... now it is 83 mph,
just changing the speed sensor will fix it ... ?
Black 99 Dodge, 5.9, 4wd, 5-sp., pro-line flatbed, small chip, pro-line front bumper, 200K (For Sale $10,700)... Black 2008 2500 STL Quad 4WD, 6-sp. manual, AFE Stage 2, Revtek 2" levelers, air bags, Pro-Line front bumper, Pro-Hauler flatbed, 5" TBE, Smarty [SIGPIC][/SIGPIC][
Esjayco is offline
post #11 of 38 (permalink) Old 04-03-2008, 03:08 AM
plvaulter06's Avatar
check your brake fluid... my lights were on also and i couldn't figgure out why, eventually figgured out that i had a crack in a brake line that was leaking fluid, so it was low. evenaually it got too low and the brakes didn't work so i kinda figgured out what was going on. After i fixed it and filled it back up with fluid lights went away and haven't come back on to this day
-'09 2500 QCLB 4x4, 6.7L, 68rfe, 3.73, 4" TBB, EGR Delete, AFE Stage 2, open breather, EFI Live
-'94, 2500 2wd, 5 sp, 3.54, many mods... always fun to row gears in a 12v
plvaulter06 is offline
post #12 of 38 (permalink) Old 04-04-2008, 10:27 AM
My speedo doesn't read until 20mph, and my abs and brake lights are on. Does that mean my speed sensor is bad? Will this solve the abs and brake light problem? Where is the speed sensor, and where do I buy one?
Black 1998 Ram 2500 Cummins Turbo Diesel 12v, BHAF, Silencer Removed, GlowShift Boost, GlowShift Transmission Temp, GlowShift EGT, Farmboys 5" exhaust, #10 Plate, Increased pump Timing to 16 degrees, MBC, Linex Bed Liner
Danman58 is offline
