Intigrated Seatbelt GM seat in a Quad Cab Ram - Dodge Cummins Diesel Forum
Old 04-15-2012, 12:35 AM   #1 (permalink)
Integrated Seatbelt GM seat in a Quad Cab Ram
I ended up putting 2006 GM integrated seat belt seats in my 98.5 ram. A little customizing required but fit well. Problem is the seat belt light now. I've tried jumpering out the pins on the plug, works for about a minuate, but then the light comes back on. I tore apart the old seat, found the there is just a set of contacts in there, that look like they close when the belt is extended. I am thinking that is what tells the computer that the belt is being used. I'm not sue if there is a sequence that needs to be performed, a resistence on the circuit, if i need a load on the seat belt enable circuit. A wiring diagram may help, but probably not. Hope someone has gone through the pain and has an answer on how to reamidy. Thanks
Old98.5 is offline   Reply With Quote
Old 04-15-2012, 02:38 PM   #2 (permalink)
12vCountryBoy's Avatar
cant help you with your wiring issue...but id like to see pics of the seats if you wouldnt mind.
97 12v, 1 ton, 4x4, 5 speed, 225k, stock for now!
Just cause it smokes, dont mean its broke
12vCountryBoy is offline   Reply With Quote
Old 04-15-2012, 11:02 PM   #3 (permalink)
I also can't help with the seat belt question sorry! But I would also like to see the seats and know what it took to get them in there thanks
1997 2500 eclb all stock
owens1369 is offline   Reply With Quote
Old 04-16-2012, 11:39 AM   #4 (permalink)
Super Moderator
More than likely the seat belts work in conjunction with a seat belt module that you don't have.
Easiest solution would be to remove the bulb in the dash after first making sure the belts lock instead of just extending all the way once you're strapped in.
They may need the module to lock.
Bill
'95 2500 4wd auto
'95 3500 5 speed heavy hauler
Stock for one day
Old 04-17-2012, 09:02 AM   #5 (permalink)
ARbowhunter7's Avatar
X10 on the pics.
Sent from my DROIDX using AutoGuide.Com Free App
1998 12V 3500 4x4...You know what it is
ARbowhunter7 is offline   Reply With Quote
Old 04-17-2012, 09:49 AM   #6 (permalink)
husker's Avatar
pictures here too please
Edge Juice/Att HOT UNLOCK, Goerend Transmission, Triple Disk Converter, 4" Magnaflow Stainless Steel Exhaust, 125/250 EDM Injectors, Custom 65/62/12, S&B cold air box, AirDog 150, B&W Turnover Goosneck Hitch, High Idle Fooler, MPG Fooler. Stage 2 snow kit.
husker is offline   Reply With Quote
Old 04-17-2012, 07:53 PM   #7 (permalink)
I'll try and get some pics up the end of the week. The materials of coarse don't match, looks good enough though and way more comfortable than my old broke down seats.
I do still have the seat belt box under center seat as I reused the center seat. the GM center seat that i got with the set is fixed in the up position and had no storage. Also the GM center was a few inch. narrower than the Dodge.
I'm going to pull the seat belt soleniods out of my original seats and hook the wiring. I really don't think the trucks that smart to want to see that load on the circuit but I've been wrong before.
Old 04-18-2012, 01:35 AM   #8 (permalink)
deyell01's Avatar
I have to admit I have done the Chevy seats in my 98 also and I will say way better seat for comfort and wasn't all that bad to fab into the truck. I left the console out and have it open in the middle and I really like it like that, as long as the seats you got have the armrests built into the seat. Also have the seatbelt light on the dash but I tend to ignore it.
98 3/4 ton extended cab, 5 speed, BHAF, star wheel cranked, no fuel plate and AFC full forward, southbend single disk cluth, guages, 4" mbrp dual exhaust. 275/70r18 Kelly safari tsr on raceline rims. 2 inch leveling kit. 2005 chevy bucket seats.
deyell01 is offline   Reply With Quote
Old 05-04-2012, 06:34 PM   #9 (permalink)
sledwrecker's Avatar
00 SWB, Quad, Auto, 2wd, BHAF, FASS 95, Juice WAM, 4" Diamond Eye Strait,Smarty,3cyl/hi idle box.
98 RC 3500 4x4, 12 valve,DDP 75's,4k gsk,ARP studs,NV4500 with South bend 1 3/8" input shaft and OFE Con single disk,flatbed. 4" Diamond Eye Strait,BHAF.
sledwrecker is offline   Reply With Quote
Old 05-04-2012, 10:56 PM   #10 (permalink)
jnicewan's Avatar
What did you do with the module that was under the center console/seat? The Dodge Q/C seat belt system doesnt use a simple open/closed-on/off switch at the buckle. The buckle switch is in fact a open/closed switch but the wires then go to a solenoid built into the retractor. Inside the retractor is a solenoid that locks the retractor. you cant simply leave the wires open, or shorted but if you want to install a 50-60 Ohm resister across the two wires then you should be good to go. Also if you unplugged or took that module out that was under the center console/seat then the light will come on too.
98 12v, 48RE, Revmax kit, V/B, triple disc stage 5, ultra low stall with a few other billet pieces. AFC modded, 100ish plate, 16.5ish*, KDP gone, 60lb springs, 4K-GSK, BHAF, pyro, trans, boost guage. , 72 AM general M35A2 LDT465
jnicewan is offline   Reply With Quote
